Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 150 51 52 53 5459 Next
PostPosted: Sun Jun 05, 2016 12:04 am
@andreigherghe: The Raspberry Pi version *is* compiled for ARM! Otherwise it wouldn't run in the first place. I'm just trying to find a better compiler than gcc, I've noticed on Windows that when I compile with the Intel compiler the performance is 50% better than with gcc, I expect the same on ARM, but there obviously is no Intel compiler for ARM....
About the 2 vs 4 cores: This item is on my todo list:
- Use 4 (or 8) cores for processing, Raspberry Pi etc. Or Clipper on separate CPU?
PostPosted: Sun Jun 05, 2016 12:16 am
Thanks for the quick reply!
I know it is compiled for ARM, but I was referring to the 7.85 beta, since I saw only Windows 32-bit versions posted.
PostPosted: Sun Jun 05, 2016 10:42 pm
Ah. Performance hasn't changed, and it takes some effort to build that, so not yet. But it won't be any different.
PostPosted: Sun Jun 05, 2016 11:30 pm
7.85 BETA076
Windows stand alone: http://www.stereotool.com/download/ster ... 85-076.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-076.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-076.dll
CHANGED:
- Delossifier: Disable Alternative reconstruction mode for now? (Fix it later, see LATER).
- uMPX decoder crackle
- uMPX crash on repeated closing.
- Delossifier: Make slower drop. Current drop speed still causes annoying effects.
- Check if MP3 detection still works (was reported to be broken - maybe Delossifier is broken? Test!) -> No, works fine. Probably a settings error?
- LW input force 48 kHz
- Generic plugin get API version call
- Absolute Highs: Filtering is not good. With size=1, there are still higher values after an initial gap. -> Ah, that was ok if it doesn't see a tone, but there still needs to be a maximum, added.
- LW buffer bug - if the Normal Output buffer is large, LW input hangs. But not always... - Unable to reproduce so far... (Logging added!) -> Doesn't seem to happen anymore. Cause still unknown.
- Fix weird startup bug -> Not seen anymore. When this happens, the pilot/rds are "broken" (signal jumps). Reloading the preset fixed it. No idea why... Only seen in .ST version. -> Not seen in a while, skip until it happens again.
- Absolute Highs has pre-ringing/mpeg like artifacts, try smaller block size (I think I increased it at some point to better filter annoying tones but that caused this problem). -> No, reducing makes sound more scratchy/squeeky.
- Absolute Highs before Noise Gate
- Check NAN's reported by baires
- Check memory leaks in stand alone version -> Caused by ASIO load bug, extra check added to avoid it in most cases.
- Compiler!! See VlcInfoFunctions.ci for example how to use external DLL.
- Add uMPX license keys
- Fix uMPX debug mode
- Check uMPX memory leaks
- Add uMPX non-licensed behavior
- Pul Paul's preset in!
- Call GuiToCommand in Generic plugin
- Make Absolute Highs 1-band mode respond to set frequencies.
- Bug in Absolute Highs; Vibrating sound -> Not there anymore?
- License key bug (Camclone) fixed.
- Asymmetry follows normal FM LPF frequency
- Reported that Nicholay Vachev's presets sound bad (distorted) in BETA063. --> Woops, in older versions BS412 was active even if FM wasn't enabled! And this preset had BS412 on.
- Add "Rules are there to be broken" block?
- Add Quadrature limiter/clipper
- Try allowing even more Quadrature noise, or faster via mirrorring. Try optimizing without x4.
- Optimize Quadrature clipper
- Fixed bug in string parameter class that could cause weird behavior (including a heap check fail in debug mode, sometimes), which was introduced in an earlier beta.
- Try Quadrature for BS412 -> No :(
- Try allowing more Quadrature noise -> Yes, now at 0.1-0.4 dB extra (was 0.1-0.2).
- Crash during startup in BETA069 fixed.
- Option added to allow Quadrature noise, this allows about 0.1-0.2 dB extra loudness (and a more open and less distorted sound) through the clipper. Might have some negative effects on stereo separation though on certain radio's (although it shouldn't be worse than some other processors' default behavior).
- Fixed logged out mode (needs to be updated for newly added pages and settings)
- Finalized RDS HTTP commands (Arctic Palm) - wait for test results.
- Crashes sometimes (since 061). -> Appears to be solved.
- Fixed 16/24 bit LSB ASIO format for new AudioScience 192 kHz capable sound card. - Matt Levin will test
- Add RDS HTTP commands (Nashville - talk to Arctic Palm) - Partially done - Arctic Palm will test
- Crash in Delossifier
- HD: Label "Diversity Delay" & add "HD" label to streaming
- Bass AGC (Old) is broken! -> Oops, new Ratio was implemented but it had a 1000:1 ratio instead of 1:1000!
- OPTIMIZE DELOSSIFIER
- Reduced stack usage, hopefully fixes crash issue
- Fix AGC ratio display
- Absolute Highs: Optimize performance: Check log() -> Removed most (256 to 40 per step), and part of code that's not needed disabled for Delossifier.
- Exciter: Try to reduce pre-ringing (maybe by doubling overlap? Or measure on bigger block size, then go back to smaller?) Is this still a problem? -> Doesn't seem to be.
- Fixed GUI bug. Maybe that fixes the gray screen that was reported by RadioImInternet - but I'm not too sure about that.
- Bug: Stereo Image Phase to 0 reduces L-R anti-phase sounds by about 6 dB, and also not constant. (This is new, used to be good before!) Problem occurs when feeding 100% anti-phase, even 1 degree difference between channels fixes it completely. -> Effect is reduced now, hopefully acceptable.
- Add Ratio to AGC
- Add Analyzer BYPASS mode (is that needed??) -> No, probably works already, but despite that, we can use a separate PC at the NAB for this.
- All L/R - L/R Quadrature mode, test with noise -> Doesn't work :(
- Add FM phase shift remover for high frequencies for Multipath
- Input Gain issue (see 2 posts below BETA054)
- LW SKIN!
- uM: Filter and add vac1/2/3/... option!
- Fixed broken VST plugin.
- Delossifier: Added MP3 detection filter; turn it on to disable the Delossifier when it thinks that the input is not an MP3.
- Delossifier: Protection added to not add too much. The result sounds cleaner, but it might also be slightly less effective. In total I think it's better.
- Detection and reconstruction both fail in 60's song Lay Down! -> Better now, but: 1. Make sure that this doesn't reduce repair elsewhere (some other parts are better now too, so be careful with that!). Maybe only remove narrow 'gaps' in the xmul array. 2. Improve detection to make Lay Down sound good always. It's not even an MP3! Check not only close to border but also a bit higher - should be nearly perfect silence! Maybe also some slowness in starting to repair?
- Absolute Highs: CRASH!
- Add Quadrature monitoring
- SPA remove monthly popup
- Added other optimizations
- Fix crash in BETA036.
- Exciter: Add Volume slider
- Exciter: Add DIFF mode
- Fixed crash when closing
- GUI: Added tooltips!
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
Mathijs - Crash at N1 in version with MicroMPX
- Delossifier: Lay Down breaks Delossifier, sounds really bad with MP3 detection turned off! (And it's not MP3). More accurate detection (smooth rolloff??) still needed, to also not detect it when not using Detect MPEG mode! Does Alternative Method sound better now?? Also try without HACK. --> Seems ok now. Add extra steep drop check. -> Solved good enough for now.
- Hanegraaf: Check RTAS en andere berschrijvingen
- SAM problem - viewtopic.php?f=14&t=7262&p=34903#p34903 -> Was internal SAM problem, apparently
- Delossifier on and no MP3 input disabled Absolute Highs in Follow Delossifier mode. Is that ok? -> No, should fall back to normal HPF determination but that's not there yet... So postpone for now. Make checkbox more clear to clarify this!!!
- Measure LW CPU load for Egor
- Arctic Palm bug & add protocol
- Latency 9sg checken
- Audacity VST problem viewtopic.php?f=2&t=7798&p=34822
- Get rid of wxWidgets for Mac Mathijs
- Get rid of wxWidgets for Linux
- Make Linux "Generic" plugin
- License check. Block HackMutant/REPT
- Add presets
- Stand alone program & VST with demo option to do Declipper, Delossifier, AZIMUTH, Dequantizer, PNR, Natural Dynamics. (No noise gate!). Somewhere in next 2-3 weeks. ProTools plugin without demo. Maybe run limited time and stop. Or announcement every 25 seconds.
LATER S:
- New Sync code with ASIO & PrecisionClock
Firma Koek - O skin
- Get rid of Jack for Mac, possibly Linux too
LATER:
- Try Delossifier on L-R??
- Improve MP3 detection (very low bitrate, Lay Down)
- Try running Absolute Highs on N=8 and N=10 (instead of the current 9) and take the minimum.
- Delossifier: Check why 16 bit MP3 at LekWaalFM doesn't get improved more by Delossifier (might be a hardcoded maximum somewhere). -> No, signal doesn't go down as steeply. Might be ok?? --> Alternative Reconstruction seems better in this case, but sometimes causes weird (LOUD) artifacts. Fix that. Also possible that we just need more Effect Strength setting due to the shallow drop (why is that anyway?).
- Delossifier: Pre ringing killer causes volume bumps. Which seems to sound good!!! Add a feature for this?
- Delossifier: Make Absolute Highs use normal HPF frequency if Delossifier detects no MP3. Or use combination of measurements or something...
- Normal Output: Don't output FM anymore! Use plugin_or_fm_output_enabled && !ALWAYS_SOUNDCARD_ACCESS. But that's not all - also check different lowpass freqs and clipping levels etc. Might be better to combine this with sound card redesign.
- set Encryption : impossible to view or modify all the processing settings. Solution is: Password like there is now (but only on Processing/repair settings!) to unlock viewing the settings plus one to load the .sts file (in the .ini it should load automatically I think...). In both cases, we could point to a separate fle that contains all the encoded settings. In case of .ini the password for unlocking must be stored in the .ini file..
- Preset Licensing : encrypted preset without beeps unlocked by a license - or never visible?
- Add filter to optimized processed audio for lossy codecs? See comments (//#warning) in Clip1Ch::clean1ch()
- Absolute Highs: Check how slowly the frequency should rise. Probably should only be available if Delossifier freq responds slowly? (Maybe already ok?)
- Show band frequencies in GUI (Natural Dynamics, MB).
- Try: Volume difference effect with different speed at different frequencies (From Pre-ringing killer)
- Add separate watchdog process - see Zuidwest FM email dd 2016-04-20 12:24
- Add HTTP commands and feedback - viewtopic.php?f=16&t=7701&p=34436#p34436
- Add sound card adjustment presets for analog sound cards.
- Input Balance issue (see 2 posts below BETA054), cause known (reallocalte big buffer for waveform display, then buffer size doesn't match, and for some reason this causes a shift in time. However, calculated values appear to be correct. Check in more detail after NAB.)
LATER 2:
- Auto-detect wrong sample rate conversions.
- Clipper: Try pre-filling quadrature! Put in pilot_rds signal. What about BS412?
- Add RT+ and Arctic Palm-like formats to help page
- Add auto detection of certain sound cards, like Marian Trace Alpha.
- Check Sort algorithm optimization
- Make DIFFERENCE work in Natural Dynamics for separate bands
PostPosted: Mon Jun 06, 2016 6:46 am
error preset Paul Thompson.
PostPosted: Mon Jun 06, 2016 9:44 am
This when loading the preset. Also the version number went from BETA074 to BETA076.
PostPosted: Mon Jun 06, 2016 12:34 pm
Hans 2 question
1st Under which menu is the uMpx ?
2nd Whats the cost for the uMpx Key ?
Thanks!
PostPosted: Mon Jun 06, 2016 3:40 pm
Hans 2 question
Thanks!
It's still hidden. Still for testers only.
PostPosted: Mon Jun 06, 2016 4:01 pm
Bojcha, am i understand it right - whole MPX signal(192Khz) streamed and fitted into 320 Kbps only ?
PostPosted: Mon Jun 06, 2016 4:26 pm
I am one of the OLDEST testers around....! I request a test version too.!
Thanks!
