Post new topic  Reply to topic  [ 752 posts ]  Go to page Previous 171 72 73 74 75 76 Next
PostPosted: Mon Dec 10, 2012 2:35 pm
Fake Stereo doesn't adjust properly to the left (by clicking left side) since version 058
Seems to work fine here, but you need to turn both Stereo and AZIMUTH on.
Actually I need to remove that you have to turn Stereo on... That was needed in the old interface, but not anymore. Will do that.
PostPosted: Mon Dec 10, 2012 2:51 pm
Hans => it's strange , when i don't select "asio" and i push the button "open asio configuration" i have this message ; "no asio control panel is availble for this asio device" :shock: , and if i select "asio" (in blue) and than i push on the button "open asio configuration" nothing happen :cry:
I am under windows xp .
Thank you hans ;)
PostPosted: Mon Dec 10, 2012 3:28 pm
Thank you hans ;)
And how was that in 6.32?
All I do is call this function:
void AsioIO::Configure(HWND hwndDlg)
    if (ASIOControlPanel() == ASE_NotPresent)
        MessageBox(hwndDlg, "No ASIO Control Panel is available for this ASIO device.", "ASIO Control Panel not available", MB_ICONERROR);
So basically, "ASIOControlPanel()". If you don't get a popup window, and no warning either, it just means that this function reports back that all is ok... :(
Edit: Issue now confirmed by more people :( - uhm, scratch that - they have the same issue with 6.32. Not sure what's happening here...
PostPosted: Mon Dec 10, 2012 5:18 pm
hans => with the 6.32 version,(avaible on your website ,not on forum)(not beta version) , asio seem work fine with this version under windows xp sp3 :?
PostPosted: Mon Dec 10, 2012 5:26 pm
Yea, Stereo Boost meter is not so good. Will try to make something else...
But, bass boost is now better, only background is changed so meters are better visible... (?)
I would need name of image for "Asio Control Panel" button.
PostPosted: Mon Dec 10, 2012 5:58 pm
Stand alone: http://www.stereotool.com/download/ster ... 33-064.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 33-064.exe
Done:
- Fix gain and tilt display
- Check ASIO configuration (Garfield)
- Skin issues
- Add presets BUSY Waiting for feedback from Brian, Phoenix, Wolf Stahl
- Add BS412 presets
- Make BS412 work without pre-emphasis
Less urgent for usability:
- Design (several people are working on something)
For later:
- Add 'purpose based' view on settings (for example all settings that affect bass combined).
- Multi-language support
- Add basic/advanced modes
- Confirm on close (stand alone version)
PostPosted: Mon Dec 10, 2012 6:53 pm
@hvz:
could indicate, even approximately, which is the attenuation in dB in the bar graphs of current ST about AGC, MB and Clipper. (a 1/4, 1/2 and full scale)? ;)
by GAP
"Less is More" (Bob Katz)
PostPosted: Mon Dec 10, 2012 7:30 pm
@hvz:
Every block should be 1dB.. my measurements is about 0.8-0.9dB.
PostPosted: Mon Dec 10, 2012 7:45 pm
This means that ST can attenuate more than 12 db in advanced clipper right ?
12 blocks = 12 db att
It can more , but not indicated . Is this right ?
PostPosted: Mon Dec 10, 2012 8:50 pm
Every line = 1 dB. Every stronger line = 6 dB.
And yes it can go deeper than the indicators show. Whether you should want that...? ;)
