Post new topic  Reply to topic  [ 752 posts ]  Go to page Previous 168 69 70 71 7276 Next
PostPosted: Sat Dec 08, 2012 5:35 pm
How about updating the 'about' and 'register' windows to give them the same feel as the rest of the interface?
PostPosted: Sat Dec 08, 2012 5:39 pm
I am seeing a lot of grey jumping flashes in the AGC & Multiband indicators, should this be normal? They go all the way down at times (or top depending on what you call the highest point). Hard to catch them with snip tool since they are random. You can see a small amount in the Multiband.
PostPosted: Sat Dec 08, 2012 6:31 pm
- ASIO buffer display Wait for feedback, might be fixed.
I think Asio display not fixed !
i think it is!
That is clipper meter.
PostPosted: Sun Dec 09, 2012 4:15 am
Will do that, but not now. For the register window you really need to be able to paste a key - and pasting is not yet supported. About isn't that interesting I think (you may open it once, see the photo and just think "never again" :) )
Both need to be adjusted and copy/paste behavior needs to be added, as wel as a pop-up keyboard to enter text via a touch screen. I'll do that soon, but not now anymore - have some high priority things that I need to fix and I just want to get this version released so I can focus on other (non-GUI) things for a while.
PostPosted: Sun Dec 09, 2012 4:28 am
Yes the GUI has come a *long* way, and so now really looking forward to your work on the new multiband compressor and its greater spectral re-balancing capability (i.e. BBP/Orban/Ominia multiband etc)
This I suspect will be the remaining one big leap for ST to top of the ladder... :-)
PostPosted: Sun Dec 09, 2012 12:41 pm
Most important change: In ASIO output sound cards the audio delay is displayed in ms! Should be very useful.
Stand alone: http://www.stereotool.com/download/ster ... 33-062.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 33-062.exe
VST: http://www.stereotool.com/download/vst_ ... 33-062.dll
Command line: http://www.stereotool.com/download/ster ... 33-062.exe
Done:
- Icon - and display new version or not registered symbol - http://i.imgur.com/p88AG.png
- CARBON_PLUGIN warning
- Remove compiler warnings
- AXIA input sound card loading issue
- ASIO latency offset missing (was available in 6.32)
- Add ASIO settings button
- Add skin by Bojcha in about box
- Red declipper display broken (caused by memory optimization)
- Increase minimum buffer size to 0.001 s
- Add input sound card Gain
- Stokkemask broken at latency 512: "clean1ch" called with SMALL_Number <= Number
- Crash when loading built-in preset (debug assert, j_copy_ch == 0) - might have caused the channels to be swapped
- Make Linux version build again (not good for releasing now)
- Add presets
- Change version number
Less urgent for usability:
- Design (several people are working on something)
For later:
- Add 'purpose based' view on settings (for example all settings that affect bass combined).
- Multi-language support
- Add basic/advanced modes
- Confirm on close (stand alone version)
PostPosted: Sun Dec 09, 2012 3:36 pm
:mrgreen: It is actually quite nice to be able to put a face to a name sometimes!
PostPosted: Sun Dec 09, 2012 3:44 pm
- Add presets
It would be great to see Stereotool available as cross / multi platform . Still considering an OSX version?
PostPosted: Sun Dec 09, 2012 4:18 pm
hans was it always normal that in the free version that you hear every 12 hours the jingle, this sound is processed by stereo tool? while i don't even use the registrated options?
PostPosted: Sun Dec 09, 2012 6:27 pm
i have 2 questions
1) If i load an sts from old ST will be FULLY working on NEW? and can i set the sts on old version (latest) and then load on NEW? (this is cause i am not used on new layout)
2) Is is possible on NEW STS when we adjust something, to press right click and value gets back to the default value???
Thanks!
