Post new topic  Reply to topic  [ 752 posts ]  Go to page Previous 15 6 7 8 976 Next
PostPosted: Sat Aug 25, 2012 12:54 am
Some more changes:
- Everything is now by default not collapsed (you can still collapse things if you want)
- IE layout is better than before, but still not what it should be (every section starts at a new line, and that's not the case in FireFox and Chrome). I think it's acceptable for now.
http://www.stereotool.com/download/ster ... 33-010.exe
http://www.stereotool.com/download/dsp_ ... 33-010.exe
PostPosted: Mon Aug 27, 2012 12:26 pm
It doesn't look good (needs styling), but this looks a lot more organized:
PostPosted: Mon Aug 27, 2012 5:23 pm
And there it is!
Whole HTML UI ordering has been redesigned using vertical blocks with buttons and sliders, things should be more logical than before.
http://www.stereotool.com/download/ster ... 33-011.exe
It doesn't look too good yet - I need to figure out a way to define the edges of these new boxes.
Works in FF and Chrome, IE behavior is acceptable (boxes are not completely drawn for some reason).
Edit: Sound cards section isn't ok yet. Will fix that asap.
PostPosted: Tue Aug 28, 2012 1:13 am
I don't know if the Sound Cards section looks the same in all browsers, but that's how it looks in Opera 12.01 x64:
PostPosted: Tue Aug 28, 2012 1:57 am
We should all be using Google Chrome. It's by far the best browser out now. It's updated regularly, and is compatible with everything. OPERA is nice, but you can just download CHROME and import your stuff. Simple, and you'll be greatful. The speed is great, and the plugins are top notch, but I guess its a good thing to test this on all browsers. :)
-n4-
PostPosted: Tue Aug 28, 2012 2:20 am
Yeah, I will use Chrome, and let Google know about every single thing I do in the web... No way, I will stay using Opera.
PostPosted: Tue Aug 28, 2012 2:34 am
You can always be Signed Out :)
PostPosted: Tue Aug 28, 2012 2:52 am
Same feeling here (but I'm using it anyway because it works very well - I guess I should check Chromium).
About the sound cards: I know, I forgot them (I was working with the command line version because that's the fastest to start - but sound cards are not included there!)
TODO's:
- Make buttons and sliders much smaller. Eventually every filter should fit on an 800x600 display, WITH other things around it. (I will enable horizontal scrolling - but vertically it MUST fit).
- Fix sound card pull-down menu's etc.
- Place things in separate screens. But I might do that later for the HTML interface. At some point I need to start working on the built-in GUI, I might do that first.
PostPosted: Tue Aug 28, 2012 11:22 pm
Fixed Sound cards section display
Fixed Sound cards - can now be changed from the HTML interface as well
Added 'Small buttons' display (click checkbox under the skin box, then press RELOAD).
I want to implement the internal GUI now, that means that this will be the last working version for the coming time...
Stand alone: http://www.stereotool.com/download/ster ... 33-012.exe
Winamp: http://www.stereotool.com/download/dsp_ ... 33-012.exe
PostPosted: Thu Aug 30, 2012 12:12 am
"blue" skin is updated - "http://85.25.73.243/stereotool_skin_b2/"
put that line without quotes in "Skin URL" and pres enter while there, and refresh browser
Tell me if i need to make some changes.
