Post new topic  Reply to topic  [ 749 posts ]  Go to page Previous 155 56 57 58 5975 Next
PostPosted: Sun Mar 21, 2010 5:16 am
hvz.. do you have a Skype address of anything that i can get in contact with you on the fly.
cos if so i can add you to my contact list.
if you have a Skype address just email me it.... nigel.russell1342@btinternet.com
PostPosted: Sun Mar 21, 2010 5:33 am
Re-uploaded BETA3 Winamp plugin and Stand Alone versions. Stereo Image (Hardrock preset) should be fine now.
I'll upload the rest (VST versions) tomorrow.
DUB<^>STEP: Will send you a PM tomorrow.
PostPosted: Sun Mar 21, 2010 5:42 am
I have downloaded the beta3.. and it is now working. rock pre-set works and were the dB reading under post amp and pre amp are ok.
pre-limiter and multi-band compressor is working to.. ill report back if I get eneymore problems... and ill check my private messages, when I get back to.
PostPosted: Sun Mar 21, 2010 6:45 am
:!: :!: :!: found another small bug in the stereo imager . :!: :!: :!:
if you turn on stereo boost ( 1990 style ) when using ( hard rock ) pre-set you end up with bad stutter and you can't get out of it .. you have to restart winamp to stop it.
found that one when I was playing with things. try it yourself you'll see what I mean. ( use the hardrock pre-set and turn on the stereo boost ( 1990 style ) it shud stutter badly and crash winamp when you try and get out of it )
the default hardrock pre-set you made works fine.
its not just limited to hardrock some others do the same thing when you enable stereo boost ( 1990 style ) its certain combination's that triggers it.
PostPosted: Sun Mar 21, 2010 12:41 pm
Found it, building a fix now.
PostPosted: Sun Mar 21, 2010 1:39 pm
Fix uploaded as BETA3.
PostPosted: Sun Mar 21, 2010 2:20 pm
Second AGC band can again go lower then first ?
PostPosted: Sun Mar 21, 2010 2:30 pm
Are you sure that you have the latest version (not a version that was cached in your browser for example?). I checked it here, and here the highs cannot get lower than the lows.
The installer of the stand alone version is 870.188 bytes. After installation, the stand alone .EXE file should be 2.117.632 bytes.
EDIT: Oops, I wrote BETA3A - but that should be BETA3! BETA3A is still an old version! Sorry........
PostPosted: Sun Mar 21, 2010 2:37 pm
:) np
PostPosted: Sun Mar 21, 2010 5:22 pm
hvz look in your pm/s
