Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 151 52 53 54 5559 Next
PostPosted: Mon Jun 06, 2016 4:59 pm
You have mail! (If your email address is still valid, that is).
PostPosted: Mon Jun 06, 2016 5:13 pm
Thanks Hans :) :) :) i will set it up and let you know :)
PostPosted: Mon Jun 06, 2016 5:56 pm
Bojcha, am i understand it right - whole MPX signal(192Khz) streamed and fitted into 320 Kbps only ?
Yes.
I tried also 512 but pretty much same as 320.
It sounds unbeliveble.. but this is not regular encoding/decoding :)
Both sides do some work.
PostPosted: Mon Jun 06, 2016 8:48 pm
Hans, could you please compile a cmd-build of the beta version? Only if it's not too much extra work off course.
PostPosted: Tue Jun 07, 2016 5:19 am
This when loading the preset. Also the version number went from BETA074 to BETA076.
Jez, try this. Was thrown in in haste, my fault. No FM, I'm assuming you know how to enable this. You can quickly listen at www.bayfm.org.au stream, as its exactly what is going to air.
Let me know how you go.
Paul
PostPosted: Tue Jun 07, 2016 7:22 am
I am one of the OLDEST testers around....! I request a test version too.!
Thanks!
Well look at mine then! Though not been a very active here.. :lol:
PostPosted: Tue Jun 07, 2016 8:04 am
If we talk for test equipment - Bojcha has such stuff
But if we talk for join date , so look at mine - it`s even before Bojchas date but... So stop taking for this- anyone can help in his way :)
PostPosted: Tue Jun 07, 2016 1:02 pm
Thanks!
WOW and Doggy is older too !!!!
PostPosted: Tue Jun 07, 2016 4:17 pm
error en multiband threshold
espero se solucione.
File comment: error multiband threshold
PostPosted: Tue Jun 07, 2016 4:32 pm
Please send me your settings so I can check.
