Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 758 posts ]  Go to page Previous 154 55 56 57 5876 Next
PostPosted: Sun Apr 29, 2018 12:11 pm
Stereo Tool 9.00 BETA064
NAN CHECKING IS ENABLED IN THIS VERSION
Windows stand alone: http://www.stereotool.com/download/ster ... 00-064.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 00-064.exe
VST: http://www.stereotool.com/download/vst_ ... 00-064.dll
- Fixed (enabled) highpass filter pre-ringing protection.
- We should probably put a warning in the next version if the CPU load is high. Done, but window doesn't nicely disappear (others as well probably)
OLDER CHANGES:
- Start of song Auto EQ/Bass EQ was too soft: Sudden Jump Protection now only acts when a band is being boosted (that wasn't the case before); effect at beginning is nearly completely gone and overall AutoEQ/BassEQ SJP does far less than before, but is not less effective!
- Sound card high frequency correction: Make sure it always works. -> Not in Ignore high frequencies mode!!!!!
- Fix Matt's GUI crash at a specific size
- FM Analyser pilot tilt problem fixed
- AGC PEQ live updates (when editing) didn't work
- Mono audio on Matt's machine - why?? Wait for .sts files. -> Was a wrong setting, FM Analyser was enabled.
- MicroMPX ifdef stuff
- RDS Compressed flag always set regardless of GUI setting (reported - check first) -> Confirmed, initial load is ignored. - Solved, wrongly initialized, ignored first SetCompresson() call.
- Weird effect for asymmetry -> External RDS input turned Asymmetry off!
- lower output L/R peaks when using external RDS - explained by Asymmetry above
- sg doesn't sound right - probably bad hard limiter Wait for Matt to test
- RDS PS= failure on Swed test files - was ignoring size of commands for other receivers
- Fixed preset load error (060)
- NAN logging disabled again
- NAN in equalizer fixed
- New skin
- Fix Basstardizer crash
- Fixed Symmetric Peak
- Max release speed fixed
New AGC mode MORE INFO BELOW!
- RDS: Add PTYN
- RDS: Add timeout for TA
- VST version no 4K
- Backup input - check stereo
- Self test crashes
- Put Bass EQ under license
- Added Basstardizer
- Add low input level warning
- Added ASIO latency setting.
- Natural Dynamics doesn't behave the same as before. (8.54)
- Show better license warning (maybe separate icon per used feature?)
- Added sound card input left/right/stereo selection.
- Redraw when warning disappears automatically
- Add MME warning
- Display settings
- Latest beta doesn't run on XP SP 2 (GetLogicalProcessorInfo can't be located in KERNEL32.dll).
- Website rename Products to Buy
- Add shortcuts for run as a service install/uninstall
- SST: Show warnings
- Muziek uploaden
- Rivendell plugin build
- DJB plugin build
- NAS
- Start of song AGC etc behavior. Fixed starting point, for AGC
- Quality > 100% extreme CPU warning and recovery
- Quality > 100% Bypass switching causes buffer filling to move
- Add AM presets
- Add new presets
- HPF after MB2 causes too loud bass into clipper (after very tightly limiting it - Bojcha)
- Left Only (dus links naar twee kanalen), Right Only (dus rechts naar twee kanalen, Stereo (default) schakelaar inbouwen in ST
- Array met frequenties versus levels (dus de uitkomst van FFourier) resultanten naar buiten brengen
- Use top part for extra displays (declipper, numbers for MPX level etc)
- Kant
- AGC better LKFS (Bojcha)
- Classical preset
- Test NanoPi
- AM streaming output
- Multi-instance version
- AF method B via UECP
- 18 Hz trigger tone
- Declipper check L-R effects
- Reduce extreme stereo
- Check out Butt
- Omnia.9 test/fix logging
- WatchCat website
- Triple stuff
- uMPX 24x2ch interface
- One bass page
- Talk to chip
- 2 jaar
- Fardau
- -24 dB side chain range?
NOTE: Bass EQ
New compressor mode info:
PostPosted: Sun Apr 29, 2018 12:12 pm
There is still *some* difference, but it should be far far less than before. I haven't looked at the AGC yet either.
OK, just, based on your post below, it sounded like there wasn't supposed to be a difference at all anymore? :?
Woohoo! Just when I wanted to post the reply that this cannot be fixed... I figured out how to fix it :) Sudden Jump Protection in Auto EQ works a lot better than before now too - it does far less, which is good!
Will run a new build tonight.
This image shows your preset WITH AutoEQ and BassEQ on top, without at the bottom. No difference anymore :)
Anyway, thanks for trying to fix it. I can live with "priming" tracks, it's not that hard to do.
Well, this output was with your file and your settings. So it kinda should be ok now. I'll check again - I didn't fix everything yet (LLB for example) so that could be it too.
PostPosted: Sun Apr 29, 2018 5:24 pm
Yeah, that's the same sample, at least the first 30 seconds of it.
I feel like if I run the plugin twice and don't get repeatable results, I'm confused as to what the "correct" result should be. I know the main use of Stereo Tool is real time FM broadcasting, so this would not be an issue for that. But it is for people who want to use it as a mastering tool and want to batch process files. It would seem like the "after audio has been running through it" result is the result you'd want, hence the need to "prime" Stereo Tool if the issue can't be fixed so that you get repeatable results (even if they are not exact they should be as close as possible).
Thanks again for spending time on it. I really appreciate that. :geek:
PostPosted: Sun Apr 29, 2018 5:27 pm
Well, exactly the same is never possible because the history affects the current levels. But, we do need to get rid of the priming - that shouldn't be needed, it just means that my startup values are wrong.
Having said that, my output files looked virtually identical (but I did disable a few things, I mainly looked at the Auto EQ and Bass EQ).
PostPosted: Sun Apr 29, 2018 5:48 pm
Ok I just looked at it again, and now it makes sense to me: The Auto EQ levels are different the 2nd time you run the file through it, so certain sounds are louder going into the rest of the chain. Others are softer. So the output isn't exactly the same - but, more importantly, priming wouldn't fix that. Priming also would just take you to some random starting point. Unless you prime by playing the last 10 seconds of the file at the start for example.
PostPosted: Sun Apr 29, 2018 5:50 pm
Hans, I have enormous problems with the last version in Adobe Premiere. On the one hand my presets are no longer loaded correctly, and on the other hand the multiband compressor does not work at all. Yeah, it's not working on the system at all. At the beginning the blue bars are displayed for about 2 seconds, and then only the red limit bars are displayed. When I use the old "Digital" compressor, everything runs normally, but I can no longer use the new one. I can't figure out why either. The single band compressor, on the other hand, runs without problems, which is strange. However, the error does not occur until the last versions. I'd have to check again when it didn't work properly so you can narrow it down. In any case, I am more than confused that this is not possible at all.
However, the error does not always occur, only sometimes. Then all of a sudden, nothing works at all. I can't figure out why it's stalling.
As a supplement. The whole plugin runs very unstable in Premiere. Sometimes I have dropouts in the sound, then if I jump further in front the plugin is reset. And sometimes the entire user interface stops responding. The VST64 version has never been so unstable in Windows under Adobe Premiere! In Audition, the version is much more stable and active.
PostPosted: Sun Apr 29, 2018 9:53 pm
Hello Hans,
Translation problem
I can't translate the following lines:
Prepare for lossy compression (MP3/AAC/OGG/...)
Input can be compressed (MP3 etc.)
hello Hans,
I submit to you again the unresolved bug
PostPosted: Mon Apr 30, 2018 12:36 am
I'm unfortunately not seeing this here, if you have more exact info about which exact version is the first that broke I can search more targeted.
PostPosted: Mon Apr 30, 2018 11:44 am
Not sure you got my email so I put it here. I am still having the issue where sometimes the highest band of the auto-eq gets stuck to maximum amplification after switching to a new preset.
PostPosted: Mon Apr 30, 2018 2:27 pm
I got it, haven't had time to look at it yet. It might be that something is wrong in my latest code change (to fix the startup behavior), I'm not sure though. (You didn't see it before right?)
