Post new topic  Reply to topic  [ 719 posts ]  Go to page Previous 161 62 63 64 6572 Next
PostPosted: Thu Feb 03, 2011 7:17 pm
Hm, surprising that that code is there. I still expect the code to run the same on an AMD though, because when I removed the 'generic' path from the executable it shrunk about 20% in size - so there shouldn't be a generic path. Also, any manually optimized SSE2 code is definitely in there (because I used #ifdef 's for that).
Having said that, the result of a test with this check bypassed (as you were looking for) would definitely be very interesting. Just to make sure.
The code runs, but the compiler may still be doing some trickery behind the scenes.
I have not had a chance to really scour Google for the W option. It gives the impression that it would give the same machine code to AMD, but I dunno...
What version of the compiler do you have? Also, you indicated you're using IPP 5.x for SSE and 6.x for SSE2? One other way this can sneak in on you is when the compiler links in IPP.
Have you ever tried a /QaxW /QxO compile? For that matter, /QaxW /QxN ?
AMD's SSE2 is identical to Intel's with the exception of HyperThreading support, so if code compiled with N will run on an AMD, then it should be compatible. Could just make a test version to see...and if it falls flat, then never mind that route...
PostPosted: Thu Feb 03, 2011 7:48 pm
I have had the problem with the clicking sound using ASIO ...one way to get around this is to wait until the clicks start....then open the ASIO windows on the task bar ( you know the one with the green play icon) click on it once & open it and then close it.... the sound will stop for harf a sec and the clicks will be gone.. its the only way I know how to get it stop..BUT i don't know if it will be the same for all computers/laptops...
( just a thought )
PostPosted: Thu Feb 03, 2011 9:25 pm
Hans, you gonna love this....
The 3 files are: PrimeSSE3Intel(/Qx:SSE3), PrimeSSE3Generic(/arch:SSE3) and the 3rd(PrimeSSE3Altered) is patched PrimeSSE3Intel !
Tell you more: Patched Stereo Tool and now 5ms buffer , 128 samples latency(44.1KHz), Normal Output, Normal Priority in VM. No drops!
So how did you patch it? And is the CPU load also lower?
PostPosted: Thu Feb 03, 2011 9:27 pm
No... I don't even have such an icon :roll:
This is driver specific, and the fact that it works might just be a coincidence.
PostPosted: Thu Feb 03, 2011 9:45 pm
Here's a version with the priorities I mentioned a few posts ago:
- PROCESS at High, which makes (I hope...)
- ASIO @ normal priority run at '13'
- Processing @ below_normal priority run at '12'
- GUI @ lowest priority run at '11'
http://www.stereotool.com/download/radi ... gging2.exe
Note: This file still contains logging - if something is wrong I'll probably need that again...
SET PRIORITY TO "EXPERIMENTAL" FOR TESTING!
I see that the 'dynamic priorities' are raised above the configured priorities, which might still cause issues. If this version still does not work properly, I'll try what happens if I turn that off.
Edit: If you still hear clicks and pops, could you install Process Explorer and check the priorities of all the threads? (ASIO thread is especially interesting)
PostPosted: Thu Feb 03, 2011 10:48 pm
I'm still getting clicks.
Tested again with BBP Asio when i don't select Audio Realtime Priority i also get clicks with BBP Asio.
With BBP Asio when i don't select Audio Realtime Priority, the Base and Dynamic Priority for JulaAsio.dll = 15.
With BBP Asio when i select Audio Realtime Priority, the Base and Dynamic Priority for JulaAsio.dll = 31.
Note there are 2 processes when i select Audio Realtime Priority with BBP.
With version 31H Logging2, JulaAsio.dll = 15. Base and Dynamic.
ox44baa = Base 12, Dynamic 12,13,15
ox9982 = Base 12, Dynamic 12,13
0x2d3c8 = Base 11, Dynamic 11,12,14
0xbbbfb = Base 13, Dynamic 13, 15
0x6243e = Base 13, Dynamic 13, 15
wdmaud.drv = 15
ntldll.dll = 13
mswsock.dll = 14
ADVAPI32 = 13
With version 31H Logging, JulaAsio.dll = 31. Base and Dynamic.
ox44baa = 31
ox9982 = 31
0x2d3c8 = 24
0xbbbfb = 24
0x6243e = 24
wdmaud.drv = 31
ntldll.dll = 24
mswsock.dll = 25
ADVAPI32.dll = 24
PostPosted: Thu Feb 03, 2011 11:27 pm
Ah! Logging 3 coming up :-)
PostPosted: Thu Feb 03, 2011 11:28 pm
Does my log halps?
btw, at my laptop i have problems to set buffer size under 100ms sometimes i can set under 120ms 48kHz/48 samples/normal output.
PostPosted: Thu Feb 03, 2011 11:35 pm
@Bojcha: I am curious, are you able to get 192kHz output when using 48kHz(or any other) input rate with ASIO enabled? When I enable ASIO I can only get 192 kHz out when the input rate is 192 kHz.
J0HN II
PostPosted: Thu Feb 03, 2011 11:38 pm
Does my log halps?
Yes, sorry, I had posted a reply but it didn't show up (?).
Anyway, it shows that there are hiccups approx. every 32 'grains'. And 32 asio grains = 32*256/4 = 2048 samples, which is exactly the number of samples between successive calls to the processing thread.
