Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 758 posts ]  Go to page Previous 15 6 7 8 976 Next
PostPosted: Mon Dec 18, 2017 9:45 am
heheheh!
I just fixed it :)
again everything from scratch.
i was indeed like a toilet tube .
http://stream.grap.gr/1045fm
PostPosted: Mon Dec 18, 2017 11:06 am
I see this thread becaomes a "preset" discussion.
Can you please go to the PRESET section with your stuff and discuss it there.
Here is a beta development thread
PostPosted: Mon Dec 18, 2017 5:15 pm
Hi DJ-DOGGY, how are you? Do you remember me? :mrgreen:
PostPosted: Mon Dec 18, 2017 11:43 pm
GUI Exception... See pic
Were you doing something (adjusting settings?) or did it just happen with no apparent reason? (The numbers point to the first MB compressor, so it must be caused there or before it).
HVZ, just loaded a preset... I'll PM you the preset over. Just had it happen again (now twice in 2 days). it recovered. Are playing in MB1, see the profile...
PostPosted: Tue Dec 19, 2017 12:40 am
So did it happen when loading the preset, or while it was just running? If you want even the slightest chance that I can reproduce it I need to know *exactly* how it happened, because obviously I'm not seeing it here, otherwise I would have fixed it already.
PostPosted: Tue Dec 19, 2017 3:33 am
Happened about 1/2 sec after loading the profile. From memory, a few frames of audio started.
I will keep a closer eye on this if this happens again and report.
PostPosted: Tue Dec 19, 2017 12:21 pm
heheheh!
I just fixed it :)
Now it's a Sink Tube, A Clogged one! And stop geoblocking everyone outside of Greece, please.
PostPosted: Sun Dec 24, 2017 1:53 am
In case you're wondering what's taking so long, I'm working on a 4K version of the GUI.
PostPosted: Sun Dec 24, 2017 5:44 pm
!! Unregistered option(s) in use !!
Looks like you need to buy a license from yourself, HAH!
Best to you.
PostPosted: Sun Dec 24, 2017 6:30 pm
why is not it time for a completely new UI? or should it cost no money??!! :lol:
Garbage in is Garbage out !
