BETA101 is posted! Biggest change is that the sudden drop behavior is completely different; the old behavior responded with a delay and could then seem to suddenly increase the level. The new behavior responds quickly at the start and then fades out.
For those complaining about a "wimpy" sound specifically on FM: Please try if what you hear disappears if you disable "Advanced Bass Distortion Protection". That will make the whole sound a lot more punchy. With the old compressor, there wasn't enough control of the bass to run without this - well you can, but it causes a lot of intermodulation distotion - the bass causes havoc in the mids and highs. I haven't tried, but the new compressor has much better control of the levels, so it might be possible to disable it if you carefully tweak the Intellilimiter. I'm planning to have another look at the clipper later - we first need to finish the new compressor.
I was talking about non-FM personality. Am not sure about other peoples.
If I have Intellilimiter on 6db (because I cannot go lower) and a 2-millisecond attack, the bass will output super high to the clipper which results in it sounding terrible with "advanced bass distortion protection off".
I found that switching to a preset changes the action of the multiband compressor. It also afterwards doesn't allow me to change the "compressor type"
My head hurts. My ears are broken. is there a thing like an audiologist for compression?
It just sounds terrible. It almost pushed down in the water and crackly. ;(
Look here is my preset. What is wrong with it
Apparently your CPU is BAD.
Just kidding, ofc not.
What happens when you load my preset? I also seems to have BAD cpu, so we are matched. Load only
