Post new topic  Reply to topic  [ 719 posts ]  Go to page Previous 166 67 68 69 7072 Next
PostPosted: Sun Feb 06, 2011 10:48 am
phoenix: Same question for you about Pristine preset. I see that you have posted something for BETA012, is that still ok or is an update needed?
Updated and tested on beta34...
viewtopic.php?f=10&t=2804&p=9091#p9091
visit website
PostPosted: Sun Feb 06, 2011 11:30 am
eldoradofm: There is a difference: The data is sent to the sound card ONE GRAIN LATER than the buffer size. So an ASIO buffer size of 64 will result in a smaller latency.
Is it then possible to add a total latency display in ms and/or samples, to find the optimal ASIO buffer granularity with minimum total latency?
PostPosted: Sun Feb 06, 2011 2:55 pm
Not really. Because it depends on the sound card driver as well. Some even add 2 extra grains of latency, and as far as I know there's no way of knowing.
Anyway, lower granularity is always better.
PostPosted: Sun Feb 06, 2011 3:06 pm
Too much artifacts with Bass Boost at 512 for decent FM preset. But i make good progress without Bass Boost.
1024 mode is already much better.
At VERY LOW frequencies, the artifacts are now indeed worse than before. However, previously there were many artifacts at higher bass frequencies which are now almost gone.
I'll do a quick test to see what happens if I boost the very low frequencies separately from the rest.
PostPosted: Sun Feb 06, 2011 4:32 pm
Bojcha: After doing some more tests I'm restoring the processing of BETA33. The trick to get less artifacts is to set the first 2 frequencies further apart. So for example not 200-300 Hz, but 0-300 Hz. Now I understand that 300 may be too high... But this is all I can do for now; I expect less artifacts with the change I'm planning for the next version.
PostPosted: Sun Feb 06, 2011 6:17 pm
For current preset i testing, Bass boost is at 0-270. but will be better if i can set 60-270 or 0-100Hz. but then are many artifacts. I have good result for preset without BassBoost.
or, deep bass boost... ON ? (512-1024)
PostPosted: Sun Feb 06, 2011 10:16 pm
That doesn't work at this latency - turned it off due to too many artifacts... But actually - if you want to set it at 60-270, use 0-270 instead - that boosts the bass LESS and is very close to 0-300 so shouldn't give too much more artifacts.
PostPosted: Sun Feb 06, 2011 10:56 pm
Here it is.
"Crucial" preset for FM - latency 512! - StereoTool Standalone v6.01!
Again, Composite Limiter is important to be at 105% / Pilot 8% / RDS 4%
File comment: Feedback is welcome!
crucial_512_FM.rar [3.09 KiB]
Downloaded 458 times
PostPosted: Mon Feb 07, 2011 2:23 am
BETA601-035:
- Restored Bass Boost sound from BETA033
- Updated Phoenix' Pristine preset, added Bojcha's Crucial preset for FM Europe & US.
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 01-035.exe
Stand alone version: http://www.stereotool.com/download/ster ... 01-035.exe
VST version: http://www.stereotool.com/download/vst_ ... 01-035.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 01-035.dll
Command line version: http://www.stereotool.com/download/ster ... 01-035.exe
Linux command line version: http://www.stereotool.com/download/ster ... ETA601-035
Linux GUI version: http://www.stereotool.com/download/ster ... ETA601-035
What remains for 6.01:
- Multiband: Adjust band 3 (and others?) 'soft limit' behavior at very low latencies. Maybe: Also check clipping (also for band 3, might be re-enabled!). DONE! - 1 hour
- Multiband: Adjust extreme EQ settings before processing to avoid issues caused by steepness. - 1 hour
- Multiband: Add 'Enable' button for steepness. 1 hour
- Performance: Multiband steepness: Moving UP can be done inside current loop, no separate loop needed. Maybe down too. Currently Multiband is FAR more expensive than before. - DONE, solved in a different way. - 1 day
- MAYBE: Make Steepness smarter. That would much better preserve the audio, especially at very low latencies! How: Instead of setting all the levels at AT MOST the level of neighboring bands + a bit, combine adjacent bands, determine total output level, and then fix it such that this combined output level is approached more. (So one very low, one very high --> one a bit less low, one a bit less high instead of both low).
- Fix NOISE GATE behavior in VST plugin
- Fix 'red output bar' issue. DONE - 1 day?
- Fix Highpass filter for higher input frequencies.
- Dynamic audio processing window: I've tested this at latency 512, and there it helps. But I don't have a clue what the effect is on higher latencies. They might also sound better, but they could just as well sound worse. - 2 hours. Result: 512 and 1024 got better, 2048 and 4096 got worse. So only turned on for the first two.
- Dynamic audio processing window: CPU load is probably a lot higher (haven't measured it yet) due to the dynamic adjustment of the behavior. The dynamic code was originally intended to be executed only once when a latency was selected, and it's not optimized at all. Fixed, CPU load reduced, and for latency 2048 and 4096 there's no difference. - Optimize, 1 day
- Reduce downsampling frequency because currently very high frequencies (21-22 kHz @ 176.4 kHz input sampling rate) in the input can cause spikes even if Hard Limit is used. DONE - 1 hour
- Vibrations caused by Very deep bass distortion protection at latency 1024. Also (but far less noticeable) in higher latency modes. No issue at latency 512 because there it's turned off. - Fixed, turned it on for latency 512, and turned other bass filter OFF for 512 because it caused distortion.
- Check difference in behavior between 44.1 and 48 kHz input for multiband! This could potentially result in really big differences. - No
- Performance: Multiband: Remove sqrt(sqrt(cos())), pow(x, .75) etc. - too expensive, replace by lookup table. - NOT FOR NOW, would increase memory usage and hence risk more page faults, so it's not sure that this would improve the performance. - 2 hours
- Performance: Move chain variables to a single Struct DONE - 1 hour
- Latency: Attempt to reduce Composite Limiter sampling latency - there is no audio anywhere near the filter frequency, so a much shorter delay might still work very well - DONE, composite limiter latency is now 0.9 ms at latencies 512 and 1024 (~1.7-2 ms at higher latencies)! It can be reduced a step further (to 0.5 ms) if I allow a bit more distortion - don't know if that's useful.
- Chris: "I still hear diff on Bass and kick between Beta 16 vs Beta 08 on 2048 latency. I hear more bass and kick on Beta 08. Pls check!" - No longer true, apparently fixed in BETA020... (Which does not make sense at all, but anyway)
- And I need to check how much the performance is impacted by the latency improvements, in the case where no upsampling and downsampling is needed. This seems to be impacted way more than I expected (could also be Multiband steepness --> Not anymore, fixed). Ah, got part of it: 1% is steepness. Which leaves about 3% to be explained. Het is NIET de FM Hard Limit - ook al bereken ik daar nu meer van. Wellicht chain2 calls? - No, wrong again. Decreased Steepness grain match from every 4 to every 16 samples, extra CPU load is now only 2% - acceptable.
- Fix BYPASS mode in stand alone version DONE
- Fix 4096 in stand alone version
- ASIO latency: Add configurable ASIO granularity
- ASIO latency: Add active output push instead of reactive. - No longer needed - I think. Data is now sent to output BEFORE processing. And there's always some processing delay. Might become more interesting when CPU load goes down.
- ASIO latency: Make option to increase ST priority. DONE
- Check ASIO on single core behavior... DONE, option available
- Change ASIO latency interface (lower values, more fine-grained; display actual latency after rounding)
- Attempt to set GAUSS back to 0 - gives MUCH better processing of most filters (no high frequency noise). BUT: Loudness effect in Bjork - It's Oh So Quiet - can that be resolved in another way? - WAIT FOR FEEDBACK
- Frequencies between 60 and 75 Hz are not handled properly yet, and can still cause vibration effects at soft high frequencies in latency 512 mode. (But FAR less than in version 6.00). Fixing this will probably increase artifacts for bass in this frequency range. - WAIT FOR FEEDBACK - Make this level depend on the input level (gives less artifacts when not needed) DONE
- Set Steepness a bit higher than before because there are far less artifacts. DONE
- Bojcha: "There is strange "tone" at LEFT channel (tested ST dsp), caused by Bass Boost, but not always!" - Seems gone now - DONE
- Something is wrong with ASIO if there's only one channel instead of 2.
- Bypass is not good again
- phoenix: Direct sound at any buffer doesnot work unless MultiCore is ENABLED! FIXED
- phoenix: "Change of Thread Priority: Now this really needs working. I'll try to make you understand the pattern that I'm observing. Normal and High donot work. Only REALTIME works depending upon whether ST is run using elevated privileges or not. So if I run ST as Admin, it changes to REALTIME in Win 7/Win Vista, else it sets it to HIGH. Now clicking on Normal or High puts it back to the priority at which ST was running just before setting it to REALTIME. So if it was set to Above Normal(using task manager), it reverts to that when clicked on Normal or High from ST Sound Confg Window." - BEHAVIOR UPDATED
- bojcha: When i change Soundcards samples it should ask me to restart program or somehow to deal with it. Currently it hangs. Moving buffer size or bypass ON/OFF, resolves it. - REPORTED TO BE OK NOW
- phoenix: ASIO sound disappears on enabling multicore. - SOLVED
- Allow setting Realtime priority on Vista (if possible, Admin rights?) - NOT POSSIBLE
- Change buffer size configuration to match whole ASIO grains (probably only displaying them) - DONE
- bojcha: I notice when Opening and starting program is a bit slower, minimizing to tray slower too. but it's ok. - Reported OK now.
- Hangups during closing of stand alone version. (hThread) Solved??? - NOT SEEN BY OTHERS
- Real-time priority +6/+5 possible instead of ABOVE_NORMAL and HIGH?
- Fix different priority settings - BUSY, waiting for feedback...
- Check/fix Bass Boost ringing reported by Bojcha for higher 'upto' frequencies. REDUCED it a bit, hope that suffices... Less steep filtering (ie. bigger difference between first 2 frequencies) helps. Another step is possible to reduce them further (probably 50% more) - DONE, FAR less artifacts now.
- Update Bojcha's Addiction preset
- Change version number --> 6.10 (there are also interface changes)
- Check forum for good new presets
- Release
Questions:
* Multiband: Question: Is Steepness behavior ok? - AS GOOD AS POSSIBLE NOW, AND CAN BE TURNED OFF.
* Loudness: QUESTION: The changed Punch behavior, is that good or bad? Should I attempt to let Punch behave as it did in the past as much as possible, or not?
For 6.02:
- It's possible to send data to an audio buffer AFTER I've returned control to the driver if I call ASIOOutputReady() when I'm ready
- Add non-phase linear Multiband stage between AGC and incoming_copy_needed.
- Use double overlap (allow quality levels > 100%) to strongly reduce artifacts
- Introduce extra latency between 512 and 1024 by upsampling or downsampling
PostPosted: Mon Feb 07, 2011 3:07 pm
Yes.. BassBoost better in beta 33 and 35. I used beta34 for preset 'Crucial', so i must check again with beta35.
Hans, i been thinking about input and output sample rate.
First thing is it's still using bit much CPU usage. Other thing is selectng samplerate is it at 'INPUT'. It's unlogical.
If i want to put winamp with VAC1 to ST input, that's input rate and cannot be 176400 or 192000... etc.. It should be 44100 or 48000. Then 'OUTPUT' 192000 or 176400 (if i use FM out)
Currently for setup is like this:
Source/Player > VAC1 > ST Input > VAC2 (ST output)
is..
VAC1 activated at Maximum samplerate. - if VAC1 supports 192000 it will be 192000, wich i think it's wrong!
VAC1 Should be 48kHz (input) then 4 times upsampled for 192kHz (if FM out) or,
VAC1 Should be 44.1kHz (input) then 4 times upsampled for 176.4kHz, or 192000 if possible (if FM out)
I set VAC1 to suport 44.1 - 200kHz max, Started ST Standalone with VAC1 as input and ST started VAC1 and that 200kHz maximum rate.(watching VAC COntrol panel). That should not happen. It should start at 44,1 or 48
So,
Input rate separate selection rate and Output (normal/FM) Saparate selection.
Used VAC version 4.10
