Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 155 56 57 58 59
PostPosted: Sun Jun 19, 2016 9:34 pm
Hmmm
I can't come here everyday and i'm get lost with some new features.
What is "LW"?
Thanks
PostPosted: Sun Jun 19, 2016 9:45 pm
BUG REPORT
GUI -> uses 100% of the selected thread when inside the FM Transmitter tab.
Is that new? I haven't changed anything on that page, as far as I know!
I honestly don't know. But it seems that the something is wrong with the scope. When i enter that page it start to chop the waveform .
My radio station
http://amradio.ddns.net
PostPosted: Sun Jun 19, 2016 10:08 pm
BUG REPORT
Ah! Well, that's not new - the problem is that there are 2 views of the same scope on the screen and they are interfering with each other.
PostPosted: Mon Jun 20, 2016 2:29 am
Hello.
When batch process files in Wavelab 6 I get this error:
I'm seeing problems in Audition now too. It's probably a stack overflow, if I reduce the compiler optimization level it works fine (but I obviously don't want to do that). Now testing if I can get it to use different settings for the parameter code, which is where I expect the problem lies...
Edit: Appears to be fixed now, I just need to lower the optimization level of the parameter handling code.
PostPosted: Mon Jun 20, 2016 9:53 am
But this could be a killer on 2 core cpu's because it hangs the thread. (once i open that tab boom 100% core utilization)
My radio station
PostPosted: Mon Jun 20, 2016 7:42 pm
Hello.
Forgiveness for slow to respond.
So far it used 7.83 and worked well.
  I tried the beta version of 7.85 -70 then came error.
When first loaded the plugin is blocking Wavelab and windows closed the program. The same happened with the beta 7.85 -80.
Only processes the first file and then fails.
Pretty Girls in your city
