Post new topic  Reply to topic  [ 707 posts ]  Go to page Previous 161 62 63 64 6571 Next
PostPosted: Mon Aug 28, 2023 9:59 am
I have doubts, even one that I have consulted for a long time and I have not had an answer (Maybe it is a bug).
1. What is the difference between the first and second option of "Before Multibands" in the Equalizer section? (Bug?)
2. Why in the "Noise Gate" section is it not possible to adjust the bands or to know which bands the Gate control works?
Best regards.-
1 - There is no difference, there were 2 places in the past with different names but they both did the same thing. Just ignore that it's there twice...
2 - The Noise Gate (and also Stereo Boost) is still based on the multiband design from Stereo Tool 1.00)! We have never really had a reason to update it. But that old multiband didn't have adjustable bands; each band is 1 octave.
PostPosted: Mon Aug 28, 2023 10:18 am
can it be true that a custom present that I have saved in version 9.92 cannot be loaded via "presents"? I don't see "select settings to load" when I want to load my present.
If so, that might be a bug. I assume you imported it and nothing shows up to select?/ Then please send me that preset so I can check what's wrong on my end.
i send you a PM
Ok, I checked it. This version was saved with an intermediate beta version from this forum thread, not with version 9.92. There were 1 or 2 versions that saved presets in a slighly different way.
If you still want to load this preset, open the .sts file and search for [Preset info] - remove all the "Contains" lines below that.
PostPosted: Mon Aug 28, 2023 3:19 pm
It works now
PostPosted: Tue Aug 29, 2023 3:42 am
Thank you Hans.
PostPosted: Tue Aug 29, 2023 2:34 pm
Can we get the ITU meter showing all the time in the Web GUI? Currently, on my Android 13 in chrome, expanding the scopes shows the ITU, but they're broken. This essentially freezes the webpage and meters, only allowing you to see what the ITU was showing the moment you pressed the expansion button.
Since making the scopes visible has a propensity to freeze it, can we get the ITU showing at all times on the Home/Processing/Clipper pages in the interim until this is solved? Enabling scopes to see the LUFS seems like overkill on these pages.
PostPosted: Tue Aug 29, 2023 7:11 pm
Now in the latest betas since 092 (092 works fine), everything to do with presets doesn't seem to be there for the screen reader I'm using in the web interface, previously it waas just saving/loading that wwas missing, now it's everything. Was that turned off for screen readers by mistake?
The web interface has no other changes in the past month or two that I can find. Linux cmd version.
I still see no changes and the preset features weren't put back for screen readers. Maybe by the stable version.
Sorry for bringing this up again, but now I want all these new features LOL.
Still no preset options with screen readers in this version for the web UI.
https://www.stereotool.com/download/ste ... TA1002-105
PostPosted: Tue Aug 29, 2023 8:26 pm
Heya. I think I read something in Discord about Tom working on the preset manager for the web UI, and attempting to update it to the more modular version the GUI proper has. I assume working on making the older one work for readers before implementing the new saving/loading features would be a waste of effort if they would have to go in and do it again afterward. I'm sure folks with low vision haven't been forgotten, and that a working interface for screenreaders is on the way. I'm sorry you've had to wait so long.
PostPosted: Wed Aug 30, 2023 12:12 pm
Thanks!
PostPosted: Wed Aug 30, 2023 2:38 pm
In the Stereo Tool - VST2 32-bit version I cannot choose the compressor type under miscellaneous. And yes I have selected show deprecated settings under application settings.
PostPosted: Wed Aug 30, 2023 4:46 pm
Weird, I just tested this in Reaper and it worked fine. Does it work on the standalone? Have you tried another host? What host do you use?
