Post new topic  Reply to topic  [ 719 posts ]  Go to page Previous 16 7 8 9 1072 Next
PostPosted: Sun Dec 26, 2010 3:02 pm
Note to self: TODO: "local_incoming_copy_needed" is currently OFF at low latencies, but might be able to remove low bass artifacts especially at those low latencies. So turn it on and try to reconfigure it's LD_N value! (Potentially change into a 2-pass filter with 1/2 period shift).
PostPosted: Sun Dec 26, 2010 11:02 pm
Maybe:
"Stereo Tool audio processor
... let your ears decide !
Download and try it now !"
(direct download link button)
"Stereo Tool rules the waves ...."
(written on oscilloscope wave graphic element)
Can you hear it, too ?
The melody of "Rule, Britannia,...Britannia rules the waves" !
Then a short text with a maximum of three or four sentences with a technical description what Stereo Tool is,
but without any advertising (standard) phrases (for sure it should be shorter as the text now) ?
Then a link for detailed information (based on the long text Hans has updated lately).
Or separated links and information: "for audio professionals" and "for private users".
(with a link on the private user info page to go to the pro user detailed info page !) ?
Maybe it would be generally better to have less text and much more screenshots
of the most important processing sections on the main site to show the complexity/possibilities.
"As you see you can adjust almost every detail of the processing ......, but you don't have to, because there are many very good built-in presets to start with.
You can adjust these built-in presets and save presets without any limitations.
Maybe a changed download concept including a short text file "Getting Started" with a short description and advice for some internal presets (the same information plus graphical explanations/tutorials linked on the main site) ?
Hans, if you don't like this free concept ?
No, problem !
Then I will sell it to Orban, Omnia, Vorsis, Jünger or Leif for 1.000.000 $ :mrgreen:
(If Leif is still alive ? - during the last months more people have seen the Yeti, Big Foot or Nessie of Loch Ness).
For me there is no doubt:
Stereo Tool rules the waves !
PostPosted: Mon Dec 27, 2010 12:36 am
Having some fun streaming (this being the first time). Would keep it running for another 3 hours. Gonna go to work! :(
Here's the linkhttp://64.150.181.14:20809/stream.aac.m3u
visit website
PostPosted: Mon Dec 27, 2010 1:05 am
Unable to connect! (And this is a link that must be opened directly in a player, not by clicking on it I think). Hint: Create a .pst (I think?) file.
PostPosted: Mon Dec 27, 2010 1:10 am
Yeah it needs to opened in winamp or foobar (any player supporting aac+).
umh, need some more info about the conversion to .pst file part.
visit website
PostPosted: Mon Dec 27, 2010 2:04 am
Unable to connect!
PostPosted: Mon Dec 27, 2010 2:10 am
Unable to connect!
Bojcha, Hans: are you able to get the Icecast Status page: http://64.150.181.14:20809/ in your browser?
visit website
PostPosted: Mon Dec 27, 2010 2:17 am
no, but
Pinging 64.150.181.14 with 32 bytes of data:
Reply from 64.150.181.14: bytes=32 time=197ms TTL=50
Reply from 64.150.181.14: bytes=32 time=199ms TTL=50
Reply from 64.150.181.14: bytes=32 time=198ms TTL=50
This port is too high, most providers block this ports because torrent!
Somewhere can't go thru.
PostPosted: Mon Dec 27, 2010 2:23 am
no, but
This port is too high, most provider block this ports because torrent!
hmm, Oh I see. That's sad.
umh , I pushed to a different(German) server...http://78.159.97.251:14068/stream.aac.m3u
See if you've any luck...
visit website
PostPosted: Mon Dec 27, 2010 2:27 am
Stream URL: http://phoenixwebcast.listen2myradio.com/
I can see status, but very heavy opened, stream can't make through.
