Post new topic  Reply to topic  [ 239 posts ]  Go to page Previous 15 6 7 8 924 Next
 Post subject: Re: StudioOne HD
PostPosted: Tue Dec 29, 2020 9:27 am
Thank you very much, Bojcha. Testing in my station... :lol: :lol: :lol:
Happy year to you.
https://fmfeeling.com
PostPosted: Tue Dec 29, 2020 4:53 pm
Thank you for the latest preset. Can you also post a FM version?
PostPosted: Tue Dec 29, 2020 6:07 pm
I am just looking at FM version, will post soon. It will not be loudness war candidate but it will be super clean.
PostPosted: Tue Dec 29, 2020 8:09 pm
Great!!!
PostPosted: Wed Dec 30, 2020 2:14 am
FM preset added.
PostPosted: Wed Dec 30, 2020 5:20 pm
As always, fantastic work, sir! Thank you and Happy New Year!
 Post subject: Re: StudioOne HD / FM
PostPosted: Thu Dec 31, 2020 5:14 am
To make this less loud, do we adjust the output level on MB2 as before? I'm looking to use this on a 70s based soft rock station. Music is not overly compressed.
Also, for streaming, I'm assuming that listeners are equalizing the music to their preferences, so I often don't use the ST EQ while broadcasting. Am I causing any issues with other settings in ST by doing this?
PostPosted: Thu Dec 31, 2020 11:46 am
The 'default' version does not use EQ at all, it's very neutral preset.
To make it less loud reduce 'output' in MB1 or 'drive' in MB2, it's same.
PostPosted: Thu Dec 31, 2020 11:57 am
Hi Bojcha, I haven't had a chance to listen to the update yet, but can you tell us what's different from the version included in Stereo Tool? What has been upgraded? In other terms, why should I use the new version? I'm sure it sounds good, looking forward to trying it!
PostPosted: Thu Dec 31, 2020 12:13 pm
Biggest difference is new dynamics in MB, gating thresh and gate RTP. That thing works nice. Idk why it uses so much CPU tho. Also idk why that is special license, it's just what most compressors use even simple hardware ones, like 286A for example.
Many other fine tunes in every corner.
