Post new topic  Reply to topic  [ 2125 posts ]  Go to page Previous 155 56 57 58 59213 Next
PostPosted: Tue May 31, 2011 4:35 pm
This is *VERY* interesting. If I disable the AGC and only use Natural Dynamics and Multiband, there's no big difference in output level if I turn Natural Dynamics on or off. So... This REALLY means that I need to use the unprocessed audio as AGC input.
Will create a new version ASAP.
Edit: Not that soon though... This is a bit tricky: Currently I'm performing Natural Dynamics directly at the input signal (after declipping and noise gate). The AGC is done AFTER Stereo Boost (which makes sense: If Stereo Boost makes the audio louder, you want the AGC to lower it more).
So now I have 3 choices:
1. Ignore Stereo Boost for the AGC. Not a good idea.
2. Perform Stereo Boost (and AZIMUTH, ...) on both the original and the Natural Dynamics signal. Big CPU load impact.
3. Perform Natural Dynamics on the audio after Stereo Boost. I'm not sure what that will do - actually it might even be better...
I'll go for option 3 for now.
PostPosted: Tue May 31, 2011 6:56 pm
"up push strength near minimum reduction" in AGC is not included for 3rd AGC band (?)
PostPosted: Tue May 31, 2011 11:27 pm
Will you add the sliders to stand alone again in next beta?
PostPosted: Wed Jun 01, 2011 1:18 am
BETA050:
- Natural Dynamics can now be placed before or after AGC
From the previous beta (still valid):
The CPU load is also pretty high because I'm calculating 32 different tilt levels to find the best match (so automatic tilt detection works, but it needs serious optimization).
New slider: "Declipping margin" - if you set this to 75%, everything above 75% of the maximum level is considered to be potentially clipped.
Changed slider: "Never consider samples to be clipped if they are lower than:" - rule out soft sounds, whatever they look like, they are not clipped.
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 20-050.exe
Stand alone version: http://www.stereotool.com/download/ster ... 20-050.exe
VST version: http://www.stereotool.com/download/vst_ ... 20-050.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 20-050.dll
Command line version: http://www.stereotool.com/download/ster ... 20-050.exe
Linux command line version: http://www.stereotool.com/download/ster ... ETA620-050 NOT AVAILABLE
Linux GUI version: http://www.stereotool.com/download/ster ... ETA620-050 NOT AVAILABLE
- Fix Punch
- Fix crash at program close
- Dynamically drop 'Allow louder highs, even if it causes vibrations' to 0 when bass filter suspects noticeable voice vibrations. 1-2 hours
- Reduce Loudness CPU load days?
- Finish new de-essing filter (check what to do with the settings, remove at least some!) 1 day
- RDS issue reported here: viewtopic.php?f=15&t=3703&p=11524#p11524
- Finish declipping filter (clipping level detection + level reduction in dB). 1. Figure out why removal of unwanted frequencies causes flat lines at high quality setting with small overlap. This causes distortion, with this fixed repairs are MUCH better. 2. Implement MP3 correction, automatically scale down when this deteriorates the sound.
- Finish blind interface
- Add AGC start level
- Channels L/R swap in stand alone version when changing filtering/quality (?) (eldoradofm)
- Move pre-emphasis to end of processing 1 day
- Release 1 hour
PostPosted: Wed Jun 01, 2011 1:28 am
I count 9 bands in dynamics filter why not the 10 like in multiband?
PostPosted: Wed Jun 01, 2011 1:59 am
How are the Natural Dynamics connected when i select After AGC ?
Because i don't hear more boost when the AGC is going up when i lower the sound.
Or are the dynamics added after the AGC and then always using the sound from before the AGC? Then it's better to change name in Add dynamics after AGC.
PostPosted: Wed Jun 01, 2011 2:10 am
There doesn't seem to be a need for 10 bands - the lowest few can be combined without quality issues. At least that's my impression...
Edit: I just compared the sound processing freakday mix with and without Natural Dynamics (settings: Max input level 100 000; Effect multiplier: 2.00 x), with Bojcha's B_Town11_FM4 preset, AGC Target output level lowered to 20.00.
Every track comes out either (nearly) unchanged or better. So this is really helping, also with processing enabled! (although the effect without any processing is MUCH bigger)
PostPosted: Wed Jun 01, 2011 3:50 am
I found yet another feature that I can use to determine whether clipping occurs or not. It seems to detect about 99% of real clipping (so some softer clipping won't be restored anymore), but if no clipping is present it indicates less than 50%. So I'll add an option to disable clipping when this filter says that no clipping is present.
(I can hear a slight deterioration in the 'extreme_clipped' sample, however in real world input where a lot of samples are incorrectly considered to be clipped I expect an improvement from this filter).
Note: This filter won't help in case of (volume) compressed audio - so modern tracks like Jack Is Back don't improve at all. However if you're playing 60's, 70's or 80's tracks (not recently remastered ones...) I expect this filter to work very well.
PostPosted: Wed Jun 01, 2011 4:07 am
And this is much better for Natural Dynamic filter. Checking ..
PostPosted: Wed Jun 01, 2011 5:47 am
Ok.. test ONE:
I've uploaded MPX track where first 01:26 is with Natural Booster OFF and second same 01:26 with Natural.Booster ON. Not default settings at all! -- Damn, sun is up. 8-)
http://www66.zippyshare.com/v/65454933/file.html
Any difference?
