Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 14 5 6 7 859 Next
PostPosted: Mon Jan 18, 2016 6:46 pm
I'm currently trying to make it use multiple bands. It sounds much cleaner but for some reason I'm getting very bad MP3-like artifacts.
PostPosted: Tue Jan 19, 2016 12:46 pm
7.85 BETA011
Windows stand alone: http://www.stereotool.com/download/ster ... 85-011.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-011.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-011.dll
CHANGED:
- Improved Exciter: Now using 40 bands instead of 1
- Added some filtering to make sound less 'sandy' (distorted).
- Exciter: Check why it sometimes boosts audio around 10 kHz (?) more than it should (Johnnie Cash) - protection filter appears not to work completely. Compare what happens without protection filter! -> Fixed (more or less)
- Added a soft of exciter (not an FM exciter but something that generates highs). I've placed it (for now) under True Bass, and it cannot be configured yet. Not really sure what to make of it yet, I think I like it but it does sound a bit "rough" sometimes. Note: It can cause pre- and post ringing at higher latency settings (I will fix that later, first want to get a bit of a feeling for what it does).
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- Try "True Bass" for highs -> Probably make a version where different modes (with/without filtering, with better HPF) are tested. Maybe also with multiple bands?? To reduce generated distortion.
- O skin
- Blog post pre-processing
- Blog post MP3 and declipping
PostPosted: Tue Jan 19, 2016 1:24 pm
hans i got a little nan problem
PostPosted: Tue Jan 19, 2016 1:51 pm
Well, if I enable the Highs-Exciter, I only get choppy audio-output :oops:
Record of the result: http://www83.zippyshare.com/v/6Xev5R4i/file.html
(starts at about 10 seconds)
PostPosted: Tue Jan 19, 2016 3:01 pm
Hm... so the first 10 seconds were ok? Weird... I must have missed some divide by 0 or something like that I suppose.
PostPosted: Tue Jan 19, 2016 3:13 pm
Hans, here to if you select exciter button it sounds like you select difference button
Edit: i get a EXCEPTION i select exciter
PostPosted: Tue Jan 19, 2016 5:32 pm
I have found something suspicious and also improved the sound a bit further, so I will build and upload a new version.
PostPosted: Tue Jan 19, 2016 6:02 pm
7.85 BETA012
Windows stand alone: http://www.stereotool.com/download/ster ... 85-012.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-012.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-012.dll
EDIT: THIS VERSION IS ADDING FAR TOO MUCH HIGHS IN SOME CASES, AND IT SOUNDS MP3-ISH. WORKING ON IT, PLEASE IGNORE THIS FOR NOW...
CHANGED:
- Fixed some Exciter issues (which might have been the cause of errors that some people reported).
- Calculate target amplification levels for each bin using white (?) noise!
- O skin
PostPosted: Tue Jan 19, 2016 6:08 pm
still has issues on Exciter, after some seconds crash the sound and gaps
PostPosted: Tue Jan 19, 2016 6:24 pm
So this version is now really much better. I have no gaps and problems with it, as opposed to the 11 version.
But something else struck me. In the 09 version there was meaningful overtones for some sounds. I have here an example in which in the 09 version, the strings have been completed properly. With the current version, however, nothing is completed. It simply lacks the whole information. If you want I can send you via PM these files. However, the completion now works better on percussion instruments. Sometimes, there are now some mp3 artifacts.
Edited: One more question: At what frequency the harmonics are completed? I had here a try with 11025 Hz. But no predictions were made in this file.
