Since my attempts at discussing the CPU load for older systems have been very unfruitful, I have a question for you, and Hans, Bojcha, and anyone else that wants to comment.
Just to let you know: The new MB is partially optimized (as I think you confirmed at some point), but the things that have been added since have not really been optimized yet. Basically there are now 2 implementations: A simple one (default settings, no burst protection) and a more elaborate one (also non-default settings (not accessible in the MB), combined with burst protection). Also, adding flat frequency response adds extra CPU load.
I will probably either remove those non-standard things later on (if no-one needs them), or add an extra code path with burst protection and default settings.
Question for everyone, although mainly for Hans: Is there a diminishing return point for this setting, similar to the "Strictness (CPU)" setting in Advanced Clipper? If so, what do you think that point is, and can it be established as a default?
You never used this thing?! Ow.... Well, this depends on the latency. At latency 512 or 1024, you should really stay as close as possible to 100%. Basically, you can see it like this: Quality 50% at latency 4096 still outperforms quality 100% at latency 2048. I'm not lowering the defaults because I don't want to compromise the quality if it's not necessary, but I would say that at latency 4096 you can safely drop the quality slider to 50-70%. (In fact, in version 5.00 70% was the default, but as PC's got faster and the total audio quality improved I changed it to 100%).
