Still waiting for the ASCII connection by MagicRDS to support AF Method A.
Any thoughts on that? I see no reason why the B Method was on the list.
Please Hans?
Do you dynamically update the list from MagicRDS? I'm asking because if not, it would work just as well if you just set it in Stereo Tool directly. And I don't think it's usually a good idea to change it dynamically (AF method B was created for dynamic switching behavior).
Well, I want MagicRDS to disable the AF functionality when playing regional advert breaks. I see no other option to do this through AF Method A.
I'm not familiar with the Method B, but MagicRDS uses the ASCII method for communication with StereoTool, and the UECP is not working, and I think the AF commands are not implemented/understood with ASCII in StereoTool.
