Bit confused... in your first post yiu say that non-asio input with non-asio output works, in the 2nd you say that this gives you a red output....
Yes, because in my first post I used a pipeline for input and in my second post (point number 2) I tried to use the normal (non ASIO) Trace 8 as an input. (Both posts use the Trace 8 as an output)
Let's see if this summarizes it correctly:
ALL Asio = ok
Normal in asio out = keeps empying
Asio in normal out - ok? !
Sorry about the confusion. To clarify:
All ASIO (in and out on Trace 8) = OK
Normal in (pipeline), ASIO out (Trace 8) = keeps emptying
Nomal in (pipeline), Normal out (Trace 8) = now seems OK
ASIO in (needs to be the Trace 8 as it's the only ASIO device) and normal out (Trace 8) would be mixing driver types on the same card which I'm not sure it would allow.
Normal in and normal out seems to fail sometimes depending on the order in which you change things? If so, what does restart and the restart button do?
Yes, using normal in (Trace 8) and normal out (Trace 8) fails on either input or output and seems to depend on which way they get opened.
i.e. from fresh start of ST, output is fine but input fails. (I think FM output opens first?) Gives red buffer error on input and "Cannot open input..." message.
Horrible tone/s pass through ST in this state! Restarting sound cards within ST gives the same result.
If I change the order of opening manually in ST, I can get the input to open but then not the output. Only one or the other seems to work!
I never tested normal in asio out, will check that tomorrow!
This is what I had a problem with initially (and still have) i.e. using a normal pipeline in and ASIO (Trace 8) output!
Your behavior seems kinda similar to what my system does - normL input plus normal output fails, exact behavior depends on opening order.. But... on my system I have the exact same problem in 7.23..... might be Vista related - it seems ok in both xp and win7, but not in vista here. !
Went back to check on 7.23 using different combinations of inputs / outputs - seems that there is also strange behaviour in this version as you mention. When I tested last on 7.23, I only reported on using normal in (pipeline) and ASIO out (Trace 8) which is OK! (unlike in latest Betas...)
Hope I've now got this right now and made it clear. I'm now even starting to get confused!
