Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 758 posts ]  Go to page Previous 17 8 9 10 1176 Next
PostPosted: Sat Dec 30, 2017 1:26 am
Can you explain what the Basstardizer does (make the bass retarded??)? That beta only crashes and hangs on my desktop here so I can't check it. Someone also forgot to add a "is the ASIO device busy" check in there.
PostPosted: Sat Dec 30, 2017 6:08 am
When i turn off the clipper it goes away, It seems that enabling the "Basstardizer" with the "clipper" Causes this problem.
Standalone x86
Intel i7 Core 2.00 Ghz, 8 GB of RAM DDR, Windows 7 x64, Reltek Audio DELL Laptop.
EVA.sts [110.66 KiB]
Downloaded 465 times
Fidelity over loudness
PostPosted: Sat Dec 30, 2017 1:53 pm
Which generation i7? It works fine on mine, which is a 6th gen.
PostPosted: Sat Dec 30, 2017 6:47 pm
4th Gen
PostPosted: Sat Dec 30, 2017 10:58 pm
Hi Hans
8.55 beta 6 running fine over the last two weeks.
Updated to 8.55 beta 14 and getting this on startup.
Does a restart, reports same and then stops.
i7 6th Gen, windows 10 64 bit v1709, 4k monitors.
Best regards and a happy and successful 2018 to you.
Rossco
PostPosted: Sun Dec 31, 2017 1:15 am
@livewireaus: That was a missing NULL-pointer check for Basstardizer in low latency mode (which doesn't have a Basstardizer since it doesn't work in low latency mode). Added. This may have caused issues (crashes, or not) for people who were using Low Quality Low Latency output. Oddly, it didn't complain on my pc, not even in debug mode...
I also think I solved the NAN issue in Basstardizer. (if a NAN went in, it would stay at NAN and output silence forever).
There are some issues left with the GUI that I will fix... next year :)
New build is running.
PostPosted: Sun Dec 31, 2017 11:41 am
Did not work:
1) low latency output
2) Self Test
PostPosted: Sun Dec 31, 2017 11:48 am
Stereo Tool 8.55 BETA015
Windows stand alone: http://www.stereotool.com/download/ster ... 55-015.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 55-015.exe
VST: http://www.stereotool.com/download/vst_ ... 55-015.dll
OLDER CHANGES:
- Added Basstardizer
- Add low input level warning
- Added ASIO latency setting.
NOTE: Bass EQ
- Self test crashes
- Put Bass EQ under license
- Revisit new Hard Limit / Final Limiter with Matt BUSY Waiting for feedback from Wes before continuing; extra settings to be removed after testing.
- VST delay appears to be wrong
- New compressor mode
- Add AM presets
- Check out Butt
- Omnia.9 test/fix logging
- WatchCat website
- Triple stuff
- uMPX 24x2ch interface
- One bass page
- Talk to chip
- 2 jaar
- Fardau
- -24 dB side chain range?
PostPosted: Sun Dec 31, 2017 3:42 pm
BS 412 by Leif from Omnia9sg?
PostPosted: Sun Dec 31, 2017 4:21 pm
The following error occurred in the Windows VST64 version immediately after opening. Unfortunately, the error could not be reproduced, and came rather coincidentally.
