Steep or not steep slopes actually do almost nothing. I suggest You to try yourself. Turn 2 bands mode with crossover around 150-250Hz and try to make sweep flat.
In best case what You'll see is 4-5dB difference in sweep, no metter how you set
steepness!
Here is my band settings:
http://i.imgur.com/4AfJX9H.png for around 200Hz crossover.
With more number of bands difference is less (but still noticable difference), which logically means that 9 (max) bands will be best current choice, and it is.
Ok, with feedback and many bands it's far less noticeable, and I hadn't realized how big the effect could be with less bands.
The good news is that I know the solution (already used it in the old multiband), and it might actually solve some other things as well. Although it could also create new problems, and it won't completely fix the issue.
What I think I need to do is use a sideband where the lowering of the slope (in both directions) starts later - probably around the crossover point. Also, this sideband should not be compensated to reach a total level of 1, so for example a low frequency band with much overlap with the next band will respond as if it peaks to 100% - no need to adjust the threshold for it.
And BTW, AGC is not working good (2 or 3 bands) That is still steep slope and also in my 2nd test, one page back, sweep should be NOT flat.
It's far less steep than before - at least 4 times less in my measurements - but it's probably a good idea to change the filter between the two bands further. I don't understand yet what's happening with the flat response, and DJ_DOGGY just reported a 'blobblobblob' issue with band 3 - so this will need some more work.
In Multiband, I found that the burst protection with the new limitation that I added today it is working really well - it's almost never active when it doesn't need to be anymore. But there's one problem: You hear the protection kick in now, because the effect is switched on 10-20 samples too late. So I need to add some lookahead behavior.
I'll probably not post any new beta's until these issues are resolved.
Also: SCA is gone from the GUI, need to add it again for one station.
