Post new topic  Reply to topic  [ 168 posts ]  Go to page Previous 17 8 9 10 1117 Next
PostPosted: Tue Jun 18, 2019 8:56 pm
With the last beta Winamp does not open.
Winamp works again by deleting the file dsp_stereo_tool.dll
I Use Winamp V5.63
Sorry, duplicate report.
It works well with ..2-019A
PostPosted: Wed Jun 19, 2019 1:47 pm
@mpx: Can you try if this version works?
https://www.stereotool.com/download/dsp ... 2-019A.exe
019A is working Hans, thanks
PostPosted: Wed Jun 19, 2019 2:51 pm
And 021 is available! Not a lot of changes, mainly small fixes. And more Linux/Pi versions available.
PostPosted: Sun Jun 23, 2019 3:03 am
BETA024 is available. If no bugs are reported, after adding some more presets this will become the new release.
PostPosted: Sun Jun 23, 2019 4:59 am
Hans, would you please consider also updating your declipper plugin with your new framework that includes the new CPU controls, stability, etc? And would you also consider adding the Azimuth correction filter to it?
Thanks!
PostPosted: Mon Jun 24, 2019 12:45 pm
Thanks!
Done!
PostPosted: Mon Jun 24, 2019 2:19 pm
Thanks!
Done!
Thanks!
PostPosted: Tue Jun 25, 2019 1:12 am
There's a bug with Classic Dreams FM 75uS preset in the latest beta.
https://fmfeeling.com
PostPosted: Tue Jun 25, 2019 11:43 am
What's the bug? I don't see anything here?
PostPosted: Tue Jun 25, 2019 7:32 pm
When I try to load the Classic Dreams FM 75uS presets nothing happens, don't load any settings.
