Post new topic  Reply to topic  [ 2125 posts ]  Go to page Previous 173 74 75 76 77213 Next
PostPosted: Thu Jun 16, 2011 5:19 pm
thanks hans. ^^
PostPosted: Thu Jun 16, 2011 7:27 pm
BETA065:
- Reduce Loudness CPU load days?
Could you please clarify if the green indicates that you have completed this and there is nothing else to do, or the red means that you still need to do something here...or is one color or the other a mistake?
PostPosted: Thu Jun 16, 2011 9:53 pm
I think as long as there's red behind it it's not completely finished.
PostPosted: Thu Jun 16, 2011 9:58 pm
That's what I'm hoping for, but in the meantime, I think I'm going to try to see if I can get close to the same sound by just using the final limiter so I can reduce the load so maybe I can use Natural Dynamics to see if I can enhance sound quality better than what Crystalizer does for me. Of course, I have to wait for a non-slow non-beta57 version... :(
PostPosted: Fri Jun 17, 2011 12:06 am
BETA066:
- I've figured out what was causing the quality REDUCTION (clicking sounds) when the Quality setting was increased. As it turns out, at the maximum quality the precision of the clipping removal was SO small that it was WAY below rounding errors (0.000000000001 %). Not only are such low values completely useless, but there was also an issue with accumulating rounding errors that caused clicking sounds. So I've now limited the Quality setting to a maximum of 5 (clicking starts around 6). And I've lowered the default value from 4 to 3.5.
- I've increased the 'step size reduction' setting from 0.825 to 0.87 - combined with the Quality reduction mentioned earlier the CPU load is still LOWER than before, quality should be (slightly) better.
- I've looked into the "Channels L/R swap in stand alone version when changing filtering/quality" issue reported by Eldoradofm. Unfortunately I've been unable to reproduce it (also tried version 6.10). So I decided to look at the code, and I did find *one* slightly suspicious thing. I've fixed that, but I'm not very sure if it fixes the issue. (I'm sending a separate PM to Eldoradofm for feedback on this one).
@ Brian: The Loudness CPU load reduction issue was already resolved - sorry... The last time I checked (I will recheck before releasing) the Loudness CPU load with highs protection was actually lower than that of version 6.10, and roughly identical to that of version 6.00. I've removed the red text to clarify this. I think running Natural Dynamics on your system will be very problematic - although I still hope to find a better, more optimized solution (I actually might have one...).
Using the Final Limiter instead of Loudness is of course possible, but the audio quality will suffer a lot. Final Limiter cannot handle loud sounds very well.
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 20-066.exe
Stand alone version: http://www.stereotool.com/download/ster ... 20-066.exe
VST version: http://www.stereotool.com/download/vst_ ... 20-066.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 20-066.dll
Command line version: http://www.stereotool.com/download/ster ... 20-066.exe
Linux command line version: http://www.stereotool.com/download/ster ... ETA620-066 NOT AVAILABLE
Linux GUI version: http://www.stereotool.com/download/ster ... ETA620-066 NOT AVAILABLE
- Fix Punch
- Fix crash at program close
- Scopes black background?
- Add AGC start level
- Declipping filter: Optimize peak matching for performance: Move determination to extra preprocessing step; try to change if statements to min/max or something.
- Declipping filter: Change default values for Maximum distortion and Step size (see Bojcha's post) WAITING FOR FEEDBACK
- Finish blind interface WAITING FOR FEEDBACK TODO: Only display this window when needed.
- Save all new settings, also through VST interface DONE except for Natural Dynamics
- Channels L/R swap in stand alone version when changing filtering/quality (?) (eldoradofm)
- Move pre-emphasis to end of processing 1 day
- Release 1 hour
PostPosted: Fri Jun 17, 2011 2:56 am
Now Declipper 'quality' values are different for beta066...
Quality: I found 2.8-2.9 is now still good. (Not 2.7 or 3.0 - exactly 2.8 to 2.9)
Max.Input Distortion: is enough at 5.0 but at 11 is really good.
Step size: 0.87 minimum for good quality, higher values are better but not worth for cpu.
This 'Auto" for 'probably' clipped sounds seem to be nice."Madonna-Voices" track is bit better and "Jack Is Back" is still not touched.
PostPosted: Fri Jun 17, 2011 3:04 am
Thanks. Had to ask... There's also red text next to the new de-essing filter, which I guess is the highs protection?
Well, unless the load of ND is decreased, there's not much point then...so we'll see what happens.
PostPosted: Fri Jun 17, 2011 5:51 am
Got a reply from eldoradofm: Problem is NOT yet solved, and seems to be linked to priority/multicore settings. His report is very clear so it shouldn't be too difficult to find the cause.
PostPosted: Sat Jun 18, 2011 9:08 am
BETA067:
Not too interesting for most people:
- Blind interface: Moved to separate window. Currently always open, will be changed as soon as I know what to check to know if this window is needed. (There must be some API or environment variable to know that a screen reader is being used).
- L/R channel swap: I found some more suspicious code, hope that eldoradofm can run a test again.
- All settings except for Natural Dynamics are saved in the VST interface now
NO CHANGES IN AUDIO.
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 20-067.exe
Stand alone version: http://www.stereotool.com/download/ster ... 20-067.exe
VST version: http://www.stereotool.com/download/vst_ ... 20-067.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 20-067.dll
Command line version: http://www.stereotool.com/download/ster ... 20-067.exe
Linux command line version: http://www.stereotool.com/download/ster ... ETA620-067 NOT AVAILABLE
Linux GUI version: http://www.stereotool.com/download/ster ... ETA620-067 NOT AVAILABLE
- Fix Punch
- Release 1 hour
PostPosted: Sat Jun 18, 2011 9:22 am
Hello from Me ....
Hans , I have suggestion for the AGC ...
I know that Band 2 is locked not to go above band 1 level ... and the same for band 3 not to go above band 2 level ... but I think that this locks are not usefull in the following case: if a song have very low bass and very loud high`s then High`s locks mid`s and they can`t go up to the needed level . This case is for 3 band use . The case with very low bass and very loud mid`s is the same for 2 band use , the bass can`t go up to the needed level.
Yeah .. i know that these cases are a piece of very very low quality songs but.. anyway StereoTool must be Magic DSP program . Agree ? :)
