Post new topic  Reply to topic  [ 154 posts ]  Go to page Previous 17 8 9 10 1116 Next
 Post subject: Re: Stereo Tool 7.41
PostPosted: Sat Apr 26, 2014 1:14 pm
Very easy
Just use your normal soundcard for FM output and disable the pilot signal , RDS signal . Leave only the Emphasis ON . And put 10 kOms per transmitter at every input . That will ensure not to load your sound card very HARD. In this way every transmitter will have the same signal . Is that what you want ?
PostPosted: Sat Apr 26, 2014 2:12 pm
Very easy
Not like that, send to stream for few transmitters LR preemphasised audio with ST stand alone.
Urban Junglist
PostPosted: Sat Apr 26, 2014 3:48 pm
I`m not sure what you exactly mean .. Stream to send to transmitter .. little confused
PostPosted: Sat Apr 26, 2014 7:22 pm
It's easy you have one processor in studio and stream processed preemphasised audio (not composite) for all transmitters, many stations with bigger coverage do like that.
Urban Junglist
PostPosted: Sat Apr 26, 2014 8:52 pm
Simple..
- Use FM output
- 44.1 or 48kHz sample rate
- In FM section Enable: Pre-emphasis, Pre-Emphasized Output,
- Disable: Encode Stereo, Encode RDS
- Set 50 ot 75us
Since it's for streaming i recommend maximum quality possible (like lame 48kHz 320kbps) and peek level not more then -6dB
Still way better to have ST at Transmitter site and use FM out. You realize that you are avoiding awesome FM clipper in ST like that?
Many stations with bigger coverage do like that.
Many stations does not know what they are doing.
PostPosted: Sat Apr 26, 2014 9:13 pm
Yes , i already tell this to him
but i don`t know if he wants to make a preemphasised stream and connect to it from different places.
It`s true for the awsome clipper . But he decides this- to clipper or not to clipper :)
PostPosted: Sat Apr 26, 2014 10:04 pm
Simple..
- Use FM output
- Set 50 ot 75us
FM out have 4x input sample rate.
Urban Junglist
PostPosted: Sat Apr 26, 2014 10:10 pm
Now I don't understand (?)
Did you tried what I wrote?
PostPosted: Sat Apr 26, 2014 10:16 pm
Did you try what wrote?
I know how it works but I just can't use x4 samplerate out.
Ok never mind.
Urban Junglist
PostPosted: Sat Apr 26, 2014 11:25 pm
you mean like audiotx (software) barix in-exstreamer (hardware) deva also and many more.. do you mean this?
The Power of Sound
