Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 476 posts ]  Go to page Previous 16 7 8 9 1048 Next
PostPosted: Wed Feb 18, 2015 6:34 pm
Deleted as per post below.
Sorry.
PostPosted: Wed Feb 18, 2015 7:07 pm
Can we stop this tense discussion, please?
Thank You!
PostPosted: Wed Feb 18, 2015 9:05 pm
Of course we can dear Bojcha!
I'm now pushing the round red object that says STOP.
There.
Now it stopped.
From dark Finland with love <3
PostPosted: Thu Feb 19, 2015 12:16 pm
I don't think it's dark at all though. :P
sorry offtopic.
PostPosted: Fri Feb 20, 2015 4:33 pm
Which countries use BS.412 ?
PostPosted: Sun Feb 22, 2015 9:33 am
Some european countries do. Which country do you plan on using it in?
PostPosted: Sun Mar 01, 2015 1:18 am
Do you want reports on the Winamp DSP stopping processing, or are you just concerned with the results of the processing when it works?
(Don't want to weigh you down with stuff that will be comparatively easy to fix once the AGC does what you want.)
Either way, this is a very interesting idea! Still trying to get a "feel" for all the settings. :)
Gene Savage
BlackLight Radio
https://BlackLightRadio.com
Tulsa, Oklahoma USA
PostPosted: Sun Mar 01, 2015 3:19 am
BETA 761-006
Windows stand alone: http://www.stereotool.com/download/ster ... 61-006.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 61-006.exe
Added Oil temperature behavior which was missing from my automatic (hydraulic) door model. Will explain below...
Oil temperature slider will make the time to reach the target level on attack roughly constant regardless of how big the jump in level is. Basically it will make the speed 'stay constant', similar to 'inertia' in the current SB and MB compressors. (But inertia has never worked on Attack and now it does). Note: I still need to make some changes (currently the oil can heat up instantly and that's not good, especially for release, so please don't use it for release; also the cooling down of the oil will affect the attack and release shape and I haven't implemented that yet in my model).
- Added another Peak mode slider in "New Singleband". The old one (from yesterday) works mainly on release, but in some cases the volume didn't go down fast enough on a loud sound. The new one works mainly on attack (higher value makes attack continue AFTER a peak.
- Changed Peak mode behavior in "New Singleband".
- New Singleband: Split Speed into Attack and Release Speed
- New Singleband: Made Attack and Release Speed Threshold relative to Speed - so you don't need to adjust it to change the shape.
TO DO:
Fix RDS time issue! viewtopic.php?f=6&t=5941&p=28209#p28209
PostPosted: Mon Mar 02, 2015 12:28 am
Do you have a link for the VST x64 plugin of StereoTool Beta? I'd love to check out that bit depth de-quantizer function on some of my HDCDs offline :)
In regards to the HDCD processing, since dBpoweramp decodes HDCD to 24-bit at -6dB volume, (measured bit-depth is 17 bits no peak extension, and between 18 and 20 bits when peak extension was enabled in the mastering process), I set the Declipper to the following settings:
Here is the measurement of the HDCD Asia - 24k gold CD:
Now, since the volume is halved (-6dB) Maximum restored peak level should be set to 200% correct?
PostPosted: Mon Mar 02, 2015 3:51 pm
No, Maximum Restored Peak must be set high enough to be able to compensate for the amount of clipping that was performed. If you want to lower the peaks afterwards, you can use the clipper for that.
