Post new topic  Reply to topic  [ 2125 posts ]  Go to page Previous 176 77 78 79 80213 Next
PostPosted: Mon Jun 20, 2011 1:38 pm
It's not available in the stand alone version :-( (it is accessible via the .STS file, but not via the GUI).
Ah..no problem, checked DSP... just one thing, it need to start bit under 100%. from 90 or even 80%.
PostPosted: Mon Jun 20, 2011 1:43 pm
Hm, I don't think that that's possible, if I recall the mechanism correctly. Will check... (You might be able to try it by filling in a < 1.0 value in the STS file).
PostPosted: Mon Jun 20, 2011 1:44 pm
Hi Hans. Constantly downloading and listening to the program. Good progress but it seems to me that you walk around ... I use the program's BETA620-037. Super OLL OK!!!!!. She showed normal results. In other versions there is damage to the sound. Especially the stereo effect. Circumcision is a left then a right. Duran Duran - Ordinary World Compressed bass.
Odd. There should be no difference between the versions - except for declipping and natural dynamics. I'll run a comparison to make sure that nothing went wrong.
Or are you testing with declipper enabled????
PostPosted: Mon Jun 20, 2011 3:44 pm
Tryed .. not working. Erlier that was possible.
PostPosted: Tue Jun 21, 2011 9:37 am
Bojcha: New build with 2 sliders in stand alone version.
Also flipped the waveform display (has always been upside down!). And maybe improved (fixed?) eldoradofm's channel switch issue, but I haven't had time to test it yet - will do that tonight.
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 20-070.exe
Stand alone version: http://www.stereotool.com/download/ster ... 20-070.exe
VST version: http://www.stereotool.com/download/vst_ ... 20-070.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 20-070.dll
Command line version: http://www.stereotool.com/download/ster ... 20-070.exe
PostPosted: Tue Jun 21, 2011 12:29 pm
@Hans, congratulations the channel switch issue is fixed now.
I'll send you a PM about the hanging issue that still exists when fast changing the buffer size.
PostPosted: Tue Jun 21, 2011 1:18 pm
Thanks, it's there now, and now i can set it under 100%. (found that i need 50%)
PostPosted: Tue Jun 21, 2011 9:43 pm
You're removing remaining peaks above 50% :?:
PostPosted: Tue Jun 21, 2011 10:03 pm
in ST case no - if you just look at numbers - yes.
I am using "keep band 1 at band 2 level.." at 400-500%, so 2-band AGC acting like 1-Band (something like wideband - in the absence of sidechained EQ) but with less reaction to low sounds (0-150Hz), which i wanted intentionally!
So, in case like that "Remove remaining peeks" have less reaction too, and that's why i need lower then 100% for band1.
Now, for this preset i am testing it's at 30%.
PostPosted: Tue Jun 21, 2011 11:54 pm
File not found on the server
