Which OS are you using? I've seen a reference to installing Windows Automation API 3.0 helps speed things up if on XP or Vista. 3.0 is already included in 7 (and 8, I suppose).
I was running it in an XP virtual machine. But it doesn't matter anyway, performance of the generated code was really bad - and so much worse that I don't think it's fixable by tweaking some compiler settings. So I'm back at 10.1 now.
Well, and please take this the right way, because I know you're busy, but, I found the issue with the sluggish IDE performance under XP and Vista very quickly and easily. It is a Knowledge Base article, and has an MSDN blog entry.
If you remain convinced that things "aren't fixable", when finding the automation api issue is as easy as a simple Google search, then that's what's known as a "self-fulfilling prophecy". Maybe in the end it would end up being the same or worse, but at this point, you don't know for sure. Also, staying on the older version means you don't get any of the updates from the future versions. Those updates may not apply to your code, or they might.
I think you gave up too easily.
In my humble opinion. Your milage may vary. Etc, etc, etc...
Oh, and yeah, why would a HPF all the way up to 500 Hz be needed? That high would trim out part of the voice (speaking) range.
