Post new topic  Reply to topic  [ 1012 posts ]  Go to page Previous 166 67 68 69 70102 Next
PostPosted: Mon Mar 04, 2013 5:48 pm
BETA049:
Stand alone: http://www.stereotool.com/download/ster ... 05-049.exe
DSP/Winamp: http://www.stereotool.com/download/dsp_ ... 05-049.exe
VST version is still building...
Note: I heard some (very small) strange thing in the sound earlier, need to check if that's still there. Haven't had time for it yet.
PostPosted: Mon Mar 04, 2013 7:24 pm
eeeh 705-49 ???
PostPosted: Mon Mar 04, 2013 7:33 pm
eeeh 705-49 ???
Typo. Doesn't matter, it's going to be 7.10 anyway.
PostPosted: Mon Mar 04, 2013 7:36 pm
Ok, when ajusting the BAND slider, it gives strange effects when set @ 15%..zoomy signal..
PostPosted: Mon Mar 04, 2013 9:28 pm
Coupling at 0% is same as beta48 ?
Edit
http://i.imgur.com/owON93x.png
Coupling is killing already not so good range. Some dull track still sound better at Coupling 0, slighlty worse at 40. and at 100 highs are almost not amplified.
PostPosted: Mon Mar 04, 2013 10:09 pm
Edit
Reducing 'spectral imbalances' will indeed reduce the amount of adjustment. The first and last band might need to be 'loosened' more because they might not need protection. Coupling at 100% makes it a singleband compressor so that makes sense.
PostPosted: Mon Mar 04, 2013 10:20 pm
Why in some songs there is no any difference if coupling is at 0 or at 100% ?
Ok... a little difference , as little as possible :)
PostPosted: Mon Mar 04, 2013 10:32 pm
I'm starting to think, the better the multiband is configured such that all bands on average have the same level, the less effect coupling will have. That makes sense: If all bands are NOT on the same average level, the sound will change when the volume drops, which is also a type of spectral imbalance.
I tried it on Bojcha's R-Style preset and heard nearly no difference, however with PhantomFM's 80s Style the difference is a lot bigger.
In the case of the song where I heard spectral imbalances (Spider Murply Gang - Skandal im Sperrbezirk) Jeroens preset really improves if I set to to 40%, in Bojcha's preset I hear nothing - even very little if I set it to 100%.
I probably need to add 'median display' in the Multiband section again (was present until version 6.32), which shows the median position of each band over a long period; that helps in making presets sound more stable. (Just for clarity: You CAN make it sound stable without actually changing the sound except for moments where there are problems).
Band coupling is still a good thing (not all tracks are equal on the input), but I do need to think of something at the extremes (first and last band).
PostPosted: Mon Mar 04, 2013 10:37 pm
Yea coupling can be good.. but not between all bands..
I would dirst need to lower bands and some for mid bands.. for upper bands almost never.
PostPosted: Mon Mar 04, 2013 10:41 pm
Exept for Orban, band coupling of 60% for band 4/5 is verry common for 8300, 8400, 8500.
