I know you folks are busy on adding/refining features and rebuilding entire modules, but window sizing is still broken using Breakaway One, in both the VST declipper 3.02 beta and Stereo Tool. The latest release of Perfect Declipper (3.01) however appears the correct size (so I didn't feel the need to include an image).
In Stereo Tool (currently using the latest beta) one has to choose to display in fullscreen mode for it to adjust to the window appropriately. In the Declipper there's no option for fullscreen mode. I don't know what's causing it, but it would be nice if Fullscreen Mode setting was saved. I also don't know which version of Stereo Tool this started happening in, because as far as I can remember, it's always been like this.
Oh, sometimes if you launch it, and it's messed up, then you click in the grey area to the left as your very first click/action, it'll re-fill the window appropriately. I don't know if that's a clue.
File comment: Fullscreen mode disabled
File comment: Fullscreen mode enabled
File comment: Fullscreen mode not an option
edit: More odd behavior. When maximizing the window while fullscreen is on, this is what you get until you disable then re-enable fullscreen mode. I cannot add more pictures, but it's basically the fullscreen enabled image with the white background of the declipper image.
