Post new topic  Reply to topic  [ 719 posts ]  Go to page Previous 162 63 64 65 6672 Next
PostPosted: Thu Feb 03, 2011 11:43 pm
@Bojcha: I am curious, are you able to get 192kHz output when using 48kHz(or any other) input rate with ASIO enabled? When I enable ASIO I can only get 192 kHz out when the input rate is 192 kHz.
Currently i don't have 192kHz soundcard with ASIO. Only my MAYA44usb wich is 44.1/48 kHz.
At 'radio' on my pc i have juli@.
Strange is that My laptop and my pc are INTELs, both are c2d. On PC all works fine. Even when i have CPU load to 100%, but on lapotp (same card) almost nothing works.
Well i use winamp for input [testing] (direct wire), it plays at 44.1 or 48kHz, If i need 192kHz (FM), i select 192kHz for input.
PostPosted: Thu Feb 03, 2011 11:45 pm
Is CPU throttling turned off on your laptop? Have you checked DPC latency on the laptop?
PostPosted: Thu Feb 03, 2011 11:48 pm
True - ASIO only supports 1 sampling frequency simultaneously. I guess I should do something to make this clear...
PostPosted: Thu Feb 03, 2011 11:50 pm
http://www.stereotool.com/download/radi ... 1-031I.exe
Ok, now this is looking interesting:
- Set this to priority EXPERIMENTAL again
- If you get a warning that the process cannot be set to REALTIME, please use Task Manager to do that!
Priorities are:
- ASIO thread: Should be 31 (confirmed in eldoradofm's post)
- Processing thread: 25
- Processing thread #2 (shorter, includes sending to output): 26
- GUI thread: 22
- Some other thread (window messages?): 24
So now none of these can interfere with the ASIO thread anymore.
I've turned the logging off again to make sure that that doesn't cause clicks.
PostPosted: Thu Feb 03, 2011 11:51 pm
CPU throttling: 10 mins ago i just searched in bios for that, and there is NO option. :evil:
DPC is OK even when ST is running.
PostPosted: Thu Feb 03, 2011 11:55 pm
First test with this version, it seems to do the trick no clicks so far. I'll test some more.
Still no clicks so i think it's fixed for me. This is with buffer of 2,7 ms. When i click restart a few times i can see the buffer flickering more, but no clicks anymore.
Edit: I now got 1 click when i started the CPU torture test. I'll set the buffer to 2.8ms now and test some more.
Also with 2.8 ms 1 click when i start CPU torture test.
PostPosted: Fri Feb 04, 2011 12:00 am
OMG.. This is NEW, and only is like that at my laptop...
I just can't lower under 109ms for normal out (asio).. BUT...
When i lower BOTH FM output and LowQuality output to minimum (both are OFF) now i have 3,7ms :shock:
PostPosted: Fri Feb 04, 2011 12:15 am
Must wait till tomorrow to test that last beta on AMD and Juli@
PostPosted: Fri Feb 04, 2011 12:23 am
You probably need to increase it by 1 ASIO grain (1.33 ms?). I think I should update the ASIO buffer configuration to match whole grains.
By the way, this CPU torture test - I suppose it's not running at priority REALTIME? Because if it is, there are no safe settings to avoid this.
I'm going to add this to my todo list:
- Change buffer size configuration to match whole ASIO grains (probably only displaying them)
- Fix different priority settings (GUI back to normal prio)
- Allow setting Realtime priority on Vista (if possible, Admin rights?)
PostPosted: Fri Feb 04, 2011 12:43 am
I still heard a very soft click with 4.0 ms. I think it's totally fixed with 5.4 ms.
Edit: did some testing with Asio granularity of 128. When changing the buffer the whole system crashed and rebooted.
