Post new topic  Reply to topic  [ 104 posts ]  Go to page Previous 17 8 9 10 11 Next
PostPosted: Tue Jan 01, 2013 6:00 pm
Yes, i found that it workes! Made big steps today. :D
Only thing is the tally's | With any professional RDS sytem (Airomate included) you can use a remote control port (LPT port in Aeromate) to load other PS pages and remotely enable TA flag (Traffic Anouncement) eg on opening TA anouncers mike on console.
Now i can concentrate on the processing parameters, and waiting for the world to end so i can buy the big version at a nice price. ;)
It`s working perfectly ...
Now playing is working like a charm with the AMIP plugin for foobar and winamp .. so RDS in the ST is almost perfect !
And yeah txt file is the one that reads ST RDS .. as i say works and update titles perfect .
PostPosted: Tue Jan 01, 2013 6:37 pm
Aqua preset from Gpagliaroli (or something like that, difficult name) added.
Thank Hans, Italian origin make it hard :lol:
Happy new year!!! ;)
by GAP
"Less is More" (Bob Katz)
PostPosted: Tue Jan 01, 2013 6:54 pm
Note: RDS special characters conversion could contain errors, if you find any please let me know.
A first quick test: Both typing in manually and reading from a Latin-1 encoded file, everything looks OK in the GUI.
But (there's always a but, isn't it ;) ) ö displays as õ and Ö as Ô on my receivers.
I'll do some more test and go through the entire charset.
I've done some more extensive testing and this is what I see in the displays of my receivers:
µ shown as ¡ (upside down exclamation mark)
¡ shown as ɑ (alpha)
‰ (per mille sign) shown as ù
Š shown as Ñ
š shown as ñ
Ž shown as ¡
ž shown as ı - Small Latin Letter Dotless I (RDS 0x9E) in one receiver, substituted for a space in another.
Œ shown as Ç
Ý shown as Ž
ý shown as ž
The GUI doesn't reflect the file contents very well:
The above are actually OK.
And another thing, if I have had ClockTime selected and then unselect it, the time display stays on screen.
The time display doesn't update, the time displayed is when I unselected ClockTime.
Ragnar
PostPosted: Tue Jan 01, 2013 8:47 pm
But with ST you have remote control to the whole program :) You can change all the settings , not only PS TA on/off and so on and so on.... see...
PostPosted: Tue Jan 01, 2013 9:14 pm
Hm, are there even still pc's available that have an LPT port??
There are some ways to set and reset the TA:
- Via the web interface
- If you can write something like this (check the .sts file for exact syntax):
[FM Transmitter]
RDS TA=1
to a file and configure that in the parameter scheduler; this file is read about once every half second and parameters are updated accordingly.
PostPosted: Tue Jan 01, 2013 9:24 pm
Š shown as Ñ
š shown as ñ
Ž shown as ¡
Œ shown as Ç
Ý shown as Ž
ý shown as ž
But... None of these characters except µ exists in Latin-1!
http://nl.wikipedia.org/wiki/ISO_8859-1
Which makes me wonder which encoding you used exactly - especially since many other characters DID get displayed correctly. Maybe Windows-1252 (CP1252) (see Wiki pagina, further down)?
Those other characters that were not shown correctly in the GUI - are they correctly displayed on the receiver?
Edit: Oddly, they seem ok in the GUI if I type them into Stereo Tool directly. Which makes me wonder even more about the encoding that's in your .txt file...
PostPosted: Tue Jan 01, 2013 9:38 pm
Yes, nomenclature confusion going on.
Windows-1252 it is. I note that some applications, e.g. Notepad, call it "ANSI", which it isn't either.
Yes, they are.
Ragnar
PostPosted: Tue Jan 01, 2013 9:40 pm
LPT no, but COM yes. There is also nice COM over LAN tool ;)
PostPosted: Wed Jan 02, 2013 12:46 am
@ragnar.jensen: I'll add the missing 32 characters tonight then. But I still don't understand what went wrong with some of the characters that you mentioned.
PostPosted: Wed Jan 02, 2013 1:39 am
The icon seems to be missing from the last standalone ..BETA702-006.exe
