Vortan, can you check the coy load when this happens? That would be my first guess. The cpu usage of the declipper is higher when there is more clipping!
What do you mean with "coy load"? It happens whithout declipper, without dynamic booster, without bass boost, without agc, without multiband clipping, without final limiter..... it is just there. Sometimes it appears after 1 minute, sometimes after 2 or 3 minutes, depending on the song which is playing. I tried to hear which "form of music" could force these interrupts, but it happens with jazz or pop as well as metal. I noticed different cpu core using, beta 46 for example was running on the 3. core with only 10%, actual betas running on 1. and 4. core, a song switch does overall load increase to 30%, mainly on the 4. core.
