Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 758 posts ]  Go to page Previous 155 56 57 58 5976 Next
PostPosted: Mon Apr 30, 2018 4:15 pm
The first time I noticed was with beta 51.
PostPosted: Thu May 03, 2018 2:49 am
Stereo Tool 9.00 BETA065
NAN CHECKING IS ENABLED IN THIS VERSION
Windows stand alone: http://www.stereotool.com/download/ster ... 00-065.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 00-065.exe
VST: http://www.stereotool.com/download/vst_ ... 00-065.dll
- Natural Dynamics was broken in the last beta's. Now again same as in 8.54
- Show better license warning (maybe separate icon per used feature?)
- Added sound card input left/right/stereo selection (specific customer request).
OLDER CHANGES:
- Fixed (enabled) highpass filter pre-ringing protection.
- We should probably put a warning in the next version if the CPU load is high. Done, but window doesn't nicely disappear (others as well probably)
- Start of song Auto EQ/Bass EQ was too soft: Sudden Jump Protection now only acts when a band is being boosted (that wasn't the case before); effect at beginning is nearly completely gone and overall AutoEQ/BassEQ SJP does far less than before, but is not less effective!
- Sound card high frequency correction: Make sure it always works. -> Not in Ignore high frequencies mode!!!!!
- Fix Matt's GUI crash at a specific size
- FM Analyser pilot tilt problem fixed
- AGC PEQ live updates (when editing) didn't work
- Mono audio on Matt's machine - why?? Wait for .sts files. -> Was a wrong setting, FM Analyser was enabled.
- MicroMPX ifdef stuff
- RDS Compressed flag always set regardless of GUI setting (reported - check first) -> Confirmed, initial load is ignored. - Solved, wrongly initialized, ignored first SetCompresson() call.
- Weird effect for asymmetry -> External RDS input turned Asymmetry off!
- lower output L/R peaks when using external RDS - explained by Asymmetry above
- sg doesn't sound right - probably bad hard limiter Wait for Matt to test
- RDS PS= failure on Swed test files - was ignoring size of commands for other receivers
- Fixed preset load error (060)
- NAN logging disabled again
- NAN in equalizer fixed
- New skin
- Fix Basstardizer crash
- Fixed Symmetric Peak
- Max release speed fixed
New AGC mode MORE INFO BELOW!
- RDS: Add PTYN
- RDS: Add timeout for TA
- VST version no 4K
- Backup input - check stereo
- Self test crashes
- Put Bass EQ under license
- Added Basstardizer
- Add low input level warning
- Added ASIO latency setting.
- Redraw when warning disappears automatically, also fixes other switches between modes
- Add left/right channel swap
- Check clean_NAN -> Fixed, array in Delossifier wasn't initialized to 0, caused weird sound when changing Quality > 100% and (incorrectly) reported NAN error.
- Check if MagicRDS ASCII mode still works (report received that it's broken) => Works flawless here... Must be a wrong setting.
- Added MagicRDS AF method A (not tested!)
- Service code didn't print anything to screen due to (probably) Visual Studio .h file changes, solved.
- If the window is too small (which shouldn't be possible to achieve manually, but might still have happened if set to full screen mode), instead of not drawing, we now just draw in part outside of the visible area.
- Add shortcuts for run as a service install/uninstall
- 64 bit ARM ALSA build has Jack dependency - remove.
- Added new (extra) simple bass clipper
- HPF after MB2 causes too loud bass into clipper (after very tightly limiting it - Bojcha) - Should be solved by new bass clipper?
- Rename and deprecate Low CPU settings -> Inverted and named to "Heavy CPU (old), under "Compatibility" header.
- LQLL: Allow 3 threads for HQ mode
- Bass clipper should do something with clipper drive.
- Latest beta doesn't run on XP SP 2 (GetLogicalProcessorInfo can't be located in KERNEL32.dll).
- Rivendell plugin build
- DJB plugin build
- NAS
- Start of song AGC etc behavior. Fixed starting point, for AGC
- Quality > 100% Bypass switching causes buffer filling to move
- Add AM presets
- Add new presets
- Array met frequenties versus levels (dus de uitkomst van Fourier) resultaten naar buiten brengen
- Move bass clipper to a logical spot.
- Combine bass effects in GUI
- Remove Hans/Matt mode from Bass EQ or give local names if there's a reason to keep both.
- Add MME warning
- Swap Bass EQ / True Bass when both set to between MB's.
- SST: Show warnings
- Website rename Products to Buy
- Display settings (Paul T)
- Muziek uploaden
- Use top part for extra displays (declipper, numbers for MPX level etc)
- Kant
- AGC better LKFS (Bojcha)
- Classical preset
- Test NanoPi
- AM streaming output
- Multi-instance version
- AF method B via UECP
- 18 Hz trigger tone
- Declipper check L-R effects
- Reduce extreme stereo
- Check out Butt
- Omnia.9 test/fix logging
- WatchCat website
- Triple stuff
- uMPX 24x2ch interface
- One bass page
- Talk to chip
- 2 jaar
- Fardau
- -24 dB side chain range?
NOTE: Bass EQ
New compressor mode info:
PostPosted: Thu May 03, 2018 12:49 pm
What was broken about Natural Dynamics? Was it completely non working? It sounded OK to me. :?
PostPosted: Thu May 03, 2018 1:04 pm
Yes. It didn't do much. It was adding *some* extra level but not enough. Might have depended on other settings as well (I didn't go that far in checking), but with default settings it was way off.
PostPosted: Thu May 03, 2018 1:19 pm
Noticed high Cpu in Bojcha Dynarider preset and he uses Auto EQ and Natural Dynamics but still uses
the Legacy Agc.Maybe he can chime in and elaborate his reasons.He's always had nice presets.
PostPosted: Thu May 03, 2018 5:12 pm
Is this preset already included in the version? I thought it was experimental in a preliminary stage of development. I can't find it on me in the VST64 Windows version. The last time I downloaded it, the Auto EQ was not yet active, but for how you write it, the legacy AGC. :roll:
PostPosted: Thu May 03, 2018 5:49 pm
It's under FM presets.
PostPosted: Thu May 03, 2018 7:18 pm
Thanks, I found it. There are only a lot of presets now and slowly it gets a bit confusing. Especially since you can't search for it in the field, but always have to go through the long lists.
Your todo list isn't really getting any smaller. How many more points do you want to correct until you finally release the new version? I would like at least the points from user Bojcha to be included, so that the new AGC can be used well.
PostPosted: Thu May 03, 2018 11:33 pm
Very Minor bug:
With just BassEQ selected I get told I am using features that require a license, but hte license page doesn't reflect this.
Yes, one day I'll get a EQ license :)
PostPosted: Fri May 04, 2018 1:11 am
I'm putting more cpu usage usually in Declipper and Clipper.
