Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 758 posts ]  Go to page Previous 167 68 69 70 7176 Next
PostPosted: Tue Jun 05, 2018 9:01 pm
Thank you very much Hans, for the integration in your software of my French translation ;)
PostPosted: Wed Jun 06, 2018 12:21 am
Stereo Tool 9.00 BETA084
Windows stand alone: http://www.stereotool.com/download/ster ... 00-084.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 00-084.exe
VST: http://www.stereotool.com/download/vst_ ... 00-084.dll
VST: ----.stereotool.com/download/vst_stereo_tool_64_BETA900-084.dll STILL BUILDING
- Fix "Hear" behavior when moving filters around (among others what Bojcha reported)
- Added some presets
- Optimized scope data collection code (less CPU expected, but more memory) To be tested in release mode, in debug it helps
- "Compensate steepness for band distances" default setting changed.
- Fix before clipper bass clipper in R128 mode.
- Windows command line build fails (Winsock2)
- WatchCat build fails (ALWAYS_SOUNDCARD_ACCESS not defined in global.h 44)
- Make sure that all the bass settings are saved correctly - Done, fixed some others as well (naming and some pages weren't linked to a save command)
- Update translations
OLDER CHANGES:
- Fix Normal Output limiter behavior (phasing sound), must have been broken forever!
- Fixed broken 4000-6000 Hz behavior in ABDP in clipper - not sure when it broken, code got corrupted (I probably hit ENTER when a value was selected in the editor...)
- Put old bass clipper meter directly below sliders again to visualize the link between them.
- Clean up warnings
- Put in 2.1 dB threshold slider (TEST). YOU PROBABLY DON'T WANT THIS VALUE TO BE LOWER but it's there now for testing.
- Move bass clipper to a logical spot.
- Combine bass effects in GUI
- Dynamically move Equalizer and Bass EQ in left menu
- Find reported crash
- Optimize "Extra softness" code
- Basstardizer did not work for Quality > 100%
- Basstardizer start level is wrong, it start with a huge boost of the bass. - was caused by a missing initialization.
- Moved Bass EQ before True Bass if it's set before MB 1 (between it was already in that order, and it doesn't make sense to have different orders.
- Cleaned up warnings (partially done)
- Bass Clipper: Allow higher than 2 extra softness. - Done, and divided numbers by 2 - so 1.0 equals what was 2 before!!!
- 2nd bass clipper causes weird harmonics. Harmonics are probably boosted. Boost threshold (figure out by how much) and filter out harmonics. => Fixed, waiting for feedback
- Rivendell plugin build. 64 bit works, 32 not yet.
- Array met frequenties versus levels (dus de uitkomst van Fourier) resultaten naar buiten brengen
- Frequency array support other than 33 bands
- Support PTYN via ASCII
- GUI: Bottom meter section now reflects changes in processing order (for bass filters).
- Sjoerd's presets sound bad on some systems (i7-2xxx) -> Probably a rounding error (log(1) != 0). Waiting for feedback.
- Reduce new bass clipper 1st harmonic -> Added new "Soft mode" setting. 0 is same as previous beta, 1 and 2 are increasingly soft (allowing overshoots).
- BETA074 Pre-bass-clipper level was wrong (removed too much deep bass!), fixed.
- Legacy AGC & LLB levels slightly different from version 8.54 => Was accidentally partially using Symmetry mode. This has been broken since BETA036.
- Auto EQ legacy mode startup behavior broken
- Natural Dynamics levels are slightly different from version 8.54 (might not be a problem) -> No
- Add a pre-bass clipper without configuration in the main clipper, to avoid suffocating mid-bass. This protects the (old) bass clipper even if you don't enable the new one, it also reduces IMD in the mid/highs further!
- Bass clipper should do something with clipper drive. -> Not anymore if pre-bass clipper works
- NAN reported in basstardizer - MAYBE fixed, waiting for feedback
- Find optimal # steps for pre-bass clipper - 2 if Fisherman's Friend mode works well. Waiting for feedback!
- Bass clipper: Added "Reduce valleys" mode that reduces overreaction (keeps more deep bass and causes less harmonics)
- Start of song AGC etc behavior. Added starting point setting for AGC
- Renamed Hans/Matt mode to a more logical name in Bass EQ; changed display of number of bands to match what makes sense to users.
- Latest beta doesn't run on XP SP 2 (GetLogicalProcessorInfo can't be located in KERNEL32.dll). Question posted. => Too hard to figure out where it's coming from (and that wouldn't even necessarily mean being able to fix it).... I guess almost nobody will still be using XP SP2 anyway...
- Quality > 100% Bypass switching causes buffer filling to move -> Tested, not (or no longer?) true
- SJP in AGC reported to be broken -> Seems fine
- SST: ThimeoKoekError was not initialized in SST. (ptke = NULL, initializer isn't executed), so uMPX encode errors were not shown
- Added new (extra) simple bass clipper
- LQLL: Allow 3 threads instead of 2 (needed for HQ mode on slower systems)
- Sound cards: Add left/right channel swap
- Check clean_NAN -> Fixed, array in Delossifier wasn't initialized to 0, caused weird sound when changing Quality > 100% and (incorrectly) reported NAN error.
- Added MagicRDS AF method A (not tested!)
- Service code didn't print anything to screen due to (probably) Visual Studio .h file changes, solved.
- GUI: If the window is too small (which shouldn't be possible to achieve manually, but might still have happened if set to full screen mode), instead of not drawing, we now just draw in part outside of the visible area.
- GUI: Redraw when warning disappears automatically, also fixes other switches between modes
- GUI: Rename and deprecate Low CPU settings -> Inverted and named to "Heavy CPU (old), under "Compatibility" header.
- Installer: Add shortcuts for run as a service install/uninstall (Still have to do that for the 64 bit version!)
- Linux: 64 bit ARM ALSA build has Jack dependency - removed.
- Check if MagicRDS ASCII mode still works (report received that it's broken) => Works flawless here... Must be a wrong setting.
- HPF after MB2 causes too loud bass into clipper (after very tightly limiting it - Bojcha) - Should be solved by new bass clipper?
- Natural Dynamics was broken in the last beta's. Now again same as in 8.54
- Show better license warning (maybe separate icon per used feature?)
- Added sound card input left/right/stereo selection (specific customer request).
- Fixed (enabled) highpass filter pre-ringing protection.
- We should probably put a warning in the next version if the CPU load is high. Done, but window doesn't nicely disappear (others as well probably)
- Start of song Auto EQ/Bass EQ was too soft: Sudden Jump Protection now only acts when a band is being boosted (that wasn't the case before); effect at beginning is nearly completely gone and overall AutoEQ/BassEQ SJP does far less than before, but is not less effective!
- Sound card high frequency correction: Make sure it always works. -> Not in Ignore high frequencies mode!!!!!
- Fix Matt's GUI crash at a specific size
- FM Analyser pilot tilt problem fixed
- AGC PEQ live updates (when editing) didn't work
- Mono audio on Matt's machine - why?? Wait for .sts files. -> Was a wrong setting, FM Analyser was enabled.
- MicroMPX ifdef stuff
- RDS Compressed flag always set regardless of GUI setting (reported - check first) -> Confirmed, initial load is ignored. - Solved, wrongly initialized, ignored first SetCompresson() call.
- Weird effect for asymmetry -> External RDS input turned Asymmetry off!
- lower output L/R peaks when using external RDS - explained by Asymmetry above
- sg doesn't sound right - probably bad hard limiter Wait for Matt to test
- RDS PS= failure on Swed test files - was ignoring size of commands for other receivers
- Fixed preset load error (060)
- NAN logging disabled again
- NAN in equalizer fixed
- New skin
- Fix Basstardizer crash
- Fixed Symmetric Peak
- Max release speed fixed
New AGC mode MORE INFO BELOW!
- RDS: Add PTYN
- RDS: Add timeout for TA
- VST version no 4K
- Backup input - check stereo
- Self test crashes
- Put Bass EQ under license
- Added Basstardizer
- Add low input level warning
- Added ASIO latency setting.
- SST internal display is broken
- Check __restrict performance
- Improve VST load time
- Resizing VST plugin? - Hacked something in that APPEARS to work (tested in Reaper which supports resizing, and, Audition and VST_Scanner which don't). It IS a bit tricky (might fail under certain very weird circumstances, so feedback needed...)
- Bass clipper & Bass effects were not loaded/saved correctly when selecting to load/save those
- Put bass clipper etc on main screen
- Check VST Audition 125% DPI behavior -> Ok here, handled by Windows... Not sure what's going wrong.
- Matt's todo list
- Update default preset
- Change RESET behavior to get settings from that preset
- Mier
- Josh
- Fix new preset levels (BS412, generic)
- Add AM presets
- Add new presets
- Create "Warm Dutch" version of Mousse preset
- Forward HELP page on web server (installed as well? Also, new URL and view for that)
- Decide to keep or remove new MB clippers -> Remove for now, wait for 9.01
- Put old MB smooth clipper back??? Test with some people...
- DJB plugin build. Mail sent.
- Make separate filter for "warm bass"?
- AVG
- NAS
- MicroMPX NIC selection broken in SST web interface - Koek
- Add MME warning
- Swap Bass EQ / True Bass when both set to between MB's.
- SST: Show warnings
- Website rename Products to Buy
- Display settings (Paul T)
- Muziek uploaden
- Use top part for extra displays (declipper, numbers for MPX level etc)
- Kant
- AGC better LKFS (Bojcha)
- Classical preset
- Test NanoPi
- AM streaming output
- Multi-instance version
- AF method B via UECP
- 18 Hz trigger tone
- Declipper check L-R effects
- Reduce extreme stereo
- Check out Butt
- Omnia.9 test/fix logging
- WatchCat website
- Triple stuff
- uMPX 24x2ch interface
- One bass page
- Talk to chip
- 2 jaar
- Fardau
- -24 dB side chain range?
NEW BASS CLIPPER:
Main goal: Warmer mid-bass
In the past, people have complained about bass in Stereo Tool. Different people described completely different issues with it, which made it very hard to figure out what was wrong. With the new compressor mode, that lets far more transients through (including bass transients), the problem was getting worse, and as it turns out, deep bass was suffocating the mid bass. It took until now - and input from 4 different people - for me to figure out 1. what people were hearing and 2. what the solution was.
The key info that lead to this breakthrough was coming from Wes Keene, who reported that the Stereo Tool clipper after another processor does sound warm - warmth was only missing if it was used with Stereo Tool. And in those other processors he had bypassed the finalc clipper - but not the bass clipper. It was the combination of output from Stereo Tool and the Stereo Tool clipper that caused a lack of warmth.
Long ago, I made some (I thought) very smart bass clipper design that would protect higher frequencies against IMD, moreso from deep bass than from less deep bass. When I tried my trick out I expected it to sound bad - but I never heard any issue with it. That, as it turns out, was not really true.... now that I'm hearing the difference it suddenly sounds much better with this new fix.
So, what I did: I added another bass clipper, but a very simple, traditional one. The same type that all the boxes (even analog boxes) used. No smart stuff to avoid harmonics etc, just a stupid, simple bass clipper with a few modes (hard / soft / ultrasoft). If you use that bass clipper BEFORE the existing clipper, it protects the existing clipper from killing mid-bass frequencies if there's a lot of deep bass present, and the new bass clipper adds harmonics that give the sound more warmth and power. On top of these things, there is actually less IMD in the higher frequencies as well now!
This thing isn't completely finished yet, but it should be usable. Most importantly, I need to make it adjust its threshold to what the existing clipper is doing after it. For now, you'll have to do that manually. Also, the default settings may be way off - I have never even noticed that this mid-bass stuff was missing, so I'm definitely not yet an expert in setting this thing up. So I'll wait for feedback from others for that.
NOTE: Bass EQ
New compressor mode info:
PostPosted: Wed Jun 06, 2018 2:41 pm
I just noticed a little cosmetic bug, if the "Auto EQ/Bass EQ used without license" is displayed, and you enter text into the "Title bar info" box... the "Auto EQ/Bass EQ used without license" changes dim/bright for each letter you type. Checked this on 2 different PC's, plus I went back a few builds and is there also.
PostPosted: Wed Jun 06, 2018 5:27 pm
Here's a little something when you're working on the VST plugin. I have here with me an increased DPI resolution within Windows. Everything is represented in 125 percent. Whenever the plugin starts, not everything fits in, because apparently the size calculation does not match the available size. To make it look normal again, I always have to switch to "Full Screen Mode". Then everything is displayed normally, but only after I have clicked somewhere. The same applies when I create a new instance. Attention! The above error seems to occur only in Adobe Audition, because it seems that a different DPI conversion takes place here. I made you some gifs here once to help you understand what I mean.
First I open the plugin, then I click into it, only then the size of the window is correct again. But this only works because I have activated full screen mode. Otherwise, it's no good to me.
Note: I would have liked to test a newer version, but unfortunately the Beta 80 was the last VST 64 version to be released. With all newer booths, the only thing that always says is that the compilation is still running, and there is therefore no link to it. :(
PostPosted: Thu Jun 07, 2018 12:47 am
The audio is clipped when "Multipath Stereo Phase Difference Remover" is enabled Image
https://fmfeeling.com
PostPosted: Thu Jun 07, 2018 12:57 am
Wow - that looks really bad! Can you send me your full preset? I definitely have NOT seen anything like that here. (That multipath stereo phase difference remover is done at the beginning of the clipper, so it shouldn't have an effect like this at all on the end result).
PostPosted: Thu Jun 07, 2018 1:02 am
Here's a little something when you're working on the VST plugin. I have here with me an increased DPI resolution within Windows. Everything is represented in 125 percent. Whenever the plugin starts, not everything fits in, because apparently the size calculation does not match the available size. To make it look normal again, I always have to switch to "Full Screen Mode". Then everything is displayed normally, but only after I have clicked somewhere. The same applies when I create a new instance. Attention! The above error seems to occur only in Adobe Audition, because it seems that a different DPI conversion takes place here. I made you some gifs here once to help you understand what I mean. dpi_scale.gif
Does "only in Adobe Audition" mean that you've tested it in others and it works fine there? At some point during startup Audition tells me how big the screen is and I use that to draw.... if that's not set correctly for some reason (if that's the case other VST's would probably have the same problem) it could explain this. I'll look into it...
PostPosted: Thu Jun 07, 2018 3:04 am
I am seeing clipping like beneyto has using Win10 64 bit standalone 9.00 beta 81. The waveform doesn't look as severely clipped as his does but the FM output meter is always red indicating clipping. It does not matter what FM preset I choose from your FM RADIO STATIONS - US 75us preset list. It always clips if the Multipath Stereo Phase Difference Remover(MSPDR) is enabled. It does not matter what the settings are in the MSPDR.
PostPosted: Thu Jun 07, 2018 5:59 pm
Well, let's put it this way. Adobe has a specially redesigned interface for increased DPI resolutions. Unlike Audacity. Everything is somehow completely different. But unlike Audacity, it's not as frequent as in Audition. Here is really the problem with every start that it is cut off.
PostPosted: Thu Jun 07, 2018 6:34 pm
Can you send me your *full* settings? I still don't see it here... I hope that one of the other settings is triggering it. (I've already tried Quality, # threads, Ignore high frequencies etc).
