Instant mute = radio seems to switch off for a moment - entire bass is gone? Or do you get really bad distortion?
- Could it be that something (sound card, transmitter, something else) is sending out the bass too loud? Or maybe that the overall volume going into the transmitter is too loud? (In other words: Is it solved if you lower the total output level a bit)
- It might be interesting to hear what happens if you enable the 'Stereo Image' processor, set everything at default levels (so it does nothing), and then set a phase shift of 180 degrees.
Its an instand mute... not disortion or very loud volume... just an instand pause for less than second.
I think its a unique low frequency that causes... but i have nt found yet..
My Stereo image is on without Phase shift.
Anyway... its not a big deal... but its strange...!
