Post new topic  Reply to topic  [ 299 posts ]  Go to page Previous 17 8 9 10 1130 Next
PostPosted: Thu Apr 11, 2013 10:16 pm
http://www40.zippyshare.com/v/71175763/file.html 50us
PostPosted: Thu Apr 11, 2013 11:19 pm
Omnia killer at play!!
PostPosted: Fri Apr 12, 2013 8:08 am
Sounds good! Well Done! 8-)
PostPosted: Fri Apr 12, 2013 8:25 am
Hey Phantom... i am collecting tracks for one big torture test, do you have some? :)
PostPosted: Fri Apr 12, 2013 9:19 am
Yes i have a lot, please contact via SKYPE !
PostPosted: Sun Apr 14, 2013 4:23 pm
Some interesting comments on the 'cleanliness' of the mpx generation/spectrum by different processors/generators etc.
Looking forward to the next beta and hopefully SSB! (Which at present seems to be pretty contentious in terms of benefit?)
PostPosted: Sun Apr 14, 2013 5:41 pm
2/3rds finished implementing SSB now. Also fixed some bugs. I should have something either tonight or tomorrow.
PostPosted: Sun Apr 14, 2013 9:28 pm
Cool :)
I made some light preset, light because I like natural sound with constant volume and little louder than source sound ;)
Is it possible to add this to ST? Maybe some sugestions about tune some options which I don't understand or not sure how it works.
rave_fm_urban_junglist_V1.sts [48.38 KiB]
Downloaded 300 times
Urban Junglist
PostPosted: Sun Apr 14, 2013 9:35 pm
Hi!
When using the MB would setting mix = negative value of the displayed median (maybe shifted by the mean of all medians) for every band roughly restore the original (longtime) spectral balance? If so, is it possible to automate that?
If not, what other automatic ways are there, dynamic EQ, I guess?
Is it possible to reorder the filters and why is the MB missing a sidechain?
PostPosted: Sun Apr 14, 2013 10:01 pm
That is so relative! :)
