I'm online again
Saw Greenland from the air (wow!), walked around in Philadelphia and ate in Chinatown this afternoon and now I'm in Las Vegas, so I hope you understand that I won't be developing much this week
So, some answers:
1. Pilot and RDS are NOT clipped and should not be affected by the composite clipper
2. I also see that sometimes there's some 'noise' or something that causes some "dirt" in the spectrum. Not sure what it is yet, but it's definitely not intentional. First guess: The limiter doesn't limit enough at some point, causing the output to be slightly too loud and be 'hard clipped'. Not really something to worry about: The level is extremely low (around -80/-90 dB), so I think you'll never get reception that's good enough to be able to even measure it.
3. Unless I'm mistaking (I hope not), adding SSB should be very very simple now. I could probably do it in a few hours. Maybe on my flight back
. Multicore support will be harder to add for this though... (So it's probably a good idea to add SSB first, to not get into trouble later).
4. I found a bug: Each time I run Stereo Tool (DSP plugin, so the audio/pilot/RDS should all start at the same point every time) with the composite clipper enabled, the output is different. That's bad. It doesn't happen with "Multicore" disabled! This may be related to a bug that Bojcha noticed: Sometimes the channels get swapped.
