Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 758 posts ]  Go to page Previous 171 72 73 74 75 76 Next
PostPosted: Tue Jun 12, 2018 1:48 pm
So you can reproduce this? I've tried it here and so far I can't. The crash is inside the Stokkemask filter, maybe you have different settings than what I'm testing with? Could you send me your *full* settings in a PM with which you see this behavior?
By the way, this code hasn't changed in over a year. Do you know if this is new?
PM sent. Can reproduce it consistently by applying large changes in the CPU value. Just loaded BETA089 and can still do it.
If I go from 20% to 100-150% it stutters and settles. Go the other way - bang!!
Found it by accident - grabbed the CPU bar and lowered it rather than display refresh! Not sure how long it has been there - sorry!!
Ross
PostPosted: Tue Jun 12, 2018 6:09 pm
Ross
Pfew! That was a nasty one! Must always have been there ever since I optimized Stokkemask for SSE2. It's fixed now (next build).
PostPosted: Wed Jun 13, 2018 9:42 am
Stereo Tool 9.00 BETA089
Windows stand alone: https://www.stereotool.com/download/ste ... 00-090.exe
Winamp DSP: https://www.stereotool.com/download/dsp ... 00-090.exe
VST: http://www.stereotool.com/download/vst_ ... 00-090.dll
VST: https://www.stereotool.com/download/vst ... 00-090.dll
- Stokkemask crash - waiting for settings
- New skin: Make disabled stuff really gray. Currently it can be a bit confusing.
- Fix unlicensed bottom text (black background)
- Create "Warm Dutch" version of Mousse preset
OLDER CHANGES:
- Wait for Paul Thompson's fixed Breaking Dreams preset
- Fix Dale Sharp preset loading error
- Quick Adjust -> Bass Boost renamed to Basstardizer and works on both now (whichever is enabled)
- Output meter blinks red / clipped signal doesn't look tight enough. -> Ah, in "Ignore high frequencies" mode - make it less sensitive if that's enabled. -> Changed warning threshold from 0.5% to 2% in this mode, that seems to be enough so far.
- Add AM presets - check 8.55 directory
- Removed a few older presets
- Fixed overshoots when using "Multipath Stereo Phase Difference Remover".
- NAN in clipper fixed
- Figure out default value for legacy clipper mode
- Add legacy bass clipper warning
- Updated Mousse and Breaking Dreams presets
- Fix new presets BS412 levels
- Put new presets in streaming section and find good levels
- Maybe add "Limit normal output" to main screen? Might be overkill given the detail of the other settings... -> No.
- Put Advanced Clipper on main screen?
- Remainder of Matt's todo list
- Improve VST load time
- Resizing VST plugin? - Hacked something in that APPEARS to work (tested in Reaper which supports resizing, and, Audition and VST_Scanner which don't). It IS a bit tricky (might fail under certain very weird circumstances, so feedback needed...)
- SST internal display is broken
- Check __restrict performance
- Bass clipper & Bass effects were not loaded/saved correctly when selecting to load/save those
- Put bass clipper etc on main screen
- Change Bass Clipper default values
- Reorganize and update Processing main screen
- Matt's todo list Partially done
- Fix "Hear" behavior when moving filters around (among others what Bojcha reported)
- Added some presets
- Optimized scope data collection code (less CPU expected, but more memory) To be tested in release mode, in debug it helps
- "Compensate steepness for band distances" default setting changed.
- Fix before clipper bass clipper in R128 mode.
- Windows command line build fails (Winsock2)
- WatchCat build fails (ALWAYS_SOUNDCARD_ACCESS not defined in global.h 44)
- Make sure that all the bass settings are saved correctly - Done, fixed some others as well (naming and some pages weren't linked to a save command)
- Update translations
- Fix Normal Output limiter behavior (phasing sound), must have been broken forever!
- Fixed broken 4000-6000 Hz behavior in ABDP in clipper - not sure when it broken, code got corrupted (I probably hit ENTER when a value was selected in the editor...)
- Put old bass clipper meter directly below sliders again to visualize the link between them.
- Clean up warnings
- Put in 2.1 dB threshold slider (TEST). YOU PROBABLY DON'T WANT THIS VALUE TO BE LOWER but it's there now for testing.
- Move bass clipper to a logical spot.
- Combine bass effects in GUI
- Dynamically move Equalizer and Bass EQ in left menu
- Find reported crash
- Optimize "Extra softness" code
- Basstardizer did not work for Quality > 100%
- Basstardizer start level is wrong, it start with a huge boost of the bass. - was caused by a missing initialization.
- Moved Bass EQ before True Bass if it's set before MB 1 (between it was already in that order, and it doesn't make sense to have different orders.
- Cleaned up warnings (partially done)
- Bass Clipper: Allow higher than 2 extra softness. - Done, and divided numbers by 2 - so 1.0 equals what was 2 before!!!
- 2nd bass clipper causes weird harmonics. Harmonics are probably boosted. Boost threshold (figure out by how much) and filter out harmonics. => Fixed, waiting for feedback
- Rivendell plugin build. 64 bit works, 32 not yet.
- Array met frequenties versus levels (dus de uitkomst van Fourier) resultaten naar buiten brengen
- Frequency array support other than 33 bands
- Support PTYN via ASCII
- GUI: Bottom meter section now reflects changes in processing order (for bass filters).
- Sjoerd's presets sound bad on some systems (i7-2xxx) -> Probably a rounding error (log(1) != 0). Waiting for feedback.
- Reduce new bass clipper 1st harmonic -> Added new "Soft mode" setting. 0 is same as previous beta, 1 and 2 are increasingly soft (allowing overshoots).
- BETA074 Pre-bass-clipper level was wrong (removed too much deep bass!), fixed.
- Legacy AGC & LLB levels slightly different from version 8.54 => Was accidentally partially using Symmetry mode. This has been broken since BETA036.
- Auto EQ legacy mode startup behavior broken
- Natural Dynamics levels are slightly different from version 8.54 (might not be a problem) -> No
- Add a pre-bass clipper without configuration in the main clipper, to avoid suffocating mid-bass. This protects the (old) bass clipper even if you don't enable the new one, it also reduces IMD in the mid/highs further!
- Bass clipper should do something with clipper drive. -> Not anymore if pre-bass clipper works
- NAN reported in basstardizer - MAYBE fixed, waiting for feedback
- Find optimal # steps for pre-bass clipper - 2 if Fisherman's Friend mode works well. Waiting for feedback!
- Bass clipper: Added "Reduce valleys" mode that reduces overreaction (keeps more deep bass and causes less harmonics)
- Start of song AGC etc behavior. Added starting point setting for AGC
- Renamed Hans/Matt mode to a more logical name in Bass EQ; changed display of number of bands to match what makes sense to users.
- Latest beta doesn't run on XP SP 2 (GetLogicalProcessorInfo can't be located in KERNEL32.dll). Question posted. => Too hard to figure out where it's coming from (and that wouldn't even necessarily mean being able to fix it).... I guess almost nobody will still be using XP SP2 anyway...
- Quality > 100% Bypass switching causes buffer filling to move -> Tested, not (or no longer?) true
- SJP in AGC reported to be broken -> Seems fine
- SST: ThimeoKoekError was not initialized in SST. (ptke = NULL, initializer isn't executed), so uMPX encode errors were not shown
- Added new (extra) simple bass clipper
- LQLL: Allow 3 threads instead of 2 (needed for HQ mode on slower systems)
- Sound cards: Add left/right channel swap
- Check clean_NAN -> Fixed, array in Delossifier wasn't initialized to 0, caused weird sound when changing Quality > 100% and (incorrectly) reported NAN error.
- Added MagicRDS AF method A (not tested!)
- Service code didn't print anything to screen due to (probably) Visual Studio .h file changes, solved.
- GUI: If the window is too small (which shouldn't be possible to achieve manually, but might still have happened if set to full screen mode), instead of not drawing, we now just draw in part outside of the visible area.
- GUI: Redraw when warning disappears automatically, also fixes other switches between modes
- GUI: Rename and deprecate Low CPU settings -> Inverted and named to "Heavy CPU (old), under "Compatibility" header.
- Installer: Add shortcuts for run as a service install/uninstall (Still have to do that for the 64 bit version!)
- Linux: 64 bit ARM ALSA build has Jack dependency - removed.
- Check if MagicRDS ASCII mode still works (report received that it's broken) => Works flawless here... Must be a wrong setting.
- HPF after MB2 causes too loud bass into clipper (after very tightly limiting it - Bojcha) - Should be solved by new bass clipper?
- Natural Dynamics was broken in the last beta's. Now again same as in 8.54
- Show better license warning (maybe separate icon per used feature?)
- Added sound card input left/right/stereo selection (specific customer request).
- Fixed (enabled) highpass filter pre-ringing protection.
- We should probably put a warning in the next version if the CPU load is high. Done, but window doesn't nicely disappear (others as well probably)
- Start of song Auto EQ/Bass EQ was too soft: Sudden Jump Protection now only acts when a band is being boosted (that wasn't the case before); effect at beginning is nearly completely gone and overall AutoEQ/BassEQ SJP does far less than before, but is not less effective!
- Sound card high frequency correction: Make sure it always works. -> Not in Ignore high frequencies mode!!!!!
- Fix Matt's GUI crash at a specific size
- FM Analyser pilot tilt problem fixed
- AGC PEQ live updates (when editing) didn't work
- Mono audio on Matt's machine - why?? Wait for .sts files. -> Was a wrong setting, FM Analyser was enabled.
- MicroMPX ifdef stuff
- RDS Compressed flag always set regardless of GUI setting (reported - check first) -> Confirmed, initial load is ignored. - Solved, wrongly initialized, ignored first SetCompresson() call.
- Weird effect for asymmetry -> External RDS input turned Asymmetry off!
- lower output L/R peaks when using external RDS - explained by Asymmetry above
- sg doesn't sound right - probably bad hard limiter Wait for Matt to test
- RDS PS= failure on Swed test files - was ignoring size of commands for other receivers
- Fixed preset load error (060)
- NAN logging disabled again
- NAN in equalizer fixed
- New skin
- Fix Basstardizer crash
- Fixed Symmetric Peak
- Max release speed fixed
New AGC mode MORE INFO BELOW!
- RDS: Add PTYN
- RDS: Add timeout for TA
- VST version no 4K
- Backup input - check stereo
- Self test crashes
- Put Bass EQ under license
- Added Basstardizer
- Add low input level warning
- Added ASIO latency setting.
- Bass EQ subpages were ending up elsewhere due to hiding of menu
- Updated Matt's presets
- Sometimes a NAN was reported after startup on the BassClipper - display value was not initialized
- Update Analog Pleasure preset
- Add Matt's new Gold preset and Wes' new Cerulean preset
- VTune test -> Several small optimizations performed
- Optimized drawing of scopes. MPX and server code still to be done.
- Got a NAN when adjusting Bass eq and setting all the Effect Strength sliders to 0
- Remove a bunch of old presets (at least half of them.... list is way too long) BUSY
- Make in-between Analog Pleasure preset (maybe name it "Analog Controlled Pleasure", the other one Analog Overdrive?)
- Optimize MPX drawing code [Fri morning]
- Optimize scope and MPX server code [Fri morning]
- Figure out how to save Mono Bass etc under normal Audio settings
- Decide where to put Gold and Cerulean presets (since they are basically intended to do things for which I need to change code, so actually they aren't optimal yet)
- Add new presets (8.55 directory)
- Check VST Audition 125% DPI behavior -> Ok here, handled by Windows... Not sure what's going wrong.
- Mier
- Josh
- Forward HELP page on web server (installed as well? Also, new URL and view for that)
- Update TO_DW in Server.cpp to greatly reduce webserver GUI usage when drawing MPX displays (and to a lesser extent, waveform displays)
- Create ST Lite, either as a mode or as separate software.
- Add simple JSON web server communication
- When using SCA as a second audio input and in combine/mix mode (ie not in backup mode), LQLL output does not contain the SCA audio input, only the normal input, whereas both FM out and Normal Out outputs has them both mixed as expected.
- Update default preset - maybe for 9.01
- Change RESET behavior to get settings from that preset - 9.01
- Decide to keep or remove new MB clippers -> Remove for now, wait for 9.01
- Put old MB smooth clipper back??? Test with some people...
- DJB plugin build. Mail sent.
- Make separate filter for "warm bass"?
- AVG
- NAS
- MicroMPX NIC selection broken in SST web interface - Koek
- Add MME warning
- Swap Bass EQ / True Bass when both set to between MB's.
- SST: Show warnings
- Website rename Products to Buy
- Display settings (Paul T)
- Muziek uploaden
- Use top part for extra displays (declipper, numbers for MPX level etc)
- VST3 support
- Kant
- AGC better LKFS (Bojcha)
- Classical preset
- Test NanoPi
- AM streaming output
- Multi-instance version
- AF method B via UECP
- 18 Hz trigger tone
- Declipper check L-R effects
- Reduce extreme stereo
- Check out Butt
- Omnia.9 test/fix logging
- WatchCat website
- Triple stuff
- uMPX 24x2ch interface
- One bass page
- Talk to chip
- 2 jaar
- Fardau
- -24 dB side chain range?
NEW BASS CLIPPER:
Main goal: Warmer mid-bass
In the past, people have complained about bass in Stereo Tool. Different people described completely different issues with it, which made it very hard to figure out what was wrong. With the new compressor mode, that lets far more transients through (including bass transients), the problem was getting worse, and as it turns out, deep bass was suffocating the mid bass. It took until now - and input from 4 different people - for me to figure out 1. what people were hearing and 2. what the solution was.
The key info that lead to this breakthrough was coming from Wes Keene, who reported that the Stereo Tool clipper after another processor does sound warm - warmth was only missing if it was used with Stereo Tool. And in those other processors he had bypassed the finalc clipper - but not the bass clipper. It was the combination of output from Stereo Tool and the Stereo Tool clipper that caused a lack of warmth.
Long ago, I made some (I thought) very smart bass clipper design that would protect higher frequencies against IMD, moreso from deep bass than from less deep bass. When I tried my trick out I expected it to sound bad - but I never heard any issue with it. That, as it turns out, was not really true.... now that I'm hearing the difference it suddenly sounds much better with this new fix.
So, what I did: I added another bass clipper, but a very simple, traditional one. The same type that all the boxes (even analog boxes) used. No smart stuff to avoid harmonics etc, just a stupid, simple bass clipper with a few modes (hard / soft / ultrasoft). If you use that bass clipper BEFORE the existing clipper, it protects the existing clipper from killing mid-bass frequencies if there's a lot of deep bass present, and the new bass clipper adds harmonics that give the sound more warmth and power. On top of these things, there is actually less IMD in the higher frequencies as well now!
This thing isn't completely finished yet, but it should be usable. Most importantly, I need to make it adjust its threshold to what the existing clipper is doing after it. For now, you'll have to do that manually. Also, the default settings may be way off - I have never even noticed that this mid-bass stuff was missing, so I'm definitely not yet an expert in setting this thing up. So I'll wait for feedback from others for that.
NOTE: Bass EQ
New compressor mode info:
PostPosted: Wed Jun 13, 2018 11:59 am
Hans - Version number on Titlebar is still showing BETA089 so not sure if correct version uploaded?
BETA090 link downloaded and still seeing issue...
Ross
PostPosted: Thu Jun 14, 2018 12:29 am
Ross
O. Crap. I guess not then. Windows 10 decided to install an update last night, which may have interrupted the build :( :( :( :( :(
I'll run a new build tonight.
PostPosted: Thu Jun 14, 2018 5:54 pm
Got a NAN when adjusting Bass eq and setting all the Effect Strength sliders to 0 :
Exception in: GUI: Saw NAN.
This is not a serious problem but it should not happen.
2a11219 2b11219 2a11220 2b11220
Restarting: NO
2a11219 2b11219 2a11220 2b11220 2a11219 2b11219 2a11220 2b11220 2a11219 2b11219 2a11219 2b11219
Restarting: NO
2a11219 2b11219 2a11220 2b11220 2a11219 2b11219 2a11220 2b11220 2a11219 2b11219 2a11219 2b11219 2a11219 2b11219 2a11219 2b11219
Restarting: NO
2a11219 2b11219 2a11220 2b11220 2a11219 2b11219 2a11220 2b11220 2a11219 2b11219 2a11219 2b11219 2a11219 2b11219 2a11219 2b11219 2a11221 2b11221 2a11221 2b11221
Restarting: NO
2a11219 2b11219 2a11220 2b11220 2a11219 2b11219 2a11220 2b11220 2a11219 2b11219 2a11219 2b11219 2a11219 2b11219 2a11219 2b11219 2a11221 2b11221 2a11221 2b11221 2a11219 2b11219 2a1122
Restarting: NO
Restarting: NO
PostPosted: Fri Jun 15, 2018 12:06 am
Found & solved - with everything at 0 a divide by 0 occurred... oops!
PostPosted: Fri Jun 15, 2018 9:51 am
Stereo Tool 9.00 BETA092 UNSTABLE - CAN CRASH!!!! DO NOT USE THIS VERSION!
Windows stand alone: https://www.stereotool.com/download/ste ... 00-092.exe
Winamp DSP: https://www.stereotool.com/download/dsp ... 00-092.exe
VST: http://www.stereotool.com/download/vst_ ... 00-092.dll
VST: https://www.stereotool.com/download/vst ... 00-092.dll
OLDER CHANGES:
- Clean up warnings
- New skin
- RDS: Add PTYN
- VST version no 4K
- Self test crashes
- Fixed memory corruption in new scope drawing code
- Make in-between Analog Pleasure preset (maybe name it "Analog Controlled Pleasure", the other one Analog Overdrive?) -> Not needed after listening again
- Decide where to put Gold and Cerulean presets (since they are basically intended to do things for which I need to change code, so actually they aren't optimal yet) - Sound good, keep where they are
- Check VST Audition 125% DPI behavior -> Ok here, handled by Windows... Not sure what's going wrong. -> Reverted to old 8.54 code for VST plugin, ignoring DPI values for now (which are sometimes handled by the host, and sometimes not).
- Changed version number to 9.00
- Wait for Matt's preset update
- Reduced Resampler memory usage by sharing LUT data between channels (they were maintained separately) (-16 MB)
- Reduced RC memory usage by splitting class into phase-linear and non-phase linear versions, and only allocating extra data if needed. (-2 MB)
- Improved parameter lookup code; replaced map by array
- Memory usage increased with 50 MB - why??? -> Mainly due to some (not yet understood) clipper change and the symmetric compressor modes. Not much that can be done.
- VLC now indicates that you need VLC 2.
- Valgrind test
- Compare code changes vs 8.54
- RELEASE
- Mier
- Josh
- Figure out how to save Mono Bass etc under normal Audio settings - Figure out a way to move them to a new spot while still loading them from the old spot for compatibility
- AVG
- NAS
- Add MME warning
- Muziek uploaden
- VST3 support
- Kant
- Classical preset
- Test NanoPi
- Check out Butt
- WatchCat website
- Triple stuff
- One bass page
- Talk to chip
- 2 jaar
- Fardau
NEW BASS CLIPPER:
NOTE: Bass EQ
PostPosted: Fri Jun 15, 2018 10:24 am
did you already had a chance to look into this:
I'm running the 32bit version of the 8.54 Jack Linux Version (is there any newer beta?). Jack is set to 192000 Hz. The FM Output goes into Liquidsoap and produces an 192000 Hz FLAC Stream for MPX Streaming. When I additionally switch on the Normal Output and set this either to a soundcard or any other Jack software the FM Output looses the complete FM part.
And do you know when the Linux Version Beta will be available?
Thanks a lot,
Christian
PostPosted: Fri Jun 15, 2018 10:35 am
Hello Hans,
Update of the French translation file version BETA092 ;)
