Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 154 55 56 57 58 59 Next
PostPosted: Mon Jun 13, 2016 11:31 am
Yes, I know that in theory the reception should be worse.
But those reports came suddenly out of nowhere!
I tested recently in an FM transmitter of a wireless headset (mono), low quality (transmits only 10 meters and just the frequency is occupied by station FM)
"Asymmetry L-R" It does not seem to improve or worsen the reception, although note that sounds stronger (tune with my smartphone)
Next Friday I will go with the car to the site reported and testing.
Then I will comment my results
PostPosted: Tue Jun 14, 2016 12:19 am
Hey Hans,
Its all solved. I forgot to turn the AGC for one of the decks off. But I'm running 7.85 Beta 076, sounding grrrreat! When is the OR (official release) going to be dropped?
So are you saying that the stopping was caused by the AGC's inside SAM?
Anyway, it has been running here for another day without issues. So, if you don't see it anymore either and nobody else complains about it I'm going to 'forget' this one for now.
PostPosted: Tue Jun 14, 2016 6:33 am
Hey Hans,
Hans, that is correct :). All solved. Yes it was the internal AGC in SAM.
-- JE
.::.(())::. Urban Hitz Radio™ USA .::.(())::. The People' Choice for Hip-Hop & R&B!
Listen to Urban Hitz RadioGET A Local or TOLL-FREE Request Line NOW...Only $2 Monthly – StereoTool 7.24:Licensed!
PostPosted: Wed Jun 15, 2016 2:13 am
7.85 BETA079
Windows stand alone: http://www.stereotool.com/download/ster ... 85-079.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-079.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-079.dll
LINUX 32 bit:
Linux stand alone: http://www.stereotool.com/download/ster ... ETA785-079
Linux command line: http://www.stereotool.com/download/ster ... ETA785-079
Note: The Linux version is no longer using the big (and at least on Mac unstable) wxWidgets library. Most features should work now.
Known issues:
- Window position and size is not retained after restart
- Embedded windows (certain plug-in types) not yet supported, but there is no Linux plugin yet so that doesn't really matter.
CHANGED:
- Get rid of wxWidgets for Linux
- Get rid of wxWidgets for Mac Mathijs
Mathijs - Crash at N1 in version with MicroMPX
- Delossifier: Lay Down breaks Delossifier, sounds really bad with MP3 detection turned off! (And it's not MP3). More accurate detection (smooth rolloff??) still needed, to also not detect it when not using Detect MPEG mode! Does Alternative Method sound better now?? Also try without HACK. --> Seems ok now. Add extra steep drop check. -> Solved good enough for now.
- Hanegraaf: Check RTAS en andere berschrijvingen
- Latency 9sg checken
- SAM problem - viewtopic.php?f=14&t=7262&p=34903#p34903 -> Was internal SAM problem, apparently
- Delossifier on and no MP3 input disabled Absolute Highs in Follow Delossifier mode. Is that ok? -> No, should fall back to normal HPF determination but that's not there yet... So postpone for now.
- Delossifier: Disable Alternative reconstruction mode for now? (Fix it later, see LATER).
- uMPX decoder crackle
- uMPX crash on repeated closing.
- Delossifier: Make slower drop. Current drop speed still causes annoying effects.
- Check if MP3 detection still works (was reported to be broken - maybe Delossifier is broken? Test!) -> No, works fine. Probably a settings error?
- LW input force 48 kHz
- Generic plugin get API version call
- Absolute Highs: Filtering is not good. With size=1, there are still higher values after an initial gap. -> Ah, that was ok if it doesn't see a tone, but there still needs to be a maximum, added.
- LW buffer bug - if the Normal Output buffer is large, LW input hangs. But not always... - Unable to reproduce so far... (Logging added!) -> Doesn't seem to happen anymore. Cause still unknown.
- Fix weird startup bug -> Not seen anymore. When this happens, the pilot/rds are "broken" (signal jumps). Reloading the preset fixed it. No idea why... Only seen in .ST version. -> Not seen in a while, skip until it happens again.
- Absolute Highs has pre-ringing/mpeg like artifacts, try smaller block size (I think I increased it at some point to better filter annoying tones but that caused this problem). -> No, reducing makes sound more scratchy/squeeky.
- Absolute Highs before Noise Gate
- Check NAN's reported by baires
- Check memory leaks in stand alone version -> Caused by ASIO load bug, extra check added to avoid it in most cases.
- Compiler!! See VlcInfoFunctions.ci for example how to use external DLL.
- Add uMPX license keys
- Fix uMPX debug mode
- Check uMPX memory leaks
- Add uMPX non-licensed behavior
- Pul Paul's preset in!
- Call GuiToCommand in Generic plugin
- Make Absolute Highs 1-band mode respond to set frequencies.
- Bug in Absolute Highs; Vibrating sound -> Not there anymore?
- License key bug (Camclone) fixed.
- Asymmetry follows normal FM LPF frequency
- Reported that Nicholay Vachev's presets sound bad (distorted) in BETA063. --> Woops, in older versions BS412 was active even if FM wasn't enabled! And this preset had BS412 on.
- Add "Rules are there to be broken" block?
- Add Quadrature limiter/clipper
- Try allowing even more Quadrature noise, or faster via mirrorring. Try optimizing without x4.
- Optimize Quadrature clipper
- Fixed bug in string parameter class that could cause weird behavior (including a heap check fail in debug mode, sometimes), which was introduced in an earlier beta.
- Try Quadrature for BS412 -> No :(
- Try allowing more Quadrature noise -> Yes, now at 0.1-0.4 dB extra (was 0.1-0.2).
- Crash during startup in BETA069 fixed.
- Option added to allow Quadrature noise, this allows about 0.1-0.2 dB extra loudness (and a more open and less distorted sound) through the clipper. Might have some negative effects on stereo separation though on certain radio's (although it shouldn't be worse than some other processors' default behavior).
- Fixed logged out mode (needs to be updated for newly added pages and settings)
- Finalized RDS HTTP commands (Arctic Palm) - wait for test results.
- Crashes sometimes (since 061). -> Appears to be solved.
- Fixed 16/24 bit LSB ASIO format for new AudioScience 192 kHz capable sound card. - Matt Levin will test
- Add RDS HTTP commands (Nashville - talk to Arctic Palm) - Partially done - Arctic Palm will test
- Crash in Delossifier
- HD: Label "Diversity Delay" & add "HD" label to streaming
- Bass AGC (Old) is broken! -> Oops, new Ratio was implemented but it had a 1000:1 ratio instead of 1:1000!
- OPTIMIZE DELOSSIFIER
- Reduced stack usage, hopefully fixes crash issue
- Fix AGC ratio display
- Absolute Highs: Optimize performance: Check log() -> Removed most (256 to 40 per step), and part of code that's not needed disabled for Delossifier.
- Exciter: Try to reduce pre-ringing (maybe by doubling overlap? Or measure on bigger block size, then go back to smaller?) Is this still a problem? -> Doesn't seem to be.
- Fixed GUI bug. Maybe that fixes the gray screen that was reported by RadioImInternet - but I'm not too sure about that.
- Bug: Stereo Image Phase to 0 reduces L-R anti-phase sounds by about 6 dB, and also not constant. (This is new, used to be good before!) Problem occurs when feeding 100% anti-phase, even 1 degree difference between channels fixes it completely. -> Effect is reduced now, hopefully acceptable.
- Add Ratio to AGC
- Add Analyzer BYPASS mode (is that needed??) -> No, probably works already, but despite that, we can use a separate PC at the NAB for this.
- All L/R - L/R Quadrature mode, test with noise -> Doesn't work :(
- Add FM phase shift remover for high frequencies for Multipath
- Input Gain issue (see 2 posts below BETA054)
- LW SKIN!
- uM: Filter and add vac1/2/3/... option!
- Fixed broken VST plugin.
- Delossifier: Added MP3 detection filter; turn it on to disable the Delossifier when it thinks that the input is not an MP3.
- Delossifier: Protection added to not add too much. The result sounds cleaner, but it might also be slightly less effective. In total I think it's better.
- Detection and reconstruction both fail in 60's song Lay Down! -> Better now, but: 1. Make sure that this doesn't reduce repair elsewhere (some other parts are better now too, so be careful with that!). Maybe only remove narrow 'gaps' in the xmul array. 2. Improve detection to make Lay Down sound good always. It's not even an MP3! Check not only close to border but also a bit higher - should be nearly perfect silence! Maybe also some slowness in starting to repair?
- Absolute Highs: CRASH!
- Add Quadrature monitoring
- SPA remove monthly popup
- Added other optimizations
- Fix crash in BETA036.
- Exciter: Add Volume slider
- Exciter: Add DIFF mode
- Fixed crash when closing
- GUI: Added tooltips!
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- Make Delossifier checkbox more clear to clarify that having no Delossifier action also disables Absolute Highs!!! (For now).
- Remove LW logging
- Fix #warning's
- Finish getting rid of wxWidgets for Linux - Save window pos DONE - leave like this for now. Most important remaining item is keeping the mouse pointer at one place when dragging sliders.
- License check. Block HackMutant/REPT
- Run Valgrind and fix errors!
- Linux version: Add Xlib error handlers. -> Not needed anymore? Crash that triggered me to add this was a bug. Asserts added.
- Arctic Palm bug - Wait for Matt
- Add version with/without LW
- Add presets
- Finish getting rid of wxWidgets for Mac Mathijs
- Send latest version to all testers, and LW version to some; mail to student
LATER ASAP:
- Tell Arctic Palm that they can add Stereo Tool protocol.
- Measure LW CPU load for Egor
- Stand alone program & VST with demo option to do Declipper, Delossifier, AZIMUTH, Dequantizer, PNR, Natural Dynamics. (No noise gate!). Somewhere in next 2-3 weeks. ProTools plugin without demo. Maybe run limited time and stop. Or announcement every 25 seconds.
LATER S:
- LW: Show Local IP(s)?
- New Sync code with ASIO & PrecisionClock
- Audacity VST problem viewtopic.php?f=2&t=7798&p=34822
- Make Linux "Generic" plugin
Firma Koek - O skin
- Get rid of Jack for Mac, possibly Linux too
- Use 4 (or 8) cores for processing, Raspberry Pi etc. Or Clipper on separate CPU?
LATER:
- Try Delossifier on L-R??
- Improve MP3 detection (very low bitrate, Lay Down)
- Try running Absolute Highs on N=8 and N=10 (instead of the current 9) and take the minimum.
- Delossifier: Check why 16 bit MP3 at LekWaalFM doesn't get improved more by Delossifier (might be a hardcoded maximum somewhere). -> No, signal doesn't go down as steeply. Might be ok?? --> Alternative Reconstruction seems better in this case, but sometimes causes weird (LOUD) artifacts. Fix that. Also possible that we just need more Effect Strength setting due to the shallow drop (why is that anyway?).
- Delossifier: Pre ringing killer causes volume bumps. Which seems to sound good!!! Add a feature for this?
- Delossifier: Make Absolute Highs use normal HPF frequency if Delossifier detects no MP3. Or use combination of measurements or something...
- Normal Output: Don't output FM anymore! Use plugin_or_fm_output_enabled && !ALWAYS_SOUNDCARD_ACCESS. But that's not all - also check different lowpass freqs and clipping levels etc. Might be better to combine this with sound card redesign.
- set Encryption : impossible to view or modify all the processing settings. Solution is: Password like there is now (but only on Processing/repair settings!) to unlock viewing the settings plus one to load the .sts file (in the .ini it should load automatically I think...). In both cases, we could point to a separate fle that contains all the encoded settings. In case of .ini the password for unlocking must be stored in the .ini file..
- Preset Licensing : encrypted preset without beeps unlocked by a license - or never visible?
- Add filter to optimized processed audio for lossy codecs? See comments (//#warning) in Clip1Ch::clean1ch()
- Absolute Highs: Check how slowly the frequency should rise. Probably should only be available if Delossifier freq responds slowly? (Maybe already ok?)
- Show band frequencies in GUI (Natural Dynamics, MB).
- Try: Volume difference effect with different speed at different frequencies (From Pre-ringing killer)
- Add separate watchdog process - see Zuidwest FM email dd 2016-04-20 12:24
- Add HTTP commands and feedback - viewtopic.php?f=16&t=7701&p=34436#p34436
- Add sound card adjustment presets for analog sound cards.
- Input Balance issue (see 2 posts below BETA054), cause known (reallocalte big buffer for waveform display, then buffer size doesn't match, and for some reason this causes a shift in time. However, calculated values appear to be correct. Check in more detail after NAB.)
LATER 2:
- Auto-detect wrong sample rate conversions.
- Clipper: Try pre-filling quadrature! Put in pilot_rds signal. What about BS412?
- Add RT+ and Arctic Palm-like formats to help page
- Add auto detection of certain sound cards, like Marian Trace Alpha.
- Check Sort algorithm optimization
- Make DIFFERENCE work in Natural Dynamics for separate bands
PostPosted: Wed Jun 15, 2016 2:21 pm
UI is doing strange things in b76.
In advanced clipper > bass section, look @ screenshot
even after restarting ST this problems remains.
PostPosted: Wed Jun 15, 2016 4:26 pm
@GuntherM: Can you send me your settings? I can't reproduce it so far (in BETA079, but I didn't change anything in the GUI).
PostPosted: Wed Jun 15, 2016 9:18 pm
Btw manual attack/release shape values go only up to 500 but automatic ones are usually higher. Why is that?
PostPosted: Thu Jun 16, 2016 12:59 am
Hans, in b79 is everything back ok, very strange :(
PostPosted: Thu Jun 16, 2016 11:41 am
7.85 BETA079
LATER S:
No.
PostPosted: Fri Jun 17, 2016 12:57 am
7.85 BETA079
LATER S:
No.
Let me rephrase this!
Not remove, but not have this as the only option.
