Post new topic  Reply to topic  [ 146 posts ]  Go to page 1 2 3 4 515 Next
PostPosted: Fri Sep 15, 2023 3:05 pm
two small corrections on some meters, De-Esser, does not display the actual reduction as in the old version on the meter (Gain Reduction), Input (in the Stand Alone version) does not show in red the gain added by the "gain" slider, see l the actual action of the process in question when it comes into action is useful, as it was in the old gui.
PS. I can't find it in the new gui, in AGC, Link band, has it been removed?
Best
PostPosted: Fri Sep 15, 2023 4:40 pm
Dynamics> AGC> Bands> (at bottom of section) Link Bass to Main
secret code for opening all cells at once for easier finding: CTRL SHIFT +
PostPosted: Fri Sep 15, 2023 4:54 pm
Congrats on the 10.10 release.
Is there any news on the Mac VST3 fixes?
I'm currently having to run in Rosetta mode on my silicon Mac to run the VST2, Native silicon Mac OS doesn't support VST2 sadly.
Just to add to this. I'm getting a blank screen in Wavelab 11.2, Mac OS Ventura 13.5.2 with the vst2 plugin
PostPosted: Fri Sep 15, 2023 9:19 pm
Hello!
I have a valid license FM Professional+ Declipper whose license does not work as a plugin in vmix. As a standalone application, the license works ok without problems. When I install the plugin in vmix it says: vst plugin use whitout license.
What would be the problem, why doesn't it work?
Have you tried (re)entering the license in the plugin from within VMIX? The standalone registration doesn't register the plugin version.
PostPosted: Fri Sep 15, 2023 10:51 pm
Unfortunately, none of the latest versions work in latest Reaper on iMac M1, latest Monterey.
I get weird gui problems and then Reaper crashes.
Are there special settings necessary in Reaper?
In Ableton, 10.11 works fine, though.
We typically test everythingin Reaper first. Do you have a retina (high resolution) screen? I got a similar report from someone else who thought that retina was causing it. Which is possible, the Macs in our office are rarely used so they are all hooked up to old lower resolution (1920x1080) monitors, so we could have missed that.
We're working on it, we have audio passing through it but the GUI doesn't show up. So we need to figure out what's wrong with that, then we can release it.
Hello!
I think I made a booboo. I added that message a few weeks ago (the VST plugin requires *some* license to be present, and there was no message on screen that warned if you didn't have any but also weren't using features that are normally paid) but I heard from others (haven't had time to check yet due to IBC) that this message now pops up even if it's registered. If you see that things are registered on the registation page, you can *probably* ignore this message for now. (If there are no beeps or other messages after a few minutes, everything is ok).
PostPosted: Sat Sep 16, 2023 2:59 pm
Stereo Tool is a processor that makes developer level adjustments available in the user GUI. This distinguishes Stereo Tool from most processors, which offer only basic adjustments seen on audio processors for 40 years.
Audio processor adjustments are like notes in a sound palette. Imagine writing a song with four notes in a scale instead of twelve. Much more melodic flexibility with twelve notes in seven registers than four notes and nothing else.
Respectfully repeating my ongoing request that (1) all the adjustments in 9.92 remain available and (2) new versions have additional developer/designer level adjustments.
Please consider two GUI "skins" maybe green and blue that represent basic and full adjustment visibility.
I was motivated to post this again because someone suggested attack shape control was not needed. That bothered me because Stereo Tool controls recognize the time based nature of control action, such as slope and curve over time, and rate of change instead of a somewhat misleading simple term like "attack time".
Eventually Stereo Tool could have parameter visual display showing time on the X-axis and gain reduction on Y-axis, with a panel on the same screen with adjustments controlling action, and scalable gain reduction meter. It could be a full-screen window for each band's attack and release parameter. Or sizable as multiple windows for each band on a multi-band compressor. That is, a visual screen like the one for the programmable equalizer. User could "draw" a band control profile on the X-Y display, and clicking or hovering on a spot on curve could produce a pop-up with the numeric parameters of that spot. Example- -6 dB threshold, 5 ms time
Perhaps a visual display like this would enable a large amount of developer level adjustments to be understood by users.
Consider sound recording and reinforcement audio mixing consoles and control panels in aircraft. GUI design objective is providing as much control as humanly possible. For some time now the massive amount of adjustments in a mixing console have been made usable by humans by employing a layer approach. This is being done now in Stereo Tool, maybe expand this.
In essence, imagine Stereo Tool GUI as a cockpit in a commercial aircraft or a mixing console for a music concert. In both cases many interactive and complex adjustments must be made by humans, with consequences.
I note that I did a poor job of human engineering this lengthy post. :|
Last edited by Greg Strickland on Sat Sep 16, 2023 3:56 pm, edited 3 times in total.
PostPosted: Sat Sep 16, 2023 3:45 pm
1) They are. They have clearer names and descriptions than before, but they're all there. Try CTRL SHIFT + to open all cells for more visibility.
2) No, the premise of this new GUI is to not have to maintain multiple operation modes. Your suggestion would defeat the purpose.
The rest of this post about graphing should probably be in the wishlist subforum since it's a major change.
PostPosted: Sat Sep 16, 2023 3:50 pm
I found something
AGC(current) bands: Sliders shows (for example 30Hz first band), but graph shows way to high slope point, that starts to "fall" at 200Hz. Is it right, or something is wrong? I thought, it`s suppose to be the "point of slope starting" - i.e. 30Hz.
Why is this "offset", if i can call it that way?
Another example is : (if 4 bands is selected), last band slider is at 24000 Hz, but high slope starts at around 11000 Hz.
PostPosted: Sat Sep 16, 2023 4:07 pm
MrKlorox- Thank you. You are correct. I think one operating mode would be excellent if it has a pathway to developer level adjustments. Like peeling off layers of an onion, or opening multiple doors to explore a house. User can stay in the living room or venture back to the lab.
I believe I posted suggestions on the wish list. But I am not wishing. For me this is not a game or a toy.
PostPosted: Sat Sep 16, 2023 4:23 pm
TNX
