Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 16 7 8 9 1059 Next
PostPosted: Thu Jan 21, 2016 11:23 pm
I still haven't gotten the output that I want out of the exciter. Sound is much clearer now (no distortion, much fewer MP3-like artifacts), but there are some other issues and the CPU load is going through the roof. I hope to be able to post something tomorrow, but if so it will be extremely heavy (but it will be a reference point for what is possible).
I had to increase the number of bands to 160 to get rid of the MP3-effects...... :shock: :o
Oddly, and very counter-intuitively, reducing the number of bands makes it much worse. 1 band doesn't have them, but 5 bands already does. At 160 it's nearly gone again.
PostPosted: Fri Jan 22, 2016 1:17 am
7.85 BETA012
Windows stand alone: http://www.stereotool.com/download/ster ... 85-013.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-013.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-013.dll
CHANGED:
- Improved Exciter: Increased number of bands from 40 to 160. MP3-like artifacts AND distortion should be gone now.
- Exciter: Calculate target amplification levels for each bin using white (?) noise!
Example input (lowpassed at 10 kHz) and output file:
https://www.wetransfer.com/downloads/cd ... 413/a461a1
- Fixed some Exciter issues (which might have been the cause of errors that some people reported).
- Improved Exciter: Now using 40 bands instead of 1
- Added some filtering to make sound less 'sandy' (distorted).
- Exciter: Check why it sometimes boosts audio around 10 kHz (?) more than it should (Johnnie Cash) - protection filter appears not to work completely. Compare what happens without protection filter! -> Fixed (more or less)
- Added a soft of exciter (not an FM exciter but something that generates highs). I've placed it (for now) under True Bass, and it cannot be configured yet. Not really sure what to make of it yet, I think I like it but it does sound a bit "rough" sometimes. Note: It can cause pre- and post ringing at higher latency settings (I will fix that later, first want to get a bit of a feeling for what it does).
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- Try "True Bass" for highs -> Probably make a version where different modes (with/without filtering, with better HPF) are tested. Maybe also with multiple bands?? To reduce generated distortion.
- Exciter: Smooth curve to avoid ringing (which is now filtered out by later steps, but that's bad).
- Exciter: Check why lowest part (just above start) is too soft.
- Add Polar stereo viewtopic.php?f=16&t=6233&p=33031#p33031
- O skin
- Blog post pre-processing
- Blog post MP3 and declipping
PostPosted: Fri Jan 22, 2016 9:11 am
Oops - when I enable the Exciter, StereoTool immediately crashes.
Problem Details from Windows:
Problemereignisname:	BEX
  Anwendungsname:	StereoTool.exe
  Anwendungsversion:	0.0.0.0
  Anwendungszeitstempel:	56a17093
  Fehlermodulname:	StereoTool.exe
  Fehlermodulversion:	0.0.0.0
  Fehlermodulzeitstempel:	56a17093
  Ausnahmeoffset:	00e8bcf7
  Ausnahmecode:	c0000417
  Ausnahmedaten:	00000000
  Betriebsystemversion:	6.1.7601.2.1.0.256.49
  Gebietsschema-ID:	1031
  Zusatzinformation 1:	61a0
  Zusatzinformation 2:	61a0f2de3b59a9adb63494d31ba4eee1
  Zusatzinformation 3:	d66e
  Zusatzinformation 4:	d66e25f6191c4bd1cd79d019ab17f9ac
PostPosted: Fri Jan 22, 2016 10:54 am
+1
PostPosted: Fri Jan 22, 2016 11:09 am
Oops! Found it. Will fix it and upload a new one.
PostPosted: Fri Jan 22, 2016 12:49 pm
7.85 BETA014
Windows stand alone: http://www.stereotool.com/download/ster ... 85-014.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-014.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-014.dll
CHANGED:
- Exciter generates more highs than the previous version (which generated too little). The amount of filtering is reduced though!
- O skin
PostPosted: Fri Jan 22, 2016 1:04 pm
I still have gaps when i enable it....! dont know why..! at any settings.
Cpy on 31% memory at about ~144mb
PostPosted: Fri Jan 22, 2016 2:44 pm
If I select highs he begins to stutter
Winamp Dsp
Windows 7 64 bit Intel Core i5-4670K CPU 3.40GHz
PostPosted: Fri Jan 22, 2016 2:58 pm
Beta14 doesn't crash anymore, but CPU-Load is so high that I cannot test it :oops: Buffers running empty almost immediately.
PostPosted: Fri Jan 22, 2016 3:14 pm
Yeah, it's 160 bands! Anyway I'll make an option to turn 160 bands on or off. I'm actually not really sure if 1 band doesn't sound better in the end...
