Post new topic  Reply to topic  [ 218 posts ]  Go to page Previous 17 8 9 10 1122 Next
PostPosted: Tue Jan 14, 2020 6:08 pm
Well, not just the new GUI, also a new web interface and a lot of STX stuff. It's getting close... so hopefully things will get more active here soon.
PostPosted: Tue Jan 14, 2020 9:47 pm
I see "STX" very often lately. What is STX?
https://fmfeeling.com
PostPosted: Wed Jan 15, 2020 11:13 am
Our new hardware processor!
PostPosted: Fri Jan 17, 2020 10:24 pm
Finally a new beta, 9.38-BETA024! It has taken a while because we've had a lot of preliminary versions with issues that weren't suitable for posting here.
Beside a lot of STX changes, these are probably the most interesting ones:
  • VST3 plugin bug fix: NAN's in vMix solved! (Compiler bug)
  • Added "Start attack immediately" to compressors (all RMS, and non-symmetrical Peak mode) and AGC
  • Added "Start attack immediately" to AGC
PostPosted: Sat Jan 18, 2020 8:05 am
Thanks for the new beta. What does 'start attack immediately' mean/do?
PostPosted: Sat Jan 18, 2020 11:03 am
I checked, it does do nothing.
Also AGC does not work same anymore. So every preset that uses Legacy AGC with WB compressor (after beta19) is wrong when loaded.
PostPosted: Sat Jan 18, 2020 6:53 pm
Should the Immediate Attack also pertain to the Low Level Boost? What about dynamic attack speeds for it?
Or is this a legacy module that only exists for compatibility? Is that why it's in the Extreme Tweaker view only?
PostPosted: Sun Jan 19, 2020 6:24 am
The web interface no longer works. Keeps popping up dialog boxes that say "[error] undefined" and I can't use it at all.
PostPosted: Sun Jan 19, 2020 9:02 am
Did a quick check here. The "start attack immediately" option does have a noticeable effect on my single band compressor config.
PostPosted: Sun Jan 19, 2020 3:06 pm
Found it. It affects compressor after Legacy AGC, even there is no (new) option for it there.
