Post new topic  Reply to topic  [ 112 posts ]  Go to page Previous 15 6 7 8 912 Next
PostPosted: Tue Nov 05, 2024 1:44 pm
Yes, for the preset Chaotic from Bojcha (something with pre-emphasis/relative stop thresh).
I personally don't like to install betas - cause there is always chance that it's bugged (or doesn't work at all like 032 DSP :D )
While that's an excellent reason not to use the betas in a live environment, one can always download a standalone version and export/import the preset manually. It might not always sound correct on an older version or be finalized and ready for release when taking from betas, however. I would upload the preset myself, but it might not be the final version, and I don't want to misrepresent the sound.
PostPosted: Tue Nov 05, 2024 4:28 pm
Everything seems to be working now, and I hope that people will like that streaming from the DSP plugin is now actually functional - I thought it was before and that the fact that it often didn't work was caused by collisions with the host applicaton, but there was an actual bug in the code that made it often fail. That also means that it should be possible to do the same with the VST plugins (but that's for later). New build tonight!
PostPosted: Wed Nov 06, 2024 2:38 pm
BETA033 with these fixes is posted.
PostPosted: Thu Nov 07, 2024 4:49 am
Another request to please finish the declipper plugin, adding the azimuth correction, noise reducer, and missing meters/displays. Should be a quick fix, to copy/paste some sections of code. (I actually have no idea how the code works on this..)
Thanks so much!
PostPosted: Sat Nov 09, 2024 3:12 pm
Any idea where the button has gone to login/logout/lock of the interface?
PostPosted: Sat Nov 09, 2024 3:30 pm
The 64-bit Windows installer is flagged by Microsoft Defender for Endpoint as a Bearfoos malware, see the picture for more information.
It seems that it is detected by machine learning, so ofcourse a false positive. But if you get any questions from users, you know what could be the issue.
PostPosted: Mon Nov 11, 2024 7:11 am
Hi Hans:
Any way to know what time this error occurred? If it does not exist, there should be a possibility that the error notification time will appear.
Best regards.-
PostPosted: Sun Dec 01, 2024 12:52 am
vst_stereo_tool_64_BETA1042-039.vst3 is not scanning/validating here in Reaper, Magix Sequoia, or PluginDoctor.
1041 VST3 is loading fine.
Apol's if this is a known issue, I searched but didn't read anything.
PostPosted: Mon Dec 02, 2024 12:13 am
Ah, I'm also noticing this in Reaper. The VST2x64 seems fine though.
Thanks for letting me know about PluginDoctor. I gotta get this!
PostPosted: Mon Dec 02, 2024 4:28 am
Yes VST2x64 is fine.
PluginDoctor: it's useful, but can be a pandora's box!
Oh, just realized 1041 VST3x64 is not passing signal at all in any host, though it scans ok. Is general advice here to stay a few feet back from the bleeding edge? (new-ish user),
