Post new topic  Reply to topic  [ 286 posts ]  Go to page Previous 16 7 8 9 1029 Next
PostPosted: Wed May 19, 2010 2:31 am
New BETA uploaded;
- AGC window is now as in previous picture
- I added a new checkbox: "Smart volume drop after silence". Basically, if this is enabled and "Enable smoothing" is enabled, the maximum volume is lowered slightly when no loud sounds are detected for a longer period of time. Result: Start of a new track / start of sudden loud sounds, which was a bit too loud until now, is a bit softer.
Note: I don't understand why that checkbox works. Actually, if I look at the code it shouldn't - but it seems to work very well for anything I've fed it so far. If you hear anything strange (way too soft sounds etc.), please let me know.
(Ow, I know the gating indicator is located at the wrong place - will fix that later. Also saving the setting of the new checkbox will be added later)
PostPosted: Wed May 19, 2010 3:29 pm
Hans Decided to write on a forum. :P Unfortunately the last version repeats on a sound 4.22. I think that in high-frequencies more sibilants are needed but not sss And control of stripe is not very much effective again. I am arranged by sounding Orban 8500 Igor Ua
PostPosted: Wed May 19, 2010 3:32 pm
I ask to listen here it
PostPosted: Wed May 19, 2010 3:36 pm
I am sorry :oops: Once again. A sound of this station is simply excellent. An analogical sound would like to havehttp://www.rmf.fm/radio/Igor
PostPosted: Wed May 19, 2010 5:35 pm
Hello Igor,
I think some things got lost in the translation...:
If I understand you correctly, version 5.00 sounds better than 4.22, but the latest BETA's sound worse than 5.00 / similar to 4.22? Or do you mean that there's something in version 4.22 that's also present in 5.00?
Isn't that the same???
What is 'control of stripe'?
Note: This might be important: Because the AGC behaves differently from before, you might need to change the 'target volume' setting to get a similar sound to before. Also, make sure that you really have the latest version - there was an in-between BETA where the multiband compressor sounded really bad.
PostPosted: Wed May 19, 2010 10:39 pm
Can you make agc-gater faster and can you make same agc-gater to stop multiband too?
"control of stripe" - Something with "Railway" D:
PostPosted: Wed May 19, 2010 10:44 pm
[quote="hvz"]New BETA uploaded;
ok where is th ebeta version
perhaps you shoudl have a seperate directory for beta version and another for release versions
Ok now where does one find it.
PostPosted: Wed May 19, 2010 10:45 pm
current BETAs:
PostPosted: Wed May 19, 2010 10:47 pm
well i get a message access forbidden
now i get access
