I can start beta31D, but not beta31E. IF i start beta31E and kill task it locks Juli@'s asio .. so i need to restart windows.
- MultiCore audio OK now (asio), but, now i have minimal buffer size 3.1ms, was 2.0-2.1ms
Is that only for multicore? Or also if you disable that?
Must check that i forgot was i use 64 or 48 samples.
@Eldorado WinXP sp3 Juli@ driver v1.23
btw, ot this PC (AMD X2 5600+ @ 3Ghz) i have clicks at 5000ms too. beta31D, beta31A, beta31.
WHen it clicks i can see clippes in multiband reaction, so it's on input (?) (buffer not full)
Bojcha, could you try the following? See this post from eldoradofm. NOTE: According to EldoradoFM, this does NOT work anymore for versions BETA031C-E, so only for A and B!
Could you try this:
- Set Priority to Normal in Stereo Tool. This should lead to NO clicking at buffer size 5000.
- Then in Task Manager, stepwise increase the priority. I'd like to know at which setting clicking starts. If I know that I can probably add an extra mode in Stereo Tool.
Tested again but this time with version 31. With this version i also get clicks with buffer of 5000ms and stereotool to normal priority. When increasing the priority with task manager the clicks are gone with realtime.
Edit: Same result with version 31B
Edit: Same with version 31A
So the previous measurement was probably not done good enough or i did something different there. It takes some time (couple of second) before the click appears and maybe i haven't noticed it before.
Testing with version 31C
There's something wrong, i see the buffer filling and then it's empty and i get a click every 5 seconds.
