Post new topic  Reply to topic  [ 183 posts ]  Go to page Previous 17 8 9 10 1119 Next
PostPosted: Mon Jun 09, 2014 11:17 am
Stand alone version, VLC input and normal output with pre-emph, 2 core AMD CPU, XP home, ST CPU load ~90-95%.
It's something like transmitter site PC for tests, no other software, just plays and I don't touch if don't need.
I was only 1 time.
Have you run the same tests with older versions (7.40 and later, since 7.40 is where I added VLC input support)?
Is it possible that this happened after a dropout of VLC? Can you try what happens if you press the 'RESTART SOUND CARDS' button a bunch of times?
Latest = BETA006? I have actually added protection against VLC crashes in BETA005, are you 100% sure that this wasn't an older beta (BETA004 for example)? Please check the date of the file... Someone complained about VLC crashes after a signal (stream) drop, I added protection against crashes in VLC in BETA005 and so far this other person has been unable to reproduce it (and before I added the protection he could). This may sound like a stupid question, but it wouldn't be the first time that someone reports a bug and says to be using the latest version but is actually using an older one...
If you can reproduce it, please send me (if it's accessible for me) the VLC input string that you're using (via a PM if you don't want others to connect).
I start tests with beta004 and this problem occurred in beta005, but only 1 time and I saw it some time after. I don't know what happened in that moment, maybe stream crash or connetcion problem.
Urban Junglist
PostPosted: Mon Jun 09, 2014 9:18 pm
Aha, there's a nice chart of what works with what at the VLC website.. http://www.videolan.org/streaming-features.html
According to that the FLAC won't work with RTP. But that's just pure lazyness of developers, what would it possibly require to make the packetizer for FLAC in RTP.
PostPosted: Tue Jun 10, 2014 10:14 am
No with 6.21 it was around 17-18% and i just started the old exe with current settings it have, after closing the new one. Also tried with 6.32 - it was around 23-24% . New one has around 31-32% (only sometimes it`s a bit lower to 28%) . So from 6.21 to 7.42 it looks like double the load . Settings of the different versions are identical.
Yes i always prefer the last versions because of lot of good options like MB drive that not exist in older ones. Also target level per band.
If i make some changes on last version in Advanced clipper i can make the load like in 6.32 and maximum modulation peaks around 104% , which is not that bad.
Edit: Here is the real settings
Biggest difference is that I added 'Highs gap protection: Preemphasized' which is by default turned ON in newer versions but didn't exist yet in 6.21. If I turn that off, I see exactly the same CPU load in 6.21 and 7.42. There are probably more things that cause an increase (because otherwise I would have expected the CPU load to be a lot lower in 7.42).
Here are my CPU loads if I set my laptop at the slowest possible speed (otherwise I hardly see any CPU load at all):
Version - this preset - this preset without gaps protection
6.21 13%
6.32 18% 15%
7.01 19% 16%
7.23 21% 17%
7.40 21% 16-17%
7.42 18% 13-14%
Btw, if I use this preset and disable the clipper, the CPU load is 6-7% on 6.21 and 5-6% on 7.42. I did improve the clipper a lot between those versions so that seems to make sense...
PostPosted: Tue Jun 10, 2014 11:58 am
WOW , Hans
now i see what is the big "CPU hungry" . Yes if i turn it off, ST turns into a what it must be (almost not visible if i can call it that way). Thanks for telling me this . May be i used to have some more tests and find it myself but i don`t know what it may be (so many options) and it sounds very good "gaps protection" so i even not suspect it , so thanks again for this.
PostPosted: Tue Jun 10, 2014 12:05 pm
WOW , Hans
Well, it *is* good - the end result sounds far more stable with it if you have extreme highs (which happens with strong pre-emphasis). But it's also heavy... It needs to perform the first clipping stages multiple times, then it compares the results to determine how much protection is needed. And that's heavy...
It might be a good idea to turn it off (use the non-preemphasized settings) for low pre-emphasis values.
PostPosted: Tue Jun 10, 2014 5:07 pm
Because one person is still reporting a crash (with currently completely unknown cause), I have just built in some functionality to detect, log some info and auto-restart on crashes. Will be available in the next beta. I can now probably extend this to a watchdog that does something when there's no audio going through the system...
PostPosted: Tue Jun 10, 2014 9:23 pm
Wow !
lots of improvements!
the last version is the best ever tested for me!
Stereotool is the best processor ever.
Hans. PLEASE ADD A WATCHDOG FOR PLAYING AN OPTIONAL MP3 FILE WHEN STEREOTOOL DOESNT RECIEVE SOUND FOR MORE THAN 10 SECONDS (let's say )
It would be excellent to work also with the streaming imput ( not only with line in from soundcard )
PLEASE ADD ALSO THE ABILITY TO HAVE AN ALTERNATIVE STREAMING SOUND IMPUT IF FIRST STREAM IS OFFLINE.
you are THE BEST!
:roll: :roll: :roll: :roll: :roll: :roll: :roll:
( stereotool latest beta on big commercial fm radiostation with 192 kbps stream :
http://stream.cretanservers.gr/1045fm
PostPosted: Tue Jun 10, 2014 10:03 pm
Wow !
Stereotool is the best processor ever...
You are alive? :D
PostPosted: Tue Jun 10, 2014 10:28 pm
Hi Camclone, it's been a long time since I've heard from you! And it's unbelievable - you left 1 dB of extra headroom in your stream :shock: .
(People who don't know Camclone: This guy is the reason for the extremely loud 'Attack of the Camclones' preset in the Omnia 9.. ;) ).
Actually I should get one of those as well lol....
I'll have to listen on good speakers tomorrow - I hear a lot of distortion on my laptop speakers but they sometimes sound like that even if the sound that's played is actually ok.
Anyway, I am planning to rewrite the whole sound card section - and when I do that all these things would be possible. Right now it's just too difficult. But after the redesign a lot of things will be easier and work better.
PostPosted: Tue Jun 10, 2014 10:55 pm
STAND ALONE: http://www.stereotool.com/download/ster ... 43-007.exe
FIXED:
- Added restart-on-crash behavior (enable 'Watchdog' in the Configuration panel).
- Lower CPU load when using streaming with low pre-emphasis values. "Hole protection" must be set to LQ mode if it's disabled for non-preemphasized audio.
- Make SCA frequencies configurable for HAM radio
- Real watchdog behavior: Regularly check for sound card input & output
- Show Lowpass filter freq in AM panel?
- C-QUAM?
OLDER CHANGES:
- Fixed one weird hangup in VLC output when passing bad parameters
- Added option to pass extra parameters to input VLC (just type them after the URL).
- Carrier at +/- 19khz on the AM band. Just turning the FM off doesn't kill the stereo pilot. (fixed in 004)
- I again will say here that there is something wrong with Calibration section . Three options are identical with what they do : Test right silence , Test SSB lower and Test SSB higher. Nevermind what option you check, they causes same display behavour and same result as audio. --> NO, they are very different if you look at the actual output. Display is generated before calibration. Actual output does contain SSB or LSB audio.
- At the new Normal output settings there is a problem with "Input without processing" option . Sound is gagged/strange / I'm not at my Stereotool pc at the moment but when using a pipeline input and normal & fm output (192 kHz) , I noticed a strange effect when switching the normal output to bypass. Sounded like it could be a sampling rate thing? - Worked fine in some cases but not in others. I think it's fixed now.
- I think I also noticed a small typo - check the AM transmitter window.
- On the thorium preset it plays fine and then gets garbled and sounding like a 45rpm song playing on 33 rpm. cpu load is just 26% the rest of the presets work fine. (waiting for feedback, unable to reproduce it). --> Multipath Clipper is enabled in this preset. That explains the higher CPU load.
- VLC output still hangs on outputs that don't work (for example an invalid ShoutCast address). Probably because no data is sent through the output path, which causes the same stop hangup again. --> If Status is STOPPED, ERROR or NOTHINGSPECIAL, I don't call STOP or RELEASE. This seems to cause a small memory leak (a few kB probably) every time it happens, so it's not ideal. But better than a complete hangup. Still waiting for feedback on a question in VLC's forum.
- Add VLC output error detection & re-connect behavior (if possible without resetting the other inputs/outputs).
- VLC input: But something is strange sometimes plays like 1 or more samples delay between channels, occurs highs cancelation when switch to mono. I checked everything including exact mono sound input. -> Output was already running before connection was established. That's ok, but the start sample must be left channel -> fixed.
- VLC input with Low Quality Low Latency output hangs -> Solved by disabling LQLL output when VLC is used for input (which makes it impossible to reach low latencies anyway)
- VLC MP3 output. No room in current settings window... -> You can now add more options in the SOUT string (space separated)
4. Turn AM stuff off if FM is enabled (?) but what about asymmetrical clipping/limiting for FM? -> Extra switch in Expert mode
5. Add pre-emphasize output button for AM pre-emphasis
Fixed the mentioned and some other bugs in the previous beta. All combinations of settings seem to work now.
- Normal Output can now be partially separately processed for FM output. So you can generate, for example, a composite clipped 75 us pre-emphasized FM signal and a not or far less pre-emphasized signal for streaming, or a separate FM signal without composite clipping to feed remote transmitters, in the same Stereo Tool instance - no more need to run a separate copy for the stream! Only the clipping and limiting is done separately, so the CPU load does not go up much. Note that the lowpass filter can not be specified separately (lowpass filtering happens much earlier in the sequence and using different values would require doing almost all the processing twice).
- AM section now contains an 'AM Transmitter' Enabled switch.
- Headroom slider added to the AM section. No more need to abuse the Post Amp slider to create headroom for asymmetrical output. (Note: It's also not possible anymore, so you need to update your settings if you use AM).
- AM pre-emphasis checkbox added in the AM section, so you don't have to abuse the FM pre-emphasis anymore.
- AM pre-emphasis curve (which is slightly different from the FM curve) is now correctly implemented.
- AM signal can now go through the FM sound card output (it's now basically an FM/AM sound card), including tilt correction etc.
