Post new topic  Reply to topic  [ 156 posts ]  Go to page Previous 16 7 8 9 1016 Next
PostPosted: Sun Mar 03, 2024 5:22 pm
PM sent.
Thanks! It reproduced here immediately, so I'll look into it.
PostPosted: Sun Mar 03, 2024 6:51 pm
PM sent.
I missed one possible code path. Fixed it, but your preset triggers some other weird things that I'm looking into now. I'll run a new build tonight.
I couldn't find the other issue, but it's probably nothing really problematic (it definitely isn't new). New build is running. I'm not 100% sure if this solves both of the error messages that you got, but I think it does (the 2nd is likely caused by the 1st).
PostPosted: Mon Mar 04, 2024 12:30 am
The build isn't fully finished yet, but the Windows part is. Both crashes and the I/O glitch message are gone, available as BETA025.
PostPosted: Mon Mar 04, 2024 6:13 am
Confirmed, working flawlessly. Thanks! :)
PostPosted: Tue Mar 05, 2024 1:24 am
Beta 10.22-024 (Mar 2 2024). It seems that when you delete a user defined preset..GUI goes black and crashes. Need to relaunch for ST to work.
I have this issue as well.
PostPosted: Tue Mar 05, 2024 4:33 am
Tom just fixed this. Check the next betas (026 I think)
PostPosted: Tue Mar 05, 2024 9:27 am
Has the Beta (26) been posted? If yes, where?
PostPosted: Tue Mar 05, 2024 11:46 am
Hi. It appears to have been, and this issue is fixed. To download 026, copy the URL for the current version (024) and change the end 024 to 026.
PostPosted: Tue Mar 05, 2024 12:07 pm
I'll post 026 later, no time now... but you can indeed download it; it also has some more improvements in how the highs are handled in the clipper (smoother transition curve).
PostPosted: Tue Mar 05, 2024 12:49 pm
Thank you..truly appreciated.
