Post new topic  Reply to topic  [ 134 posts ]  Go to page Previous 16 7 8 9 1014 Next
PostPosted: Wed Jul 03, 2024 6:32 pm
I assume that something went wrong with signing last night. I haven't seen any error messages (normally they appear in the mail). We have added RDS2 support for STXtreme today, but there's a GUI issue that needs to be fixed before it's useful to run a new build, so I expect the next build in 1.5 days.
Edit: There are indeed Mac errors that I'm getting back from Apple. I can't check what they are until I'm behind the Mac in our office tomorrow, which will be by the end of the day because I have meetings all day.
PostPosted: Thu Jul 04, 2024 2:15 pm
Good to see you're seeing errors like me. fingers crossed its an easy sort.
PostPosted: Thu Jul 04, 2024 5:14 pm
So, Apple changed some legal document which needed to be accepted, without that, signing failed. I just accepted it; I'll run a new build tonight. I hope that that was all.
PostPosted: Fri Jul 05, 2024 11:56 am
Ah, I see. Fingers crossed it sorts out the problem
PostPosted: Fri Jul 05, 2024 1:13 pm
BETA031 is available!
PostPosted: Fri Jul 05, 2024 3:06 pm
Thanks
Beta031 registers on Mac and opens fine now. I can load preset settings from the menu again.
Only thing I can see that isn't working is previously saved sessions with the plugin already loaded won't load the saved state they were in, everything has reverted to default values.
PostPosted: Fri Jul 05, 2024 11:45 pm
Huh, I am unable to select a preset... The option has just vanished?
PostPosted: Sat Jul 06, 2024 4:47 am
Strange. There was recently a thin mode added that compacts the text, but the preset button should still be there in that mode. Does it show if you widen the window to fullscreen then shrink it back down?
PostPosted: Sat Jul 06, 2024 3:16 pm
Since beta 025, the Threads and CPU selection bar is gone.
PostPosted: Sat Jul 06, 2024 10:04 pm
Running Adobe Audition 2024 Build 24.0.3.3 on macOS Sonoma 14.5 w/Apple M2 Max.
Still running VST / Stereo Tool 9.92 as any 10.x version simply doesn't load.
Today, tried both VST & VST3 64-bit 10.31-021 BETA.
See below images. The dialog box populates half off the screen; nothing thereafter. Apply/Cancel do nothing. Dropdown box does not drop anything down.
Whereas in 10.11, I was able to hit the red x to close out of this dialog box, hitting the red x has no response. Need to force quit Audition and restart entirely in both versions of 10.31-021 BETA.
Thanks very much for the support in addressing and resolving these.
https://imgur.com/a/DoZFd9v
(photos removed to reduce space)
Reconfirming this behavior for 10.31-031 BETA in Audition.
Regrettably, after clearing out the vst/vst3 files and dropping OSX/64bit v9.92 back in, once I load the plugin and the GUI populates - seemingly correctly - I cannot click anywhere/anything without an immediate crash of 992 and the Adobe Error Report dialog box populating, at which point I can send/not send, and Audition shuts down entirely and requires deleting the session that had been open at the point of the crash before opening normally once again.
Suppppper frustrating, as I'd love at least v9.92 to again work! Tried reinstalling, putting in different VST folders and rescanning plugins...same result above... :(
