BETA069:
I didn't want my TODO list to grow, so:
- Fixed saving of 'Advanced highs...' filter.
Winamp DSP plugin:
http://www.stereotool.com/download/dsp_ ... 20-069.exe
Stand alone version:
http://www.stereotool.com/download/ster ... 20-069.exe
VST version:
http://www.stereotool.com/download/vst_ ... 20-069.dll
VST version (No SSE2):
Command line version:
Linux command line version:
http://www.stereotool.com/download/ster ... ETA620-069 NOT AVAILABLE
Linux GUI version:
- Fix Punch
- Loudness: Annoying cracking sound in bass. Slightly present in 5.00, worse in 6.00, maybe even worse in 6.10. Only when bass is too loud. Much worse than in Final Limiter (at same input level!) - so this clearly indicates a bug. Most likely cause: The filter that was added to remove bass artifacts.......
- No, it's the louder bass. But it can be fixed by changing some settings. Default settings updated, and behavior for 'not Very strict' improved. Also Deep bass boost and Very deep bass protection are enabled for latency 512 now.
- Fix crash at program close
- Reduce Loudness CPU load
- Scopes black background?
- Add AGC start level
Optimize peak matching for performance: Move determination to extra preprocessing step; try to change if statements to min/max or something.
- Declipping filter: Change default values for Maximum distortion and Step size (see Bojcha's post) WAITING FOR FEEDBACK
- Finish blind interface WAITING FOR FEEDBACK TODO: TEST:
Only display this window when needed.
- RDS issue reported here:
viewtopic.php?f=15&t=3703&p=11524#p11524 partially solved
DONE except for Natural Dynamics
- Declipper: Fix loud bass with soft higher frequencies issue.
- Update presets? (BASS_AGC etc.)
1 day
- Change version number
1 hour
- Release
1 hour
